GSM/GPRS/GPS Tracker
Hi folks! I want to share my code in this community. This is a tracker with Arduino Duemilanove, GSM/GPRS Shield with SIM900 module by Open Electronics and a generic C3-370C GPS module.
Hope this helps someone!.
Greetings from Argentina.
:slight_smile:
Add ‚Äúlisten‚ÄĚ method in GSM class.
add to gsm.cpp
void GSM::listen(void)
     _cell.listen();
add to gsm.h
void listen();
//Matias Frith rmfrith@hotmail.com
//31 Dic 2012
//#include "SIM900.h"
#include <SoftwareSerial.h>
#include <string.h>
#include "sms.h"
#include <MemoryFree.h>
SMSGSM sms;
// declare pins and set up the serial port for gps
#define rxPin 2 //rx pin in gps connection
#define txPin 3 //tx pin in gps connection
SoftwareSerial gps = SoftwareSerial(rxPin, txPin);
// gps variables
boolean gps_started=false;
boolean invalid_sentence=true;
int comas;
byte byteGPS = 0;
int i = 0;
int h = 0;
int d = 0;
int dpos = 0;
char sentence[10][10];
char url[100];
String strurl;
boolean returnurl;
char GPS_RMC[100]="";
// gsm variables
String text;
String nro;
byte sms_reply;
byte reply_saldo;
int pos;
boolean gsm_started=false;
char position;
char smsbuffer[100];
char n[12];
void setup(){
  pinMode(rxPin, INPUT);
  pinMode(txPin, OUTPUT);
  //***STARTING GPS***
  Serial.print("Inicializando GPS... ");
  gps.begin(9600);
  //SET GPS TO COLD START MODE
  //gps.write("$PSRF101,0,0,0,000,0,0,12,4*10");
  //delay(1000);
  //SET NMEA OPTIONS
  gps.write("$PSRF201,NMEA9600,NULL38400,GGA1,GLL0,GSA0,GSV0,RMC1,VTG0,USER0*0D");
  returnurl=getURL();
  while (!returnurl){
     Serial.println("[FAIL]");
     delay(5000);
     returnurl=getURL();
  Serial.println("[OK]");
  gps_started=true;
  //***STARTING GSM***
  Serial.print("Inicializando GSM... ");
  while(!gsm.begin(2400)){
    delay(5000);
  gsm_started=true;
  if((gps_started)&&(gsm_started)){
    Serial.println("Sistema inicializado");
    Serial.println("Sistema no inicializado.");
void loop(){
  gps.listen();
  returnurl=getURL();
  if (returnurl){
    Serial.print(strurl);
    gsm.listen();
    Serial.print(" RAM:");
    Serial.println(freeMemory());
    if(gsm_started){
      position=sms.IsSMSPresent(SMS_ALL);
      if(position){
        sms.GetSMS(position,n,smsbuffer,100);
          Serial.print("Mensaje recibido de ");
          Serial.print(n);
          Serial.print(": ");
          Serial.println(smsbuffer);
          nro=n;
          text=smsbuffer;
          sms.DeleteSMS(position);
        if (nro.indexOf("444")>=0){
          sms.SendSMS("+05401164906xxx",smsbuffer);
        } else if (nro=="") {
          sms_reply=1;
         if (text.indexOf("GET POS")>=0){
          text=strurl;
          sms_reply=1;
        } else if (text.indexOf("SALDO")>=0){
          saldo();
          sms_reply=0;
          //text="No se interpreto el comando.";
          sms_reply=0;
        if (sms_reply) {
          sms_reply=0;
