GSM Shield get stuck on AT%13%
I am using arduino ide 1.5.7 with Leonardo.
I connected pins as described here: http://arduino.cc/en/Guide/GSMShieldLeonardoMega, but I go error:
/home/nenadalm/arduino-1.5.7/libraries/GSM/src/GSM3MobileMockupProvider.cpp: In member function 'int GSM3MobileMockupProvider::begin(char*)':
/home/nenadalm/arduino-1.5.7/libraries/GSM/src/GSM3MobileMockupProvider.cpp:49:2: error: 'Serial' was not declared in this scope
  Serial.println("GSM3MobileMockupProvider::begin()");
then I found: Arduino GSM Shield + Yun - Arduino GSM Shield - Arduino Forum so I downloaded posted version of GSM library and now my program shows on serial console:
scanning...
AT%13%
and that's it. it get stuck here. I tried even with 12V, 1.5A adapter.
my code:
#include <GSM.h>
#define PIN_NUMBER "here_is_my_pin"
#define CALL_NUMBER "here_is_some_number"
GSM gsmAccess(true);
  while(!Serial) {};
  Serial.println("scanning...");
  gsmAccess.begin(PIN_NUMBER);
  Serial.println("pin accepted");
Sim normally works with my mobile. Any suggestions?
i had the same problem....
i followed THIS and magically everything start to work :slight_smile:
Thanks for Your response.
I modified the code as suggested:
GSM3_NetworkStatus_t GSM3ShieldV1AccessProvider::begin(char* pin, bool restart, bool synchronous)
	pinMode(__RESETPIN__, OUTPUT);
	// If asked for modem restart, restart
	if (restart)
		HWrestart();
		HWstart();
    unsigned loopCnt = 2;
	theGSM3ShieldV1ModemCore.gss.begin(9600);
	// Launch modem configuration commands
	ModemConfiguration(pin);
	// If synchronous, wait till ModemConfiguration is over
	if(synchronous)
		// if we shorten this delay, the command fails
		while(ready()==0 && loopCnt--)
	return getStatus();
but it's still the same (the code run for over 8 minutes)
That's weird. Last printed words are "inside loop" (just once). Even if delay should take 1 second, it takes forever.
    Serial.println("method begin");
	if (restart)
		HWrestart();
		HWstart();
	if(synchronous)
        Serial.println("before loop");
		while(ready()==0 && loopCnt--) {
            Serial.println("inside loop");
        Serial.println("after loop");
	return getStatus();
delayMicroseconds seems to have an opposite problem: "inside loop" is printed 5 times in a row (even if there should be 1000s delay between these prints).
	if (restart)
		HWrestart();
		HWstart();
    unsigned loopCnt = 5;
	if(synchronous)
			delayMicroseconds(1000000000);
	return getStatus();
but when I create new sketch, it works as expected (one print per second):
  Serial.println("Hello World!");
http://arduino.cc/en/Reference/DelayMicroseconds
"Currently, the largest value that will produce an accurate delay is 16383. This could change in future Arduino releases. For delays longer than a few thousand microseconds, you should use delay() instead."
thanks for information. but delay gets stuck for unknow reason
