I'm getting the error "Cannot declare variable 'lightOutlet' to be of abstract type 'basicTimerOutletObject'. I'm not sure why the compiler is still thinking that basicTimerOutletObject is an abstract type; as far as I can tell I've defined all the functions which need to be defined in it. I'm using the Eclipse IDE with the Arduino plugin.
The main program file is controller_alpha_04.cpp.
* controller_alpha_04.cpp
#include "controller_alpha_04.h"
#include "OutletObjects.h"
#include "Wire.h"
#include "RTClib.h"
#include "basicTimeFunctionsLib.h"
#include "sensorGrabber.h"
#define LIGHT_PIN 7;
#define PUMP_PIN 8;
RTC_DS1307 RTC;
byte lightPin = LIGHT_PIN;
byte pumpPin = PUMP_PIN;
combinedDataObject combinedData;
sensorGrabber sensorPoller(&combinedData, &RTC);
timeObject _testtimeOn(9,50,0);
timeObject _testtimeOff(10,0,0);
timeObject _testduration(0,0,30);
basicTimerOutletObject lightOutlet;//(lightPin, &combinedData, _testtimeOn, _testtimeOff); <-- Compiler flags error here.
Serial.begin(57600);
Wire.begin();
RTC.begin();
lightOutlet.begin(lightPin, &combinedData);
lightOutlet.set(_testtimeOn, _testtimeOff);
Here's the header file that deals with that object:
* OutletObjects.h
* Created on: Apr 12, 2012
* Author: Sev
#ifndef OUTLETOBJECTS_H_
#define OUTLETOBJECTS_H_
#include "Arduino.h"
#include "timerClasses.h"
class outletObjectInterface
public:
virtual void begin() = 0; // Must be passed the address of the pin it should control in setup.
virtual void evaluate() = 0; // Call to make the outlet evaluate its logic.
virtual void set()= 0;
virtual void print() = 0; // Call to print settings and status to Serial. Prints on a single line, does not <cr>.
void setManualOverride(boolean _state); // Call to manually turn the outlet on or off and prevent evaluation of outlet logic
void freeManualOverride(void); // Call to free the manual override and allow the outlet to return to normal function
boolean isInitialized(void) ;
boolean isSet(void) ;
boolean isReady(void) ;
boolean getOutletPinState(void);
protected:
boolean outletOverrideState;
boolean overrideOn; // True if manual override is on
boolean outletPinState;
byte outletPin;
boolean outletInitialized; // Has the object been initialized? Should be set false by constructor
boolean outletSet; // Has the object been set properly? Should be set false by constructor.
class basicTimerOutletObject : public outletObjectInterface
public:
void begin(byte _pin, combinedDataObject * _data);
void evaluate(void);
void set(timeObject _on, timeObject _off);
void print(void);
basicTimerOutletObject(void);
basicTimerOutletObject(byte _pin, combinedDataObject * _data, timeObject _timeOn, timeObject _timeOff);
protected:
basicTimerObject timer;
combinedDataObject * data;
class basicThermostatOutletObject : public outletObjectInterface // need to add a hysteresis timer.
public:
void set(temperatureObject _target, boolean _invert);
void print(void);
basicThermostatOutletObject(void);
basicThermostatOutletObject(byte _pin, combinedDataObject * _data, temperatureObject _setPoint, boolean _invert);
protected:
temperatureObject setPoint;
int setTemp; // Raw temperature that the thermostat is set to trigger at
boolean invertOperation; // set true if you want the thermostat to kick in if the temperature is above the setpoint, as with an AC.
