i got a gsm sheild
i download the library on that page and installed it by the(add .zip library) ran a example code it it would not even compile.
the first error i got was about the WProgram.h. i fixed it by going into the library and modified the GSM_Shield.h and GSM_Shield.cpp. i changed the WProgram.h to arduino.h
than when i fixed the first problem i compiled the example sketch and it came a WConstants.h error up. I went into the library again and modified the NewSoftSerial.cpp (the .h file didnt have a WConstants.h) to arduino.h
and after i did this, this came up than i collapsed
Arduino: 1.8.5 (Windows 7), Board: "Arduino/Genuino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Linwood Corp Sales\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10805 -build-path C:\Users\LINWOO~1\AppData\Local\Temp\arduino_build_233335 -warnings=none -build-cache C:\Users\LINWOO~1\AppData\Local\Temp\arduino_cache_573967 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Linwood Corp Sales\Documents\Arduino\libraries\GSM_Shield\examples\GSM_Shield_Test\GSM_Shield_Test.pde
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Linwood Corp Sales\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10805 -build-path C:\Users\LINWOO~1\AppData\Local\Temp\arduino_build_233335 -warnings=none -build-cache C:\Users\LINWOO~1\AppData\Local\Temp\arduino_cache_573967 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Linwood Corp Sales\Documents\Arduino\libraries\GSM_Shield\examples\GSM_Shield_Test\GSM_Shield_Test.pde
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\LINWOO~1\AppData\Local\Temp\arduino_build_233335\sketch\GSM_Shield_Test.pde.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Users\Linwood Corp Sales\Documents\Arduino\libraries\GSM_Shield" "C:\Users\LINWOO~1\AppData\Local\Temp\arduino_build_233335\sketch\GSM_Shield_Test.pde.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Users\Linwood Corp Sales\Documents\Arduino\libraries\GSM_Shield" "C:\Users\Linwood Corp Sales\Documents\Arduino\libraries\GSM_Shield\GSM_Shield.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Users\Linwood Corp Sales\Documents\Arduino\libraries\GSM_Shield" "C:\Users\Linwood Corp Sales\Documents\Arduino\libraries\GSM_Shield\NewSoftSerial.cpp" -o "nul"
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Users\Linwood Corp Sales\Documents\Arduino\libraries\GSM_Shield" "C:\Users\LINWOO~1\AppData\Local\Temp\arduino_build_233335\sketch\GSM_Shield_Test.pde.cpp" -o "C:\Users\LINWOO~1\AppData\Local\Temp\arduino_build_233335\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\LINWOO~1\AppData\Local\Temp\arduino_build_233335\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Users\Linwood Corp Sales\Documents\Arduino\libraries\GSM_Shield" "C:\Users\LINWOO~1\AppData\Local\Temp\arduino_build_233335\sketch\GSM_Shield_Test.pde.cpp" -o "C:\Users\LINWOO~1\AppData\Local\Temp\arduino_build_233335\sketch\GSM_Shield_Test.pde.cpp.o"
In file included from C:\Users\Linwood Corp Sales\Documents\Arduino\libraries\GSM_Shield/GSM_Shield.h:11:0,
from C:\Users\Linwood Corp Sales\Documents\Arduino\libraries\GSM_Shield\examples\GSM_Shield_Test\GSM_Shield_Test.pde:14:
C:\Users\Linwood Corp Sales\Documents\Arduino\libraries\GSM_Shield/NewSoftSerial.h:71:16: error: conflicting return type specified for 'virtual void NewSoftSerial::write(uint8_t)'
virtual void write(uint8_t byte);
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Stream.h:26:0,
from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:29,
from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:232,
from C:\Users\LINWOO~1\AppData\Local\Temp\arduino_build_233335\sketch\GSM_Shield_Test.pde.cpp:1:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Print.h:51:20: error: overriding 'virtual size_t Print::write(uint8_t)'
virtual size_t write(uint8_t) = 0;
Using library GSM_Shield in folder: C:\Users\Linwood Corp Sales\Documents\Arduino\libraries\GSM_Shield (legacy)
exit status 1
Error compiling for board Arduino/Genuino Uno.
