Grove stepper and motor driver not going in reverse
Hello!
I am using the grove stepper and motor from Arduino Project Hub.
I cant get the motor to go in reverse. I am passing a negative int to myStepper.step() but it still rotates the same direction.
Any ideas?
#include <Stepper.h>
int t =0;
const int stepsPerRevolution = 200;
Stepper myStepper(stepsPerRevolution, 8, 9, 10, 11);
int stepCount = 0;
  int lightValue = analogRead(A0);
  lightValue = map(lightValue, 0, 646, 0, 100);
  Serial.println("Light Value:");
  Serial.println(lightValue);
  int motorSpeed = 50;
  myStepper.setSpeed(motorSpeed);
  if (lightValue > 54) {
    Serial.println("lightvalue > 54");
    myStepper.step(stepsPerRevolution);
  } else if(lightValue < 46) {
    Serial.println("lightvalue < 46");
    myStepper.step(stepsPerRevolution*-1);
    Serial.println("motor is still");
  delay(250);
There is no pause between forward & reverse, maybe it IS reversing but you can't see it, put a 300 mS delay between F & R, stick a piece of tape on the shaft for a flag and try it.
int t =0;
int stepCount = 0;
  delay(300);
    delay(300);
  delay(250);
There is delay(250); at the end of the if else statement.
Did you try the " Stepper Motor Control - one revolution" in the Examples- Stepper in the IDE?
This is it, you may need to change a statement to match your wiring pins.
 This program drives a unipolar or bipolar stepper motor.
 The motor is attached to digital pins 8 - 11 of the Arduino.
 The motor should revolve one revolution in one direction, then
 one revolution in the other direction.
 Created 11 Mar. 2007
 Modified 30 Nov. 2009
 by Tom Igoe
const int stepsPerRevolution = 200;  // change this to fit the number of steps per revolution
// for your motor
// initialize the stepper library on pins 8 through 11:
  // set the speed at 60 rpm:
  myStepper.setSpeed(60);
  // initialize the serial port:
  // step one revolution  in one direction:
  Serial.println("clockwise");
  // step one revolution in the other direction:
  Serial.println("counterclockwise");
  myStepper.step(-stepsPerRevolution);
Tom... :slight_smile:
Have you connected the wires in the right sequence? only a third of the possible wiring posibilities will
produce proper rotation for a 5-wire stepper. Don't assume the order is left-to-right.
@MarkT I changed the pin sequence from 8, 9, 10, 11 to 8, 10, 9, 11 and it works correctly.
