Hello,
im using an GSM Modul (http://www.amazon.de/SainSmart-Kompatibel-Drahtlos-Module-SIEMENS/dp/B006CHEUSI/ref=sr_1_2?ie=UTF8&qid=1434885471&sr=8-2&keywords=siemens+gsm) to send an SMS when a magnatic switch turns on.
I need to start the networkscan with a pushbutton but i even found a way to automate that.
I am already able to send SMS's but the problem is that i never get an answear of the Modul(I'm using AT commands). I just set the Serialbegin to 9600 which works fine.
My question now: how can I check if the Modul connected succesful to the network? Is there a pin which turns high or low? or i the onliest way to solve the problem of not getting an aswear of the modul?
Thanks here hope anybody can help me:)
AT+CSQ - Signal strength report?
Thank you for your fast answear.. and the link to that nice tutorial.
I'm despairing... I dont get an answear of the gsm modul... i followed exactly the steps of the tutorial...
Could it be possible that the Modul hasn't got enough power? but it sends sms so i think it should be enough.. please help me.. I dont know what im doin wrong
Possible, all the GSM/GPRS units I know of need up to 2 amp when transmitting, depending on signal quality.
I think we need to see some code now?
Serial.begin(19200);
Serial.println("AT\r");
This is the code ... when i send an "AT" to the GSM i should response an OK. But I get back nothing.
My wiring: rx/tx to rx/tx of the arduino(i know its crossed on the GSM) and gnd to gnd and 5v to to VDD.. shuld be right? :s
Greets Jannes
How would you know? You haven't got any way of reading the response.
Try the following. Connect your modem to pins 7 & 8. Open the serial monitor and Send the AT command.
#include <SoftwareSerial.h>
SoftwareSerial GPRS(7, 8);
GPRS.begin(19200);
if (GPRS.available())
while(GPRS.available())
Serial.write(GPRS.read());
if (Serial.available())
GPRS.write(Serial.read());
Thy .. But i get no answear and my AT i sended i cant even see in the serial Monitor
I connected the rx pin of the modem to pin D7 and the tx pin t D8 that right isnt it? :o
janneswa:
If in doubt swap them over... D7 is Rx so connect to modem Tx and D8 to modem Rx.
Already done..no diffrence
Unfortunately my German isn't good enough to fully understand the Amazon page but it does look like there are some instructions and example code?
Yeah i got the code for the sms out of that commands ... but i cant find a diffrence to my wiring and code ... i dont find my misstakes ...
and i just wonna check if the gsm connected succesful to the network
i know that the modul get my commands.. but i cant recieve the answer .. and when i cant recieve the answear i cant check if the netconnection is true :s
