GSM MODULE-How to determine Valid center!
i have made one project that controlls the relay through GSM-SIM900A and Arduino UNO.
I made one program and its work satisfactory.
#include <SoftwareSerial.h>
SoftwareSerial GPRS(10, 11);
String textMessage;
String relayState = "LOW";
const int relay = 4;
const uint8_t switchPin = 2;
const bool switchOn  = false;     // using INPUT_PULLUP
const bool switchOff = true;
bool lastState = switchOff;
bool newState;
int joystick[1];
  pinMode(relay, OUTPUT);
  /*digitalWrite(relay, HIGH);*/
  pinMode ( switchPin, INPUT_PULLUP );
  GPRS.begin(9600);
  GPRS.println("AT+CMGF=1");
  GPRS.print("AT+CNMI=2,2,0,0,0\r");
  delay(100);
  joystick[0] = digitalRead(switchPin);
  newState = joystick[0];
  if (newState == switchOn and lastState == switchOff)
    sendSMS();
  lastState = newState;
  if (GPRS.available() > 0) {
    textMessage = GPRS.readString();
    Serial.print(textMessage);
    recvSMS();
    delay(10);
void recvSMS() {
  if (textMessage.indexOf("on") >= 0) {
    // Turn on relay and save current state
    relayState = "on";
    Serial.println("Relay set to ON");
    textMessage = "";
  if (textMessage.indexOf("off") >= 0) {
    // Turn off relay and save current state
    digitalWrite(relay, LOW);
    relayState = "off";
    Serial.println("Relay set to OFF");
    textMessage = "";
if(textMessage.indexOf("state")>=0){
    String message = "relay is " + relayState;
    sendSMS(message);
    Serial.println("relay state resquest");
    textMessage = "";
void sendSMS() {
  Serial.println("Switch was turned ON ");
  GPRS.println("AT+CMGS=\"+917987553768\"");
  GPRS.println ("Switch was turned ON");
  GPRS.write( 0x1a ); // ctrl+Z character
void sendSMS(String  message){
  Serial.println(message);
  GPRS.println(message);
  GPRS.write( 0x1a );
how can i insert valid sender in this program for determine the phone number which sent the incoming message for actuating relays.
could you please help.
