Hi. I am working on a project where you can send an SMS to the sim900 in a greenhouse to get the temperature from a DS18B20 sensor and control other variables and see other data. I am halfway through writing my code but i keep being put back by an issue i can't seem to resolve myself. When sending an SMS to read the temperature it sends back the temperature exactly how i wanted it to be. However, a few seconds later i am bombarded with these SMS messages from the Sim900. I do not know the reasoning for this because sending other SMS messages work just fine. I will paste all the code but the main functions you want to look at are updateTemp, getTemp, and send_message.
#include <DallasTemperature.h>
#include <OneWire.h>
#include <SoftwareSerial.h> // Library for using serial communication
SoftwareSerial SIM900(7, 8); // Pins 7, 8 are used as used as software serial pins
String incomingData; // for storing incoming serial data
String message = ""; // A String for storing the message
int relay_pin = 4; // Initialized a pin for relay module
int temp_sensor = 5;
float temp = 0;
float tempLimit = 25;
bool isHeatOn = true;
bool tempStated = false;
OneWire oneWirePin(temp_sensor);
DallasTemperature sensors(&oneWirePin);
Serial.begin(115200); // baudrate for serial monitor
SIM900.begin(19200); // baudrate for GSM shield
pinMode(relay_pin, OUTPUT); // Setting erlay pin as output pin
digitalWrite(relay_pin, HIGH); // Making relay pin initailly high
sensors.begin();
// set SMS mode to text mode
SIM900.print("AT+CMGF=1\r");
delay(100);
// set gsm module to tp show the output on serial out
SIM900.print("AT+CNMI=2,2,0,0,0\r");
delay(100);
//Function for updating the temp
updateTemp();
//Function for receiving sms
receive_message();
//Function to manually turn on or off the heater
manualSwitch();
//Function for getting the current temperature
getTemp();
//Function for changing the temperature limit
changeTempLimit();
//Function for checking heater status
getHeatStatus();
//Function for checking overall status
getAllStatus();
//Reset incoming data to stop texts sending repeatedly
incomingData = "";
void updateTemp() {
sensors.requestTemperatures();
temp = sensors.getTempCByIndex(0);
void getAllStatus() {
if (incomingData.indexOf("Status")>=0) {
message = "Temperature: " + String(temp) + " \n Temperature Limit: " + String(tempLimit) + " \n Heater is on: " + String(isHeatOn);
send_message(message);
void getHeatStatus() {
if (incomingData.indexOf("Heater status")>=0) {
if (isHeatOn == true) {
message = "Heater is on.";
Serial.print(message);
} else if (isHeatOn == false) {
message = "Heater is off.";
tempStated = false;
void changeTempLimit() {
if (incomingData.indexOf("Increase limit")>=0) {
tempLimit = tempLimit + 1;
message = "Limit increased, now: " + String(tempLimit);
if (incomingData.indexOf("Decrease limit")>=0) {
tempLimit = tempLimit - 1;
message = "Limit decreased, now: " + String(tempLimit);
tempStated == false;
void getTemp() {
if (incomingData.indexOf("Temp")>=0 && tempStated == false) {
message = "Celsius Temperature is: " + String(temp);
tempStated == true;
incomingData = "";
void manualSwitch() {
// if received command is to turn on relay
if(incomingData.indexOf("Heater on")>=0)
message = "Led is turned ON";
// Send a sms back to confirm that the relay is turned on
Serial.print("\n led is ON.");
// if received command is to turn off relay
if(incomingData.indexOf("Heater off")>=0)
digitalWrite(relay_pin, LOW);
message = "Led is turned OFF";
// Send a sms back to confirm that the relay is turned off
Serial.print("\n led is OFF.");
tempStated = false;
void receive_message()
if (SIM900.available() > 0)
incomingData = SIM900.readString(); // Get the data from the serial port.
Serial.print("Data: " + String(incomingData));
delay(10);
void send_message(String message)
SIM900.println("AT+CMGF=1"); //Set the GSM Module in Text Mode
delay(100);
SIM900.println("AT+CMGS=\"+447719291638\""); // Replace it with your mobile number
delay(100);
SIM900.println(message); // The SMS text you want to send
delay(100);
SIM900.println((char)26); // ASCII code of CTRL+Z
delay(100);
SIM900.println();
The response i get in the Serial Monitor is the string being repeated over and over but the last letters being cut of by the next string. Thanks for the hep in advance
