GSM/GPRS SHIELD
Bonjour à tous, j’ai un problème depuis quelques temps, je n’arrive pas à connecter mon arduino UNO équipé actuellement d’un shield GSM/GPRS au GPRS.
J’utilise une carte sim SFR avec forfait DATA (c’est mieux :wink: ) sur laquelle j’ai désactivé le code pin pour faciliter la manipulation.
voici mon programme, il est actuellement bloqué à la ligne 25.
int8_t answer;
int onModulePin= 2;
char data[512];
int data_size;
char aux_str[100];
char aux;
int x = 0;
void setup(){
    pinMode(onModulePin, OUTPUT);
    Serial.println("Starting...");
    power_on();
    delay(3000);
    while (sendATcommand2("AT+CREG?", "+CREG: 0,1", "+CREG: 0,5", 2000) == 0);
    sendATcommand("AT+SAPBR=3,1,\"Contype\",\"GPRS\"", "OK", 2000);
    sendATcommand("AT+SAPBR=3,1,\"APN\",\"sl2sfr\"", "OK", 2000);
    sendATcommand("AT+SAPBR=3,1,\"USER\",\"\"", "OK", 2000);
    sendATcommand("AT+SAPBR=3,1,\"PWD\",\"\"", "OK", 2000);
    while (sendATcommand("AT+SAPBR=1,1", "OK", 20000) == 0)
        delay(5000);
    Serial.println("Here we go !...");
void loop(){
    // Initializes HTTP service
    answer = sendATcommand("AT+HTTPINIT", "OK", 10000);
    if (answer == 1)
	    Serial.println("HTTPInit...");
        // Sets CID parameter
        answer = sendATcommand("AT+HTTPPARA=\"CID\",1", "OK", 5000);
        if (answer == 1)
		    Serial.println("HTTPCid...");
            // Sets url
            answer = sendATcommand("AT+HTTPPARA=\"URL\",\"www.example.com\"", "OK", 5000);
            if (answer == 1)
			    Serial.println("HTTPUrl...");
                // Starts GET action
                answer = sendATcommand("AT+HTTPACTION=0", "+HTTPACTION:0,200", 10000);
                if (answer == 1)
				    Serial.println("HTTPAction...");
                    x=0;
                    do{
                        sprintf(aux_str, "AT+HTTPREAD=%d,100", x);
                        if (sendATcommand2(aux_str, "+HTTPREAD:", "ERROR", 30000) == 1)
						    Serial.println("HTTPread...");
                            data_size = 0;
                            while(Serial.available()==0);
                            aux = Serial.read();
                            do{
                                data_size *= 10;
                                data_size += (aux-0x30);
                            }while(aux != 0x0D);
                            Serial.print("Data received: ");
                            Serial.println(data_size);
                            if (data_size > 0)
                                while(Serial.available() < data_size);
                                Serial.read();
                                for (int y = 0; y < data_size; y++)
                                    data[x] = Serial.read();
                                    x++;
                                data[x] = '\0';
                                Serial.println("Download finished");
                        else if (answer == 2)
                            Serial.println("Error from HTTP");
                            Serial.println("Error getting the url");
                            data_size = 0;
                        sendATcommand("", "+HTTPACTION:0,200", 20000);
                    }while (data_size > 0);
                    Serial.println(data);
                Serial.println("Error setting the url");
            Serial.println("Error setting the CID");
        Serial.println("Error initializating");
    sendATcommand("AT+HTTPTERM", "OK", 5000);
    delay(5000);
void power_on(){
    Serial.println("Pre power...");
    uint8_t answer=0;
    // checks if the module is started
    answer = sendATcommand("AT", "OK", 2000);
    if (answer == 0)
        // power on pulse
        digitalWrite(onModulePin,HIGH);
        delay(3000);
        digitalWrite(onModulePin,LOW);
        // waits for an answer from the module
        while(answer == 0){
            // Send AT every two seconds and wait for the answer
	    Serial.println("Post power...");
int8_t sendATcommand(char* ATcommand, char* expected_answer1, unsigned int timeout){
    uint8_t x=0,  answer=0;
    char response[100];
    unsigned long previous;
    memset(response, '\0', 100);    // Initialize the string
    delay(100);
    while( Serial.available() > 0) Serial.read();    // Clean the input buffer
    Serial.println(ATcommand);    // Send the AT command
        x = 0;
    previous = millis();
    // this loop waits for the answer
    do{
        if(Serial.available() != 0){
            response[x] = Serial.read();
            x++;
            // check if the desired answer is in the response of the module
            if (strstr(response, expected_answer1) != NULL)
                answer = 1;
        // Waits for the asnwer with time out
    while((answer == 0) && ((millis() - previous) < timeout));
    return answer;
int8_t sendATcommand2(char* ATcommand, char* expected_answer1,
char* expected_answer2, unsigned int timeout){
    char response[100];
    delay(100);
        x = 0;
    do{
            x++;
            // check if the desired answer 1 is in the response of the module
                answer = 1;
            // check if the desired answer 2 is in the response of the module
            if (strstr(response, expected_answer2) != NULL)
                answer = 2;
    }while((answer == 0) && ((millis() - previous) < timeout));
    return answer;
Le programme en lui-même ne comporte pas d’erreurs, c’est simplement la conection au GPRS qui est défaillante et je n’arrive pas à savoir pourquoi ]:slight_smile:
Merci d’avance :roll_eyes:
Valentin_RCHB:
Bonjour à tous, j'ai un problème depuis quelques temps, je n'arrive pas à connecter mon arduino UNO
bonjour
C'est donc qu'avant tu a déjà reussi ? , (avec une autre carte/operateur ? ) 8)
