I try to test Grove - Infrared Temperature Sensor on Ardiuno Yun with the sample code but it dose not work in the console it show that the object temperature is out of range all the time. However, when I try to test it on Ardiuno Uno, it works fine. The following code is the one I use to with Grove Temperature sensor.
HERE IS THE CODE:
// Function: Measure the measure the Surrounding temperature around the sensor
// and the temperature of the target which is in front of the sensor.
// And print the result on the serial monitor.
// Hardware: Grove - Infrared Temperature Sensor
// Arduino IDE: Arduino-1.0
// Author: Bruce.Qin
// Date: Nov 28,2011
// Version: v1.0 modified by FrankieChu at Jan 24,2013
// by www.seeedstudio.com
// This library is free software; you can redistribute it and/or
// modify it under the terms of the GNU Lesser General Public
// License as published by the Free Software Foundation; either
// version 2.1 of the License, or (at your option) any later version.
// This library is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
// Lesser General Public License for more details.
// You should have received a copy of the GNU Lesser General Public
// License along with this library; if not, write to the Free Software
// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#include <math.h>
#define SUR_TEMP_PIN A0 // Analog input pin connect to temperature sensor SUR pin
#define OBJ_TEMP_PIN A1 // Analog input pin connect to temperature sensor OBJ pin
float temp_calibration=0; //this parameter was used to calibrate the temperature
//float objt_calibration=0.000; //this parameter was used to calibrate the object temperature
float temperature_range=10; //we make a map of temperature-voltage according to sensor datasheet. 10 is the temperature step when sensor and
//object distance is 9CM.
float offset_vol=0.014; //this parameter was used to set the mid level voltage,when put the sensor in normal environment after 10 min,
//the sensor output 0.For example,the surrounding temperature is 29℃,but the result is 27℃ via the sensor,
//you should set the reerence to 0.520 or more,according to your sensor to change.
//the unit is V
float tempValue = 0;
float objtValue= 0;
float current_temp=0;
float temp=0;
float temp1=0;
float temp2=0;
unsigned int temp3=0;
const float reference_vol=0.500;
unsigned char clear_num=0;//when use lcd to display
float R=0;
float voltage=0;
long res[100]={
318300,302903,288329,274533,261471,249100,237381,226276,215750,205768,
196300,187316,178788,170691,163002,155700,148766,142183,135936,130012,
124400,119038,113928,109059,104420,100000,95788,91775,87950,84305,
80830,77517,74357,71342,68466,65720,63098,60595,58202,55916,
53730,51645,49652,47746,45924,44180,42511,40912,39380,37910,
36500,35155,33866,32631,31446,30311,29222,28177,27175,26213,
25290,24403,23554,22738,21955,21202,20479,19783,19115,18472,
17260,16688,16138,15608,15098,14608,14135,13680,13242,12819,
12412,12020,11642,11278,10926,10587,10260,9945,9641,9347,
9063,8789,8525,8270,8023,7785,7555,7333,7118,6911};
float obj [13][12]={
/0/ { 0,-0.274,-0.58,-0.922,-1.301,-1.721,-2.183,-2.691,-3.247,-3.854,-4.516,-5.236}, //
/1/ { 0.271,0,-0.303,-0.642,-1.018,-1.434,-1.894,-2.398,-2.951,-3.556,-4.215,-4.931}, //→surrounding temperature,from -10,0,10,...100
/2/ { 0.567,0.3,0,-0.335,-0.708,-1.121,-1.577,-2.078,-2.628,-3.229,-3.884,-4.597}, //↓object temperature,from -10,0,10,...110
/3/ { 0.891,0.628,0.331,0,-0.369,-0.778,-1.23,-1.728,-2.274,-2.871,-3.523,-4.232},
/4/ { 1.244,0.985,0.692,0.365,0,-0.405,-0.853,-1.347,-1.889,-2.482,-3.13,-3.835},
/5/ { 1.628,1.372,1.084,0.761,0.401,0,-0.444,-0.933,-1.47,-2.059,-2.702,-3.403},
/6/ { 2.043,1.792,1.509,1.191,0.835,0.439,0,-0.484,-1.017,-1.601,-2.24,-2.936},
/7/ { 2.491,2.246,1.968,1.655,1.304,0.913,0.479,0,-0.528,-1.107,-1.74,-2.431},
/8/ { 2.975,2.735,2.462,2.155,1.809,1.424,0.996,0.522,0,-0.573,-1.201,-1.887},
/9/ { 3.495,3.261,2.994,2.692,2.353,1.974,1.552,1.084,0.568,0,-0.622,-1.301},
/10/ { 4.053,3.825,3.565,3.27,2.937,2.564,2.148,1.687,1.177,0.616,0,-0.673},
/11/ { 4.651,4.43,4.177,3.888,3.562,3.196,2.787,2.332,1.829,1.275,0.666,0},
/12/ { 5.29,5.076,4.83,4.549,4.231,3.872,3.47,3.023,2.527,1.98,1.379,0.72}
Serial.begin(9600); // initialize serial communications at 9600 bps
analogReference(INTERNAL);//set the refenrence voltage 1.1V,the distinguishability can up to 1mV.
