GSM shield arduino Problem with Incoming call Voice
hi i use the official example of arduino GSM Receive Voice Call then when i call the GSM shiled the call answered but i can't get any voice and i can't send the voice any help ?
here is the device GSM shield i used to run this example code Link Decice
 Receive Voice Call
 This sketch, for the Arduino GSM shield, receives voice calls,
 displays the calling number, waits a few seconds then hangs up.
 Circuit:
 * GSM shield
 * Voice circuit. Refer to to the GSM shield getting started guide
   at http://www.arduino.cc/en/Guide/ArduinoGSMShield#toc11
 * SIM card that can accept voice calls
 With no voice circuit the call will connect, but will not send or receive sound
 created Mar 2012
 by Javier Zorzano
 This example is in the public domain.
 http://www.arduino.cc/en/Tutorial/GSMExamplesReceiveVoiceCall
// Include the GSM library
#include <GSM.h>
// PIN Number
#define PINNUMBER ""
// initialize the library instance
GSM gsmAccess;
GSMVoiceCall vcs;
// Array to hold the number for the incoming call
char numtel[20];
  // initialize serial communications and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.println("Receive Voice Call");
  // connection state
  boolean notConnected = true;
  // Start GSM shield
  // If your SIM has PIN, pass it as a parameter of begin() in quotes
  while (notConnected) {
    if (gsmAccess.begin(PINNUMBER) == GSM_READY) {
      notConnected = false;
      Serial.println("Not connected");
  // This makes sure the modem correctly reports incoming events
  vcs.hangCall();
  Serial.println("Waiting for a call");
  // Check the status of the voice call
  switch (vcs.getvoiceCallStatus()) {
    case IDLE_CALL: // Nothing is happening
    case RECEIVINGCALL: // Yes! Someone is calling us
      Serial.println("RECEIVING CALL");
      // Retrieve the calling number
      vcs.retrieveCallingNumber(numtel, 20);
      // Print the calling number
      Serial.print("Number:");
      Serial.println(numtel);
      // Answer the call, establish the call
      vcs.answerCall();
    case TALKING:  // In this case the call would be established
      Serial.println("TALKING. Press enter to hang up.");
      while (Serial.read() != '\n') {
        delay(100);
      vcs.hangCall();
      Serial.println("Hanging up and waiting for the next call.");
thanks for your help :slight_smile:
