GSM Sim800L Module fails to send a message
Greetings and salutations,
I am a rookie when it comes to this and I have no prior experience to using the GSM module.
Expectation: Code Runs
Use Serial monitor to get phone number and message to send
It sends “Sent!” to the serial monitor which means it has successfully sent
Reality : Code Runs
Serial monitor works
Sends “Failed” which means it was not able to send the message
Code for the board
#include <SoftwareSerial.h>
#include "Adafruit_FONA.h"
#define FONA_RX 2
#define FONA_TX 3
#define FONA_RST 4
char replybuffer[255];
SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
Adafruit_FONA fona = Adafruit_FONA(FONA_RST);
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout = 0);
  while (!Serial);
  Serial.println(F("FONA basic test"));
  Serial.println(F("Initializing....(May take 3 seconds)"));
  fonaSS.begin(4800);
  if (! fona.begin(fonaSS)) {
    Serial.println(F("Couldn't find FONA"));
    while (1);
  Serial.println(F("FONA is OK"));
   char sendto[21], message[141];
   flushSerial();
   Serial.print(F("Send to #"));
   readline(sendto, 10);
   Serial.println(sendto);
   Serial.print(F("Type out one-line message (140 char): "));
   readline(message, 20);
   Serial.println(message);
   if (!fona.sendSMS(sendto, message)) {
      Serial.println(F("Failed"));
      Serial.println(F("Sent!"));
void loop() {}
void flushSerial() {
    while (Serial.available())
    Serial.read();
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout) {
  uint16_t buffidx = 0;
  boolean timeoutvalid = true;
  if (timeout == 0) timeoutvalid = false;
  while (true) {
    if (buffidx > maxbuff) {
    while(Serial.available()) {
      char c =  Serial.read();
      if (c == '\r') continue;
      if (c == 0xA) {
        if (buffidx == 0)   // the first 0x0A is ignored
          continue;
        timeout = 0;         // the second 0x0A is the end of the line
      buff[buffidx] = c;
      buffidx++;
    if (timeoutvalid && timeout == 0) {
    delay(1);
  buff[buffidx] = 0;  // null term
  return buffidx;
What the serial monitor shows
FONA basic test
Attempting to open comm with ATs
	---> AT
	---> AT
	---> AT
	---> AT
	---> AT
	<--- AT
	---> AT
	<--- AT
	---> ATE0
	<--- ATE0
	---> ATE0
	<--- OK
	---> AT+CVHU=0
	<--- OK
	---> ATI
	<--- SIM800 R14.18
OK
	---> AT+CPMS="SM","SM","SM"
	<--- +CPMS: 0,40,0,40,0,40
FONA is OK
Send to #(I have to redact this information, but this is a phone number)
Type out one-line message (140 char): This is a test message
	---> AT+CMGF=1
	<--- OK
	---> AT+CMGS="(I have to redact this information,but this is a phone number)"
^Z
Failed
As you may see, it all works except for the last part, it says “Failed” and I have no clue why, I have followed the instructions as such on https://www.teachmemicro.com/arduino-gsm800l-tutorial/ but still to no avail. Help would be greatly appreciated. Thank you and have a nice day :slight_smile:
Quick edit: Have tried multiple times, same input, same output(failed)
Quick edit #2:I also have no clue where “^Z” comes from in the 2nd to the last line of the serial monitor
I have the same issue... Any ideas on what it is
Hello Captain and john.
At first i suggest that check the power supply , because the module need 2A for sending or receiving or connect to the network. for this issue you must use lm2596 module , and at the output of it connect a 1000uF capacitor , and your wiring must be very very short .
for program code , do according to link below .
In-Depth: Send Receive SMS & Call with SIM800L GSM Module & Arduino.
it is very useful link.
any question ???
TOMCAT.
