relay control through SMS using GSM900A AND Arduino uno
program copied from google.
#include <SoftwareSerial.h>
// Configure software serial port
SoftwareSerial SIM900A(10, 11);
// Variable to store text message
String textMessage;
// Create a variable to store Lamp state
String lampState = "HIGH";
// Relay connected to pin 12
const int relay = 12;
// Automatically turn on the shield
/* digitalWrite(9, HIGH);
digitalWrite(9, LOW);
delay(5000);*/
// Set relay as OUTPUT
pinMode(relay, OUTPUT);
// By default the relay is off
digitalWrite(relay, HIGH);
// Initializing serial commmunication
SIM900A.begin(9600);
// Give time to your GSM shield log on to network
Serial.print("SIM900A ready...");
// AT command to set SIM900 to SMS mode
SIM900A.print("AT+CMGF=1\ ");
delay(100);
// Set module to send SMS data to serial out upon receipt
SIM900A.print("AT+CNMI=2,2,0,0,0\ ");
delay(100);
void loop(){
if(SIM900A.available()>0){
textMessage = SIM900A.readString();
Serial.print(textMessage);
delay(10);
if(textMessage.indexOf("ON")>=0){
// Turn on relay and save current state
digitalWrite(relay, LOW);
lampState = "on";
Serial.println("Relay set to ON");
textMessage = "";
if(textMessage.indexOf("OFF")>=0){
// Turn off relay and save current state
lampState = "off";
Serial.println("Relay set to OFF");
textMessage = "";
if(textMessage.indexOf("STATE")>=0){
String message = "Lamp is " + lampState;
sendSMS(message);
Serial.println("Lamp state resquest");
textMessage = "";
// Function that sends SMS
void sendSMS(String message){
delay(100);
// REPLACE THE X's WITH THE RECIPIENT'S MOBILE NUMBER
// USE INTERNATIONAL FORMAT CODE FOR MOBILE NUMBERS
SIM900A.println("AT+CMGS=\"+91798755378\"\ ");
// Send the SMS
Serial.println ("Set SMS Content");
SIM900A.println(message);
delay(100);
Serial.println ("Finish");
// End AT command with a ^Z, ASCII code 26
SIM900A.println((char)26);
delay(100);
Serial.println ("Message has been sent ->SMS Selesai dikirim");
SIM900A.println();
// Give module time to send SMS
delay(5000);
when i sending "STATE" sms to GSM for knowing the current status of lamp GSM not sending reply sms on my mobile.Remaining functions are ok.
Serial monitor appear like below.
SIM900A ready...AT+CMGF=1 AT+CNMI=2,2,0,0,0
+CMT: "+917987553768","","18/12/18,16:19:03+22"
STATE
Set SMS Content
Finish
Lamp state resquest
AT+CMGF=1 AT+CMGS="+917987553768"
ERROR
Lamp is HIGH
SoftwareSerial SIM900(10, 11);
String textMessage;
delay(5000);
SIM900.begin(9600);
delay(20000);
Serial.print("SIM900 ready...");
SIM900.print("AT+CMGF=1\r");
delay(100);
SIM900.print("AT+CNMI=2,2,0,0,0\r");
delay(100);
void loop(){
if(SIM900.available()>0){
textMessage = SIM900.readString();
delay(10);
lampState = "on";
textMessage = "";
lampState = "off";
textMessage = "";
sendSMS(message);
textMessage = "";
delay(100);
SIM900.println("AT + CMGS = \"+917987553768\"");
delay(10000);
// Send the SMS
SIM900.println(message);
delay(6000);
SIM900.println((char)26);
delay(6000);
SIM900.println();
delay(5000);
delay(6000);
After changing delay time also i am not getting lamp state sms from GSM.
I want to add a part to be able to rest the program just by sending a code.
I tried so many ways but mostly got problem. Any help regarding the issue.
int GSM_SMS::available()
if (_incomingBuffer.indexOf("1#")) { //here but does not work
//if (_incomingBuffer.length() != 0) {
Serial.println("reset");
APP_GSM_ShutdownReset();
else{
int nextMessageIndex = _incomingBuffer.indexOf("\r\n+CMGL: ");
To put your code in a code box, use the </> icon in the far left of the post tool bar and paste your code between the two bracket sets that appear.
To go back and put your code in a code box, in the bottom right of your post, select "more" and click modify. When the modify post opens, high light your code and click the </> in the far left of the post tool bar. This will put you code in code brackets. Then save the changes.
