GSM Module - SIM800l and NEO-6M Gps module arduino code not working together
#include <SoftwareSerial.h>
#include <AltSoftSerial.h>
#include <TinyGPS++.h>
//sender phone number with country code
const String PHONE = "+2557688276xx";
#define ignition_switch 4
#define ignition_sensor A0
//GSM Module RX pin to Arduino 10
//GSM Module TX pin to Arduino 11
#define rxPin 11
#define txPin 10
SoftwareSerial sim800(rxPin, txPin);
//GPS Module RX pin to Arduino 9
//GPS Module TX pin to Arduino 8
#define rxPin 8
#define txPin 9
AltSoftSerial neogps;
TinyGPSPlus gps;
String sms_status, sender_number, received_date, msg;
boolean ignition_status = false;
boolean tracking_status = false;
boolean reply_status = true; //not completely implemented
boolean anti_theft = false;
unsigned long previousMillis = 0;
long interval = 60000;
  delay(7000);
  //Serial.println("Arduino serial initialize");
  sim800.begin(9600);
  neogps.begin(9600);
  //Serial.println("neogps Software serial initialize");
  //delay(1000);
  pinMode(ignition_switch, OUTPUT);
  pinMode(ignition_sensor, INPUT);
  sms_status = "";
  sender_number = "";
  received_date = "";
  msg = "";
  sim800.print("AT+CMGF=1\r"); //SMS text mode
  //sendATcommand("AT+CSCLK=2", "OK", 1000);
  ignition_status = getIgnitionStatus();
  if (tracking_status == true && ignition_status == true) {
    if (currentMillis - previousMillis > interval) {
      sendGpsToServer();
  if (anti_theft == true && ignition_status == true) {
    digitalWrite(ignition_switch, HIGH);
  while (sim800.available()) {
    parseData(sim800.readString());
  while (Serial.available())  {
    sim800.println(Serial.readString());
void parseData(String buff) {
  Serial.println(buff);
  unsigned int len, index;
  index = buff.indexOf("\r");
  buff.remove(0, index + 2);
  buff.trim();
  if (buff != "OK") {
    index = buff.indexOf(":");
    String cmd = buff.substring(0, index);
    cmd.trim();
    //Serial.println(buff);
    if (cmd == "+CMTI") {
      //get newly arrived memory location and store it in temp
      //temp = 4
      index = buff.indexOf(",");
      String temp = buff.substring(index + 1, buff.length());
      temp = "AT+CMGR=" + temp + "\r";
      //AT+CMGR=4 i.e. get message stored at memory location 4
      sim800.println(temp);
    else if (cmd == "+CMGR") {
      extractSms(buff);
      //Serial.println("extractSms Success.");
      if (sender_number == PHONE) {
        //Serial.println("doAction");
        doAction();
        deleteSms();
  else {
void extractSms(String buff) {
  unsigned int index;
  sms_status = buff.substring(1, index - 1);
  sender_number = buff.substring(0, 13);
  buff.remove(0, 19);
  received_date = buff.substring(0, 20);
  buff.remove(0, buff.indexOf("\r"));
  buff.trim();
  index = buff.indexOf("\n\r");
  buff = buff.substring(0, index);
  buff.trim();
  msg = buff;
  buff = "";
  msg.toLowerCase();
  Serial.println("----------------------------------");
  Serial.println(sms_status);
  Serial.println(sender_number);
  Serial.println(received_date);
  Serial.println(msg);
void doAction() {
  //case sensitive
  if (msg == "car on") {
    Serial.println("Said Your Car has ON");
    if (reply_status == true) {
      sendSms("Said Your Car has ON");
  else if (msg == "car off") {
    digitalWrite(ignition_switch, LOW);
    Serial.println("Said Your car has OFF");
      sendSms("Said Your Car has OFF");
  else if (msg == "get location") {
    sendSmsGPS("Location");
  else if (msg == "anti theft on") {
    anti_theft = true;
      sendSms("Hi Said Your Anti Theft System on And Car Will Be OFF");
