Gsm shield and SD card
Hello I need some help.
I have a Arduino Ethernet and an Arduino Gsm shield, the official one.
I am trying to start the gsm shield, after the SD card and create a file on the sd card, but it blocks.
Can you check what is wrong on this code/
Thank you.
///////////////////// Library and initializations //////////////////////////////
#include <GSM.h>
#include <SD.h>
GSM gsmAccess;
GSMVoiceCall vcs;
GSM_SMS sms;
GSM3ShieldV1DirectModemProvider modemAccess;
char charbuffer[20];
///////////////PIN Number of the SIM card, phone numbers and SMS////////////////
#define PINNUMBER ""
File myFile;
  Serial.println("Network TEST");
  start_gsm();
  Serial.println("---------------------------------------------------");
  start_sd();
  creat_file();
  Serial.println("DATA.txt created");
void start_gsm()
  Serial.println("Waiting for the GSM Shield...");
  boolean notConnected = true;
    while(notConnected)
    if(gsmAccess.begin(PINNUMBER)==GSM_READY)
      notConnected = false;
      Serial.println("Not connected");
  Serial.println("GSM Shield initialized");
void start_sd()
    Serial.print("Initializing SD card...");
  pinMode(10, OUTPUT);
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
void creat_file()
   //Creat the new file
  Serial.println("Creating DATA.txt...");
  myFile = SD.open("DATA.txt", FILE_WRITE);
  myFile.close();
  Serial.println("DATA.txt is created");
sometimes give me this:
øøøøNetwork TEST
Waiting for the GSM Shield…
Initwwwww???ýØ?}µLõâ
I cannot help you but would like to know if you make it work as I would also like to use Arduino Ethernet + GSM shield.
It appears you may be running out of SRAM. The symptoms could range from garbage on the serial monitor to a reboot of the Arduino.
Try adding this function and call it before calling each device setup function.
int freeRam() {
  extern int __heap_start,*__brkval;
  int v;
  return (int)&v - (__brkval == 0 ? (int)&__heap_start : (int) __brkval);
edit: Then use it like this:
Serial.print(F("Free RAM: "));
Serial.println(freeRam());
It will not show zero if you run out of SRAM. It will show a negative or an unrealistic large value.
Can you test the code? It start to loop.
