GSM keeps sending SMS (problem in Arduino code)
I have an Arduino Uno that is interfaced with GSM. I wrote a code which makes the GSM send SMS if it receives an SMS with letter (‘s’). The problem is when the GSM received letter ‘s’ it keeps sending multiple SMSs rather than one.
Anyone can solve this problem ??
Here is the code that I wrote it.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(7, 8); // Rx,Tx
String textMessage;
String message;
  mySerial.begin(9600);   // Setting the baud rate of GSM Module
  Serial.begin(9600);    // Setting the baud rate of Serial Monitor (Arduino)
  delay(20000); // it should be 20000 to connect gsm to network
   Serial.print("SIM900 ready...");
  // AT command to set SIM900 to SMS mode
  mySerial.print("AT+CMGF=1\r");
  // Set module to send SMS data to serial out upon receipt
  mySerial.print("AT+CNMI=2,2,0,0,0\r");
if(mySerial.available()>0){
    textMessage = mySerial.readString();
    Serial.print(textMessage);
     if(textMessage.indexOf("s")>=0){
      message= "led is on";
    SendMessage(message);
    textMessage = "";
 void SendMessage(String message)
  mySerial.println("AT+CMGF=1");    //Sets the GSM Module in Text Mode
  delay(1000);  // Delay of 1000 milli seconds or 1 second
  mySerial.println("AT+CMGS=\"+966554942736\"\r"); // Replace x with mobile number
  delay(2000);
  mySerial.println(message);// The SMS text you want to send
  delay(2000);
  mySerial.println((char)26);// ASCII code of CTRL+Z
  delay(5000);
you should make sure you read all the bytes in the buffer for the GSM serial
How to make sure that I read all the bytes in the buffer for the GSM serial
if (Serial.available( ))
aChar = Serial.read();