  else if (msg == "anti theft off") {
    anti_theft = false;
      sendSms("Anti-Theft System OFF");
    else if (msg == "reply on") {
      sendSms("Reply has ON");
    else if (msg == "reply off") {
      reply_status = false;
  else if (msg == "tracking on") {
    tracking_status = true;
      sendSms("Live Tracking has ON");
  //yet to be implemented
  else if (msg == "tracking off") {
      sendSms("Live Tracking has OFF");
  else if (msg == "tracking status") {
    if (tracking_status == false) {
    else {
  sms_status = "";
  sender_number = "";
  received_date = "";
  msg = "";
void deleteSms()
  sendATcommand("AT+CMGD=1,4", "OK", 2000);
  Serial.println("All SMS are deleted.");
void sendSmsGPS(String text)
  // Can take up to 60 seconds
  boolean newData = false;
  for (unsigned long start = millis(); millis() - start < 2000;)
    while (neogps.available())
      if (gps.encode(neogps.read()))
        newData = true;
  if (newData)      //If newData is true
    float flat, flon;
    unsigned long age;
    Serial.print("Latitude= ");
    Serial.print(gps.location.lat(), 6);
    Serial.print(" Longitude= ");
    Serial.println(gps.location.lng(), 6);
    newData = false;
    delay(300);
    sim800.print("AT+CMGS=\"" + PHONE + "\"\r");
    sim800.print("http://maps.google.com/maps?q=loc:");
    sim800.print(gps.location.lat(), 6);
    sim800.print(",");
    sim800.print(gps.location.lng(), 6);
    delay(100);
    sim800.write(0x1A); //ascii code for ctrl-26 //sim800.println((char)26); //ascii code for ctrl-26
void sendSms(String text)
  sim800.print(text);
  delay(100);
  Serial.println("SMS Sent Successfully.");
int8_t sendATcommand(char* ATcommand, char* expected_answer, unsigned int timeout) {
  uint8_t x = 0,  answer = 0;
  char response[100];
  unsigned long previous;
  memset(response, '\0', 100);    // Initialice the string
  delay(100);
  while ( sim800.available() > 0) sim800.read();   // Clean the input buffer
  if (ATcommand[0] != '\0')
    sim800.println(ATcommand);    // Send the AT command
  x = 0;
  previous = millis();
  // this loop waits for the answer
  do {
    if (sim800.available() != 0) {  // if there are data in the UART input buffer, reads it and checks for the asnwer
      response[x] = sim800.read();
      //Serial.print(response[x]);
      x++;
      if (strstr(response, expected_answer) != NULL)    // check if the desired answer (OK) is in the response of the module
        answer = 1;
  } while ((answer == 0) && ((millis() - previous) < timeout));   // Waits for the asnwer with time out
  return answer;
boolean getIgnitionStatus()
  float val = 0;
  for (int i = 1; i <= 10; i++)
    val = val + analogRead(ignition_sensor);
  val = val / 100;
  //Serial.println(val);
  if (val > 90)
    sendSms("Hi Said Someone Trying To Start Your Bike");
    return true;
  else if (val < 50)
    return false;
void setIgnition()
  ignition_status = getIgnitionStatus;
  if (ignition_status == false) {
    //sim800l sleep mode turned off
    //must send sim800.print("AT"); here
    sim800.print("AT");
    sendATcommand("AT+CSCLK=0", "OK", 1000);
  else if (ignition_status == true) {
    //sim800l sleep mode turned on
int sendGpsToServer()
Am working on Gps Tracking System with Anti Theft System with sms request. Everything works fine except when i request sms for (GET LOCATION) i do not get sms replay while in serial monitor it shows the gps coordinates but it delete and not sending sms other than that when i request for other sms i do get sms replay and everything works. I really need help please..
