GSM library and Seeedstudio gprs 2.0 shield
Hi all.
This question has been touched before on the internet, but I haven’t found any real solution yet.
The thing is that I bought a Seeedstudio GPRS 2.0 shield, and I want to use it as a webserver (a very simple one). I have successfully connected to my APN and the internet as well as doing regular http requests. That’s all good, but I’m during AT commands directly, and I don’t think my initial GPRS connection sequence is robust enough. Therefor I want to use the Arduino GSM library instead. When I read the documentation on that library, it’s clear that it’s developed for the official Arduino GSM shield. As I read it, they don’t use the same chip (which may be the party killer), and they use different pins for serial communication. Changing the serial pins is easy (http://arduino.cc/en/Guide/GSMShieldLeonardoMega - see bottom). So, it all comes down to a question.
Have any of you succeeded in using the GSM library with the Seeedstudio 2.0 GPRS shield and how did you do it?
Best regards
Lasse Vestergaard
I dont have the Seeedstudio GPRS 2.0, and use a EFCOM GSM/GPRS shield that uses the a different chipset. The GSM lib and examples that come with the Arduino IDE work with some small modifications. Your mileage may vary.
ibbernik: Hi all.
This question has been touched before on the internet, but I haven't found any real solution yet.
The thing is that I bought a Seeedstudio GPRS 2.0 shield, and I want to use it as a webserver (a very simple one). I have successfully connected to my APN and the internet as well as doing regular http requests. That's all good, but I'm during AT commands directly, and I don't think my initial GPRS connection sequence is robust enough. Therefor I want to use the Arduino GSM library instead. When I read the documentation on that library, it's clear that it's developed for the official Arduino GSM shield. As I read it, they don't use the same chip (which may be the party killer), and they use different pins for serial communication. Changing the serial pins is easy (http://arduino.cc/en/Guide/GSMShieldLeonardoMega - see bottom). So, it all comes down to a question.
Best regards
Lasse Vestergaard
Great. Could you maybe reveal which small modifications you had to do?
Regards
Lasse Vestergaard