          text.toCharArray(smsbuffer,100);
          Serial.print("Enviando posicion al solicitante: ");
          Serial.print(smsbuffer);
          sms.SendSMS(n,smsbuffer);
     Serial.println("Error al obtener coordenadas");
void saldo(){
  sms.SendSMS("444","");
boolean getURL(){
  byteGPS = 0;
  while(1==1){
  byteGPS = gps.read();
  delay(1);
  //Serial.write(byteGPS);
    if(byteGPS=='R'){
      delay(1);
        if(byteGPS=='M'){
          delay(1);
            if(byteGPS=='C'){
  GPS_RMC[0]='
¬†GPS_RMC[1]=‚ÄėG‚Äô;
¬†GPS_RMC[2]=‚ÄėP‚Äô;
¬†GPS_RMC[3]=‚ÄėR‚Äô;
¬†GPS_RMC[4]=‚ÄėM‚Äô;
¬†GPS_RMC[5]=‚ÄėC‚Äô;
 i = 6;
 comas=0;
¬†while((byteGPS != ‚Äė*‚Äô)&&(i<=62)){
       delay(10);
   //si recibo dos comas consecutivas faltan datos, la trama no se tiene en cuenta y se descarta
   if(byteGPS == 44) {
     comas++;
     if (comas > 1){
       returnurl=false;
     comas=0;
     returnurl=true;
   GPS_RMC[i]=byteGPS;
   i++;
 // delay(10);
if(returnurl){
 h = 0;
 d = 0;
 //Serial.println();
 while(h<strlen(GPS_RMC)){
   //Serial.write(GPS_RMC[h]);
     if(GPS_RMC[h] == 44) {
       dpos = 0;
       d++;
¬† ¬† ¬† ¬†sentence[d][dpos]=‚Äė0‚Äô;
       sentence[d][dpos]=GPS_RMC[h];
       dpos++;
   h++;
char g_lng[4]={sentence[5][0],sentence[5][1],sentence[5][2],’\0’};
 char m_lng[8]={sentence[5][3],sentence[5][4],’.’,sentence[5][6],sentence[5][7],sentence[5][8],sentence[5][9],’\0’};
 char g_lat[4]={sentence[3][0],sentence[3][1],’\0’};
 char m_lat[8]={sentence[3][2],sentence[3][3],’.’,sentence[3][5],sentence[3][6],sentence[3][7],sentence[3][8],’\0’};
//convert array to float
 double lngg=atof(g_lng);
 double latg=atof(g_lat);
 double lngm=atof(m_lng);
 double latm=atof(m_lat);
 //convert to decimal
 double lngmd=lngg+(lngm/60);
 double latmd=latg+(latm/60);
 //convert float to long
 long lngmdl=lngmd100000;
 long latmdl=latmd
100000;
 //convert to array again
 char lngmdc[10];
 char latmdc[10];
 ltoa(lngmdl,lngmdc,10);
 ltoa(latmdl,latmdc,10);
 //drag 4 decimal characters to the right, and insert the floating point to lat and lng
 for(i=6;i>=3;i=i-1){
   lngmdc[i]=lngmdc[i-1];
   latmdc[i]=latmdc[i-1];
 lngmdc[2]=’.’;
 latmdc[2]=’.’;
 //convert velocity to float, then to kmh   [1 knots = 1.85200 kmh]
 double velkmh=atof(sentence[7])*1.85200;
 if (velkmh<10){
   velkmh=0;
 char velkmh_c[10];
 ltoa(velkmh,velkmh_c,10);
 double course=atof(sentence[8]);
 char course_c[6];
 ltoa(course,course_c,10);
 //concatenate results!
¬†strcpy(url, ‚Äú‚ÄĚ);
¬†strcpy(url, ‚Äúhttp://maps.google.com/maps?q=‚ÄĚ);
 strcat(url, sentence[6]);
 strcat(url, lngmdc);
¬†strcat(url, ‚Äú,‚ÄĚ);
 strcat(url, sentence[4]);
 strcat(url, latmdc);
 strcat(url, " Spd: “);
 strcat(url, velkmh_c);
¬†strcat(url, " Kmh‚ÄĚ);
 strcat(url, " Hdg: “);
 strcat(url, course_c);
¬†strcat(url, " Deg‚ÄĚ);
strurl=url;
return returnurl;
thanks for sharing!
Muchas gracias por compartir!
