GSM Sim800l - internet connection library
Hi Guys. I’m looking for a library to connect to the internet with sim800l-master.
I tried this code but : …/GSMSim.h:1: error: stray ‘\357’ in program…GSMSim.h:59: error: expected class-name before ‘{’ token …
Any other code?
Thanks…
#include <GSMSim.h>
#define RX 7
#define TX 8
#define RESET 2
#define BAUD 9600
GSMSim gsm;
 * Also you can this types:
 * GSMSim gsm(RX, TX);
 * GSMSim gsm(RX, TX, RESET);
 * GSMSim gsm(RX, TX, RESET, LED_PIN, LED_FLAG);
  Serial.println("GSMSim Library - GPRS Connection and HTTP Get Example");
  Serial.println("");
  gsm.start(); // baud default 9600
  //gsm.start(BAUD);
   * gsm.gprsConnectBearer() APN: "internet", User: "", Password: ""
   * gsm.gprsConnectBearer(String apn) User: "", Password: ""
   * gsm.gprsConnectBearer(String apn, String user, String password)
   * Returns boolean true/false. Is connect to baerer return true, else false
  Serial.println(gsm.gprsConnectBearer());
  //delay(1000);
  Serial.println(gsm.gprsGetIP()); // String ip address.
   * gsm.gprsHTTPGet("www.google.com") // only returns method and response code like METHOD:GET|HTTPCODE:xxx
   * gsm.gprsHTTPGet("www.google.com", true) // returns method, response code, data lenght and DATA like METHOD:GET|HTTPCODE:xxx|LENGHT:x|DATA:......
   * if an error occured it returns error messages like this after ERROR: tag:
   * HTTP_READ_ERROR
   * HTTP_ACTION_READ_ERROR
   * HTTP_ACTION_ERROR
   * HTTP_PARAMETER_ERROR
   * HTTP_INIT_ERROR
   * GPRS_NOT_CONNECTED
   * This function automaticly terminate HTTP request at the end but it doesn't close the gprs connection!
  Serial.println(gsm.gprsHTTPGet("iot.robothane.net/test.php", true));
  // After this command, if you make another HTTP request you must re connect to bearer like gprsConnectBearer() function.
  // If you make multiple http request in one loop, dont close connection, make http requests then close the connection!
  // You can check the connection is alive with gprsIsConnected() function.
  Serial.println(gsm.gprsCloseConn());
Where did you get that code? I doubt that you typed it in.
Posting the code here got rid of the character that the compiler didn't like, so copy the code from your post, and try compiling that code.
https://github.com/erdemarslan/GSMSim/blob/master/examples/GSMSim_Internet/GSMSim_Internet.ino
