GSM construction using the following arduino components
:sunglasses:
Project components :
1 arduino UNO + 1 gsm shield with built in antenna + two sim cards (properly working) + IDE environment lastest version
actions : send sms & receive sms project in Arduino
Problems : "send sms" does not show messages on test gsm (PIN code correctly entered in IDE). Code properly working ! GSM shield powered by USB cable ( shortage of suffcicient powersupply to send an sms ?) Built in antenna on GSM shield not long or powerful enough ?!
Anybody who tried this configuration already ?
Used the following code from the GSM library : The Code works fine
SMS sender
This sketch, for the Arduino GSM shield,sends an SMS message
that you send it through the serial monitor. To make it work,
open the serial monitor, and when you see the READY message,
type a message to send. Make sure the serial monitor is set
to send a newline when you press return.
Circuit:
  • GSM shield
created 25 Feb 2012
by Tom Igoe
This example is in the public domain.
// libraries
#include <GSM.h>
// entered correctly the Pin code !
#define PINNUMBER ""
// initialize the library instance
GSM gsmAccess; // include a 'true' parameter for debug enabled
GSM_SMS sms;
// initialize serial communications
Serial.println("SMS Messages Sender");
// connection state
boolean notConnected = true;
// Start GSM shield
// If your SIM has PIN, pass it as a parameter of begin() in quotes
while(notConnected)
if(gsmAccess.begin(PINNUMBER)==GSM_READY)
notConnected = false;
Serial.println("Not connected");
Serial.println("GSM initialized");
Serial.print("Enter a mobile number: ");
char remoteNumber[20]; // telephone number to send sms
readSerial(remoteNumber);
Serial.println(remoteNumber);
// sms text
Serial.print("Now, enter SMS content: ");
char txtMsg[200];
readSerial(txtMsg);
Serial.println("SENDING");
Serial.println("Message:");
Serial.println(txtMsg);
// send the message
sms.beginSMS(remoteNumber);
sms.print(txtMsg);
sms.endSMS();
Serial.println("\nCOMPLETE!\n");
Read input serial
int readSerial(char result[])
int i = 0;
while(1)
while (Serial.available() > 0)
char inChar = Serial.read();
if (inChar == '\n')
result = '\0';
  • Serial.flush();*
  • return 0;*
  • if(inChar!='\r')*
    _ result = inChar;_
    * i++;*
    Related Searches :
    Problem: the message(s) sent by the GSM shield ( IDE interface) do not arrive instantly on the test gsm.
    *However when I unplug the SIM card from the GSM shield and plug it in in a mobile phone... The messages do appear. *
Get over it.
