Hello guys,
I bought a SIM800L module but I get a problem ... the LED flashes 7 times fast (1 flash per second) and 1 flashes after 3 seconds.
The module is powered by 5V from a computer power supply, the voltage has been lowered to 4.2V via a 1N4001 diode and placed two 200uF capacitors in parallel to the output.
The card does not have a PIN, it is inserted correctly,I'm using the "original" antenna (the spiral one) and the SIM on the phone works.
It only worked one time. My intent is to send SMS but I can not because it does not connect to the network.
This is what serial comunication return to me:
AT
OK
+CPIN: READY
Call Ready
SMS Ready
AT+CSQ
+CSQ: 0,0
OK
Call Ready
SMS Ready
AT+CREG?
+CREG: 0,2
OK
Call Ready
SMS Ready
AT+COPS=?
+COPS: (1,"vodafone","voda IT","22210"),(3,"TELECOM ITALIA MOBILE","TIM","22201"),(3,"Wind Telecom SpA","I WIND","22288"),,(0-4),(0-2)
OK
According to the SIM800L AT Command Manual, your response for
AT+CREG?
+CREG: 0,2
is decoded as:
n = 0: Disable network registration unsolicited result code
stat = 2: Not registered, but MT is currently searching a new
operator to register to
I suspect you have a problem with your SIM card. You may want to try your settings though. Perhaps:
at+creg=1
Also, you may need to attach to the GPRS service using:
AT+CGATT
and define the PDP context:
AT+CGDCONT
I'm from Italy and I'm using a vodafone SIM... on my cellphone work perfectly, and two days ago the module worked normally...if I remove the SIM Card and type AT+CSQ the result is 20,0
It's difficult to say. If the module was working fine a few days ago with the same SIM card, I would look into trying out a different SIM card. Can you purchase a cheap prepaid SIM in Italy?
I doubt it. If you're getting a nonzero RSSI, you probably are okay. Also, if it was working before in the same place, then its likely okay. I run into SIM card problems more than antenna issues.
I tried two TIM Sim Cards and worked ... 1 SIM Card was a Brazilian SIM I could not send SMS but I could read SMS while with the Italian SIM I had no problems.
So the next one reading this thread know that Vodafone SIM Card in Italy with this module does not work.
I am using sim800L with Arduino pro mini and switch VCC of SIM800L via MOSFET is working perfectly,
But when the battery goes 3.5 volts so module is not responding, it does not give the message "CALL READY" "SMS READY.
as per datasheet SIM800L operating voltage is 3.4 to 4.4 volt.
Please drop your suggestions here why is not working when the battery goes under 3.5 volt.
Looking at AT+CBC I had theorically adequate power... Couldn't join my operator network.
After itching and scratching (AT+COPS?, AT+CREG?, AT+CGREG?, AT+CMEE?, …). I finaly came to sense thinking that the nano board powered by USB wasn't able to sustain current whilst joigning the network...
Took another power source to provide 5V to the board as it has the built-in voltage regulators.
Now it works.
— D6 NET led blinks every 3 seconds (instead of 1);
— D2 RING led stay put (that's the one that made me realise the SIM800L board was restarting);
I'll try to look what kind of capacitor (instead of a battery) I should add in order to have only one power source whilst playing on the dev board. Although it's kind of useless for the final application as I will need to provide 5V to both the Nano and the SIM800L.
About SMS Sending maybe dig around: AT+CSCA=? Googling SMSC + provider name to find the right number or with the SIM card in a working mobile dialing #50057672#…
EG: AT+CSCA="+393492000500",145 for Vodafone Italy
The SIM800L needs a 2Amp current while searching for the signal. It can run at 3.6v to 4.5v.
If the LED is continuously blinking it is searching for the network. If you give proper power it will get connected. I used LM2596 with a 9v 1 amp power supply to achieve it.
I really need help as i cannot start my project. The module is not working but i an get output in serial monitor, so i think der must be a way to fix it it shows "ready" but i cannot sent sms or call whatsoever. the led also blinks 7 times.
THE SERIAL MONITOR SHOWS THIS...:
rauson:
Initializing...
RDY
+CFUN: 1
AT
OK
AT+CSQ
+CSQ: 0,0
OK
+CPIN: READY
AT+CCID
8991301804782159456f
OK
AT+CREG?
+CREG: 0,2
OK
Call Ready
SMS Ready
Have you managed to get this work? I have similar issue.
No... i have learned that many people are facing similar issue with this module. i suppose the module is ill manufactured, or may be there has been a faulty batch.
i have same problem with sim800l module, led blibks in 1 second then after some time led blinks after each 3 secs , in hyper terminal i m receiving sms ready and call ready but when i call / sms to module then it shows the numbr is powered off, some time call goes some times not, i am using buck converter of 3A. voltage is set at 4v, on CSQ response i m gettng 10,0 to 13,0 on 13,0 call sms are wrking.
on same place with same network with sim900A works perfectly.
I have 5 pcs. SIM800L. All but one failed to get connection. (CSQ respond 0,0)
I placed a large capacitor (1500 uF; 6V3) over the Vcc (4,00V).
Now all works perfect
