I have been playing with a Geeetech GSM shield and easily got it sending SMS messages and making phone calls using Geeetech’s demo code. Over the last couple days I now cant get it to send SMS messages even if I go back to the Geeetech demo code that I started with. Every time I try to send a message by typing t in the serial monitor it comes back with ERROR after trying to send the message. Below is from the serial monitor after sending a SMS and then making a phone call. Again the SMS Errors and the phone call goes through. I have replaced the last 4 of my phone number is xxxx. Can anyone offer any help. I am using a Arduino Uno.
AT+CMGF=1
OK
AT + CMGS = “+1512202xxxx”
How are you ?
ERROR
ATD + +1512202xxxx;
OK
Here is the code
/*Note: this code is a demo for how to using GPRS Shield to send SMS message and dial a voice call.
The microcontrollers Digital Pin 7 and hence allow unhindered communication with GPRS Shield using SoftSerial Library.
IDE: Arduino 1.0 or later */
#include <SoftwareSerial.h>
#include <String.h>
SoftwareSerial mySerial(7, 8);
mySerial.begin(19200); // the GPRS baud rate
//after start up the program, you can using terminal to connect the serial of gprs shield,
//if you input 't' in the terminal, the program will execute SendTextMessage(), it will show how to send a sms message,
//if input 'd' in the terminal, it will execute DialVoiceCall(), etc.
if (Serial.available())
switch (Serial.read())
case 't':
SendTextMessage();
case 'd':
DialVoiceCall();
if (mySerial.available())
Serial.write(mySerial.read());
///SendTextMessage()
///this function is to send a sms message
void SendTextMessage()
mySerial.print("AT+CMGF=1\r"); //Because we want to send the SMS in text mode
delay(100);
mySerial.println("AT + CMGS = \"+1512202xxxx\"");//send sms message, be careful need to add a country code before the cellphone number
delay(100);
mySerial.println("How are you ?");//the content of the message
delay(100);
mySerial.println((char)26);//the ASCII code of the ctrl+z is 26
delay(100);
mySerial.println();
///DialVoiceCall
///this function is to dial a voice call
void DialVoiceCall()
mySerial.println("ATD + +1512202xxxx;");//dial the number
delay(100);
mySerial.println();
void ShowSerialData()
while (mySerial.available() != 0)
