gsm based led matrix display , GSM interfacing problem
hi
sir i am trying to merge the GSM code with the source code of led matrix display using arduino, and i dont know how to do it.
both codes are given below:
GSM code:
  • Author@ExploreEmbedded
  • Example to Send messages Interactively using GSM SIM800L
  • LIBRARY CREDITS:
  • Thanks to Cristian Steib(steibkhriz@gmail.com) for the library.
  • PINOUT:
  • | ARDUINO UNO >>> SIM800L |
  • GND >>> GND
  • RX 10 >>> TX
  • TX 11 >>> RX
  • RESET 2 >>> RST
#include <Sim800L.h>
#include <SoftwareSerial.h> //is necesary for the library!!
Sim800L Sim800L; //to declare the library
char text[161]=""; //buffer to store message
char number[11]=""; //phone number to send message
int cnt;
bool error; //to catch the response of sendSms
void setup(){
Sim800L.begin(); // initializate the library.
void loop(){
//Read the Number
Serial.print("\nEnter 10 digit Phone Number:c");
while(Serial.available()<=0);
cnt = Serial.readBytesUntil(’\n’,number, 11);
number[cnt] = ‘\0’;
Serial.println(number);
//clear the serial input buffer so that no typed characters are pending
delay(1000); //delay required before clearing the input buffer
while(Serial.available()>0) //clear buffer
Serial.read();
//Read the Message to be sent
Serial.print(“Enter Message:”);
cnt = Serial.readBytesUntil(’\n’,text, 160);
text[cnt] = ‘\0’;
Serial.println(text);
Serial.read();
//Send the message and display the status
error = Sim800L.sendSms(number,text);
if(error)
Serial.println(“Error Sending Message”);
Serial.println(“Message Sent Successfully!”);
arduino code for led matrix:
  • Arduino code to display scrolling characters on 6 or more 8x8 LED matrix. *
  • The no: of matrices can be increased with a small change in code. *
  • Comments are given in each statement for editing. *
  • Circuit designed and program coded by Prasanth K S *
  • Contact : Prasanthksubash@gmail.com *
char msg ="A B C D E F G H I J K L M N O P Q R S T U V W X Y Z ";//Change the text here.
int scrollspeed=5;//Set the scroll speed ( lower=faster)
int x;
int y;
int latchPin1 = 5; //Arduino pin connected to blue 12 RCLK of 74HC595
int clockPin1 = 6; //Arduino pin connected to green 11 SRCLK of 74HC595
int dataPin1 = 7; //Arduino pin connected to violet 14 SER of 74HC595
//-- Rows (Positive Anodes) –
int latchPin2 = 9; //Arduino pin connected to yellow Latch 12 RCLK of 74HC595
int clockPin2 = 10; //Arduino pin connected to white Clock 11 SRCLK of 74HC595
int dataPin2 = 8;
//BITMAP
//Bits in this array represents one LED of the matrix
// 8 is # of rows, 6 is # of LED matrices
byte bitmap[8][10];
int numZones = sizeof(bitmap) / 8; // One Zone refers to one 8 x 8 Matrix ( Group of 8 columns)
int maxZoneIndex = numZones-1;
int numCols = numZones * 8;
//FONT DEFENITION
byte alphabets[8] = {
{0,0,0,0,0},//@ as SPACE
//{8,28,54,99,65},//<<
{31, 36, 68, 36, 31},//A
{127, 73, 73, 73, 54},//B
{62, 65, 65, 65, 34},//C
{127, 65, 65, 34, 28},//D
{127, 73, 73, 65, 65},//E
{127, 72, 72, 72, 64},//F
{62, 65, 65, 69, 38},//G
{127, 8, 8, 8, 127},//H
{0, 65, 127, 65, 0},//I
{2, 1, 1, 1, 126},//J
{127, 8, 20, 34, 65},//K
{127, 1, 1, 1, 1},//L
{127, 32, 16, 32, 127},//M
{127, 32, 16, 8, 127},//N
{62, 65, 65, 65, 62},//O
{127, 72, 72, 72, 48},//P
{62, 65, 69, 66, 61},//Q
{127, 72, 76, 74, 49},//R
{50, 73, 73, 73, 38},//S
{64, 64, 127, 64, 64},//T
{126, 1, 1, 1, 126},//U
{124, 2, 1, 2, 124},//V
{126, 1, 6, 1, 126},//W