class timerTimerOutletObject : public outletObjectInterface
public:
virtual void begin(byte _pin, combinedDataObject * _data);
virtual void set(timeObject _on, timeObject _duration);
virtual void evaluate(void);
virtual void print(void);
timerTimerOutletObject(void);
timerTimerOutletObject(byte _pin, combinedDataObject * _data, timeObject _timeOn, timeObject _duration);
protected:
#endif /* OUTLETOBJECTS_H_ */
And here's the cpp file for the above header file:
* OutletObjects.cpp
* Author: Sev
void outletObjectInterface::setManualOverride(boolean _state)
overrideOn = true;
outletOverrideState = _state;
outletPinState = outletOverrideState;
evaluate();
void outletObjectInterface::freeManualOverride(void)
overrideOn = false;
evaluate();
boolean outletObjectInterface::isInitialized(void)
return outletInitialized;
boolean outletObjectInterface::isSet(void)
return outletSet;
boolean outletObjectInterface::isReady(void)
return ( outletInitialized && outletSet);
boolean outletObjectInterface::getOutletPinState(void)
return outletPinState;
void basicTimerOutletObject::begin(byte _pin, combinedDataObject * _data)
outletPin = _pin;
data = _data; // data is a pointer to the main combinedDataObject for the program.
outletInitialized = true;
timer.setDataSource(data);
void basicTimerOutletObject::set(timeObject _on, timeObject _off)
timer.setTimers(_on, _off);
outletSet = true;
void basicTimerOutletObject::evaluate(void)
timer.tick();
if(overrideOn == true)
digitalWrite(outletPin, outletPinState);
return;
outletPinState = timer.getState();
void basicTimerOutletObject::print(void)
if (isReady() == false) { Serial.print("NOT READY"); return;}
timeObject on = timer.getTimeOn();
timeObject off = timer.getTimeOff();
timeObject _now = timer.getcurrenttime();
Serial.print("Time On: ");
on.printTime();
Serial.print(" Time Off: ");
off.printTime();
Serial.print(" Time Now: ");
_now.printTime();
Serial.print(" Outlet is");
if(getOutletPinState() == true) Serial.print("ON");
if(getOutletPinState() == false) Serial.print("OFF");
if(overrideOn == true) Serial.print(" MANUAL OVERRIDE ON");
basicTimerOutletObject::basicTimerOutletObject(void)
outletInitialized = false;
outletSet = false;
basicTimerOutletObject::basicTimerOutletObject(byte _pin, combinedDataObject * _data, timeObject _timeOn, timeObject _timeOff)
outletSet = true;
timer.setTimers(_timeOn, _timeOff);
data = _data;
outletPin = _pin;
void basicThermostatOutletObject::begin(byte _pin, combinedDataObject* _data)
outletPin = _pin;
data = _data;
void basicThermostatOutletObject::set(temperatureObject _target, boolean _invert)
setPoint = _target;
invertOperation = _invert;
outletSet = true;
void basicThermostatOutletObject::evaluate(void)
if(isReady() == false) { Serial.println("ERROR, NOT READY"); return;}
if(overrideOn == true) { outletPinState = outletOverrideState; digitalWrite(outletPin, outletPinState); return;}
if(invertOperation == false)
if(data->getTempRaw() < setPoint.getTempRaw()) outletPinState = true; // Some basic hysteresis; this if statement could be accomplished without with "outletPinState = (data->getTempRaw() < setTemp.getTempRaw())
if(data->getTempRaw() > setPoint.getTempRaw()) outletPinState = false;
if(data->getTempRaw() < setPoint.getTempRaw()) outletPinState = false;
if(data->getTempRaw() > setPoint.getTempRaw()) outletPinState = true;
basicThermostatOutletObject::basicThermostatOutletObject(void)
outletSet = false;
basicThermostatOutletObject::basicThermostatOutletObject(byte _pin, combinedDataObject * _data, temperatureObject _setPoint, boolean _invert)
outletSet = true;
outletSet = true;
setPoint = _setPoint;
outletPin = _pin;
data = _data;
void basicThermostatOutletObject::print(void)
Serial.print("Therm Setpoint:");
Serial.print(setPoint.getTempF(), 2);
Serial.print("*F Invert:");
if(invertOperation == true) Serial.print("On");
if(invertOperation == false) Serial.print("Off");
Serial.print(" Current Temp:");
Serial.print(data->getTempF(), 2);
Serial.print("*F Outlet is ");
(removed timerTimer object stuff to save space)