//analogReference(INTERNAL1V1);//(mega only)set the refenrence voltage 1.1V,the distinguishability can up to 1mV.
measureSurTemp();//measure the Surrounding temperature around the sensor
measureObjectTemp();
float binSearch(long x)// this function used for measure the surrounding temperature
int low,mid,high;
low=0;
//mid=0;
high=100;
while (low<=high)
mid=(low+high)/2;
if(x<res[mid])
low= mid+1;
else//(x>res[mid])
high=mid-1;
return mid;
float arraysearch(float x,float y)//x is the surrounding temperature,y is the object temperature
int i=0;
float tem_coefficient=100;//Magnification of 100 times
i=(x/10)+1;//Ambient temperature
voltage=(float)y/tem_coefficient;//the original voltage
//Serial.print("sensor voltage:\t");
//Serial.print(voltage,5);
//Serial.print("V");
for(temp3=0;temp3<13;temp3++)
if((voltage>obj[temp3])&&(voltage<obj[temp3+1]*)) *
* return temp3; *
float measureSurTemp()
* unsigned char i=0;*
* float current_temp1=0;
_ int signal=0; _
_ tempValue=0;_
_ for(i=0;i<10;i++) // _
_ { _
tempValue+= analogRead(SUR_TEMP_PIN);
_ delay(10); _
_ } _
_ tempValue=tempValue/10; _
_ temp = tempValue1.1/1023;
R=2000000temp/(2.50-temp); _
_ signal=binSearch(R); _
current_temp=signal-1+temp_calibration+(res[signal-1]-R)/(res[signal-1]-res[signal]);
_ Serial.print("Surrounding temperature:");_
Serial.print(current_temp);
return current_temp;
_}_
float measureObjectTemp()
_{_
_ unsigned char i=0; _
_ unsigned char j=0; _
float sur_temp=0;
unsigned int array_temp=0;
_ float temp1,temp2;_
float final_temp=0;
_ objtValue=0; _
_ for(i=0;i<10;i++)_
_ {_
objtValue+= analogRead(OBJ_TEMP_PIN);
_ delay(10);_
_ } _
_ objtValue=objtValue/10;//Averaging processing _
temp1=objtValue1.1/1023;//+objt_calibration;
* sur_temp=temp1-(reference_vol+offset_vol);
_ Serial.print("\t Sensor voltage:"); _
Serial.print(sur_temp,3);
_ Serial.print("V"); _
array_temp=arraysearch(current_temp,sur_temp1000);
* temp2=current_temp;
temp1=(temperature_rangevoltage)/(obj[array_temp+1][(int)(temp2/10)+1]-obj[array_temp][(int)(temp2/10)+1]);
* final_temp=temp2+temp1;
if((final_temp>100)||(final_temp<=-10))
_ {_
_ Serial.println ("\t out of range!");_
_ }_
_ else*_
* Serial.print("\t object temperature:"); *
* Serial.println(final_temp,2);
_ }_
_}_
_MeasureTemperature.zip (3.35 KB)*_
