Growduino smart garden
That looks like a nice set up Odisej. I'm curious as to how you have the window set up.
Pretty cool! I've wanted to do something like this, but I just have a deadly fear of water anywhere near electronics. Maybe this will motivate me (if I'm careful enough haha :P)!
@streety: I wanted to get a strong servo motor, but figured out it could be quite expensive stuff...so I went to a junkyard and took a motor from a car (screen wipers) and it works great. I control it through a strong mos-fet and I regulate the speed using pwm :slight_smile: In this winter time I am upgrading the code, adding RTC for better timing and accuracy and watchdog to consume less power.
Regards,
Peter
This is an awesome project. I think I'm going to work on something like this next. And why did I not think of going to a dump to find old electronic parts. Also, and idea: most local computer stores would be glad to give used parts too. And they would probably be interested in cool electronics like this in their store.
I have something very similar to this. Details are on my blog here: New project: Arduinoponics
But I basically also used a Ford windshield wiper pump to make a system in the style of a WindowFarm (http://windowfarms.org/).
I added/hardcoded my pump timer interval code into the Firmata firmware (my source here GitHub - nemik/arduinoponics: Arduino code to control a pump for hydroponics purposes.). I did this because the pumping of nutrients is the most important. I plan to otherwise use serial communication via Firmata and a laptop or small router to do the sensing for temperature, light, humidity, etc and also turn lights on and off.
Right now it just runs the pump for 4 seconds every 10 minutes. It's all powered from a 12V 1A AC adapter with a 7805 regulator producing 5V for the Arduino and 12v going to the pump via a transistor.
I have some pictures of it here: hydroponics | Flickr
I'm really interested to start something like this, but where for crying out loud do you get those small DC pumps? I've looked everywhere (eBay, Amazon, Pet stores, etc.) and just can't seem to find any that run at a reasonable voltage for a reasonable price. Obviously it doesn't have to be anything particularly powerful, but I just can't seem to find any.
Maybe I'm typing the wrong keywords or something?
Either way, could someone please direct me to a pump or suggest somewhere to look? :stuck_out_tongue:
TchnclFl, just search for "washer pump" on e-bay.
Here are some:
http://cgi.ebay.com/ebaymotors/Mercedes-Benz-Windshield-Washer-PUMP-S500-S320-S420_W0QQitemZ370293652813QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item563738bd4d
http://cgi.ebay.com/ebaymotors/Ford-Focus-Windshield-Washer-Pump-Sedan-00-01-02-03-04_W0QQitemZ230403070453QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item35a517d9f5
http://cgi.ebay.com/ebaymotors/Ford-Focus-Windshield-Washer-Pump-Wagon-ZX3-ZX5-00-04_W0QQitemZ230403072409QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item35a517e199
Ahhh thanks! Any idea what voltage these pumps use? Also, I assume it is in fact DC? :stuck_out_tongue:
They are all car window washer pumps. 12V DC.
Since we debate... has anyone found a special type of magnetic valve, that is triggered by pulse.
To explain what I'm looking for: "ordinary" magnetic valves are kept open while current is flowing through. So, keeping this kind of valve open for a while is wery power consuming, especialy if running on a battery. That's why I am looking for a special valve, that requires only a pulse to open, and then another pulse to close. This are used in "real" life (by Claber for example) for wattering sistems...
Regards,
Peter
If anyone's looking for well-priced seeds (herbs, fruits, veggies, etc.), I found a nice seller on eBay:
http://myworld.ebay.com/mazaltov73/
I just ordered some catnip and basil from them, and they combine shipping too. It's 1.75 USD for shipping for unlimited amounts of seeds. It's cool cause most of them are only 99 cents for a couple hundred seeds too!
I know this sounds like I'm the person selling and I'm advertising, but I'm not, I just really like this guy's prices :).
@Odisej: Thanks for the reply about your window set up. Try searching for 'latching solenoid valve' and 'bistable solenoid valve'
A few possibilities:
http://www.betavalve.com/seconda.asp
http://www.giplindia.com/latching-solenoid-valve.htm
Hope that helps
Thanks for this! I didn't know the english term, so I just knew I need to look for a kind of solenoid :slight_smile: I'll try ordering some and then again...rewrite the code :sunglasses:
Regards,
Peter
I updated my source code here: GitHub - nemik/arduinoponics: Arduino code to control a pump for hydroponics purposes.
I put in a relay for AC power to turn some lights on and off as Chicago isn't getting much sun these days.
Right now there is a cron script on the router than turns the lights on every morning at 5:30 and turns them off at 21:00. The toggling of the lights has also been added as a button on the OpenWRT admin menu.
For anyone interested in a system aimed at hydroponic gardening, I've created a project called 'Wireplant'. Pictures, code, schematics, and a full description of features is available at www.wireplant.com
Odisej due you have your code posted some where. I am doing a green house but using car power windows motors and rails to slide the vents open when it gets to hot
Curtiss
I believe my code won't be any good to you, as it isn't written in english and would be extremly hard to understand. Besides, I think I don't even have the hardware part written down anywhere. Too many wires :frowning:
But at the moment I am developing a new version for this spring, but I still need a few weeks to comlete...
any update on this?
I'm considering building either a growth box, or a small greenhouse for growing citrus during the winter here in Germany. Thank you for all the ideas! I want to add something: How about sensing plant growth and health via determination of chlorophyll fluorescence? This should be quite easy. All you need is a strong LED emitting at 425 nm, a photosensor (better a CCD), and a 685 ± 20 nm bandpass filter. The programm would run at night to circumvent disturbance by ambient light. The LED is lit and the CCD records the amount of emitted photons at 685 nm. The more leaves the plants in the growth box produce, the more photons the CCD should record.
Chlorophyll spectrum:
What do you think about this?
Thanks!
Till
PS: I'm a biologist. Ask me anything. :wink:
