Growing array with fscanf data in matlab
I am trying to send a value to an arduino from Matlab and read serial data with fscanf() in matlab from the arduino.
My requirements are that i need to be able to send the data at a specified time interval i.e 20 values persecond at .05 seconds. and i need to be able to graph the incoming data and be able to save it for later use. I will know the length of the array before I start I have read and seen that this can be used to speed up the process.
The problem i am currently having is that each iteration of the loop becomes successively longer which throws the time behavior off more. I believe this to be due to the growing array inside of the loop I have.
x = linspace(0,time1,tosd)';
x1 = amp*sin(x*(2*pi/20)) + offset;
y = zeros(length(x),1);
i = 1;
figure(1);
hold on;
title('Pressure Data');
xlabel('Data Number');
ylabel('Analog Voltage (0-1023)');
t1 = zeros(length(x),1);
figure(2);
hold on;
title('Time to execute task');
xlabel('iteration number');
ylabel('time taken');
while (i<=length(x))
    t2 = tic;
    t = tic;
    fprintf(handles.UltraM,(['<P' num2str(x1(i)) '>']));
    disp((['<P' num2str(x1(i)) '>']));
    y(i) = fscanf(handles.UltraM,'%i');
    figure(1);
    hold on;
    plot(i, y(i), 'b*');
    plot(i, pressure, 'b*');
    drawnow;
    hold off;
 while toc(t) < 0.05
     continue
 end
    t1 = toc(t2);
    figure(2);
    hold on;
    plot(i,t1,'b*');
    drawnow;
    hold off;
    i = i + 1;
end
The last tic toc finction is just used so that i can graphically see the slowdown time.
thank you in advance for any help
