GSM shild , Replay to sms , need help please
hi all ,
i am using arduino to control an GSM SM100B , every thing is working perfectly except when i want to send an sms after receive an sms
"replay to message ", i get this Error
O K > + C M G S : 2 5 O K + C M E E R R O R : 4
dose any one have any idea about that ?
my code :
#include <SoftwareSerial.h>  //Include the NewSoftSerial library to send serial commands to the cellular module.
    char inchar;                //Will hold the incoming character from the Serial Port.
    SoftwareSerial cell(2,3);    //Create a 'fake' serial port. Pin 2 is the Rx pin, pin 3 is the Tx pin.
    char mobilenumber[] = "0597010129";  // Replace xxxxxxxx with the recipient's mobile number
    //GSM
    Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
    Serial.println("Initialize GSM module serial port for communication.");
    cell.begin(9600);
    delay(35000); // give time for GSM module to register on network etc.
    Serial.println("delay off");
    cell.println("AT+CMGF=1"); // set SMS mode to text
    delay(200);
    cell.println("AT+CNMI=3,3,0,0"); // set module to send SMS data to serial out upon receipt
    delay(200);
     if(cell.available() >0)//If a character comes in, from the cellular module
     inchar=cell.read();
     Serial.println(inchar);
     if (inchar=='#'){ // OK - the start of our command
       delay(10);
       inchar=cell.read();
         if (inchar=='a'){
           delay(10);
           Serial.println("The folowing SMS : \n");
           inchar=cell.read();
           if (inchar=='0'){ //sequance = #a0
             Serial.println("#a0 was received");
         else if (inchar=='1'){//sequance = #a1
            Serial.println("#a1 was received ");
            sendSms();
     cell.println("AT+CMGD=1,4");// AT command to delete all msgs
     Serial.println(" delete all SMS");
    }//end of  if(cell.available() >0) {...}
    void sendSms(){
    //cell.println("AT+CMGF=1"); // set SMS mode to text
    cell.print("AT+CMGS=");  // now send message...
    cell.print((char)34); // ASCII equivalent of "
    cell.print(mobilenumber);
    cell.println((char)34);  // ASCII equivalent of "
    delay(500); // give the module some thinking time
    cell.print(":D hello m3alleg :D");   // our message to send
    cell.println((char)26);  // ASCII equivalent of Ctrl-Z
    delay(20000);
CME ERROR code 4 "Operation not supported"
When the error starts with "+CME ERROR", it means that the error is a device specific error code.
http://www.smssolutions.net/tutorials/gsm/gsmerrorcodes/
thank you very much, is that means that SM5100B GSM dose not Support replay to SMS ? what can i do ?
the receive part alone is working perfectly and the send part alone is also working perfectly but they dos not fit together =(
Sorry I don't know the SM5100B, but you could use a,other way to send "replies" by software :
put a flag ON when a SMS comes in, then, if the flag is set, send a SMS just as you do when you only want to send a SMS (without having received one before), and put the flag OFF .