{99, 20, 8, 20, 99},//X
{96, 16, 15, 16, 96},//Y
{67, 69, 73, 81, 97},//Z
pinMode(latchPin1, OUTPUT);
pinMode(clockPin1, OUTPUT);
pinMode(dataPin1, OUTPUT);
pinMode(latchPin2, OUTPUT);
pinMode(clockPin2, OUTPUT);
pinMode(dataPin2, OUTPUT);
//Clear bitmap
for (int row = 0; row < 8; row++) {
for (int zone = 0; zone <= maxZoneIndex; zone++) {
bitmap[row][zone] = 0;
//FUNCTIONS
// Displays bitmap array in the matrix
void RefreshDisplay()
int rowbit = 1 << row;
digitalWrite(latchPin2, LOW);//Hold latchPin LOW for transmitting data
shiftOut(dataPin2, clockPin2, MSBFIRST, rowbit); //Transmit data
//Start sending column bytes
digitalWrite(latchPin1, LOW);//Hold latchPin LOW for transmitting data
//Shift out to each matrix
for (int zone = maxZoneIndex; zone >= 0; zone–)
shiftOut(dataPin1, clockPin1, MSBFIRST, bitmap[row][zone]);
//flip both latches at once to eliminate flicker
digitalWrite(latchPin1, HIGH);//Return the latch pin 1 high to signal chip
digitalWrite(latchPin2, HIGH);//Return the latch pin 2 high to signal chip
//Wait
delayMicroseconds(700);
// Converts row and colum to bitmap bit and turn it off/on
void Plot(int col, int row, bool isOn)
int zone = col / 8;
int colBitIndex = x % 8;
byte colBit = 1 << colBitIndex;
if (isOn)
bitmap[row][zone] = bitmap[y][zone] | colBit;
bitmap[row][zone] = bitmap[y][zone] & (~colBit);
// Plot each character of the message one column at a time, updated the display, shift bitmap left.
void XProcess()
for (int charIndex=0; charIndex < (sizeof(msg)-1); charIndex++)
int alphabetIndex = msg[charIndex] - ‘@’;
if (alphabetIndex < 0) alphabetIndex=0;
//Draw one character of the message
// Each character is 5 columns wide, loop two more times to create 2 pixel space betwen characters
for (int col = 0; col < 6; col++)
// Set the pixel to what the alphabet say for columns 0 thru 4, but always leave columns 5 and 6 blank.
bool isOn = 0;
if (col<5) isOn = bitRead( alphabets[alphabetIndex][col], 7-row ) == 1;
Plot( numCols-1, row, isOn); //Draw on the rightmost column, the shift loop below will scroll it leftward.
for (int refreshCount=0; refreshCount < scrollspeed; refreshCount++)
RefreshDisplay();
//Shift the bitmap one column to left
for (int row=0; row<8; row++)
for (int zone=0; zone < numZones; zone++)
//This right shift would show as a left scroll on display because leftmost column is represented by least significant bit of the byte.
bitmap[row][zone] = bitmap[row][zone] >> 1;
// Shift over lowest bit from the next zone as highest bit of this zone.
if (zone < maxZoneIndex) bitWrite(bitmap[row][zone], 7, bitRead(bitmap[row][zone+1],0));
XProcess();
in the attachment below… i merge the two codes but its not working…
testing_1.ino (6.01 KB)
hi
GSM code:
  • LIBRARY CREDITS:
  • PINOUT:
  • GND >>> GND
  • RX 10 >>> TX
  • TX 11 >>> RX
  • RESET 2 >>> RST
int cnt;
void setup(){
void loop(){
//Read the Number
number[cnt] = ‘\0’;
Serial.read();
text[cnt] = ‘\0’;
Serial.read();
if(error)
int x;
int y;
int dataPin2 = 8;
//BITMAP
byte bitmap[8][10];
//FONT DEFENITION
//Clear bitmap
//FUNCTIONS
//Wait
int zone = col / 8;
if (isOn)
void XProcess()
bool isOn = 0;
RefreshDisplay();
XProcess();
// Per.
If you have requirements for the resulting program, you forgot to include them, and you forgot to include your attempt to produce that program, and you forgot to say what the problems are.
@waheed, please do not cross-post. Threads merged.
