Salve, avendo questo programmino, quando mi collego ad arduino tramite GSM (SIM900), non riesco a fargli leggere ciò che riceve dalla stringa da web.
Premetto che lo sketch completo con SMS, CHIAMATE, ecc., funziona per tutto ok. UNico problema chè ho è quello che quando invio
http://numeroipassegnato/stringa
sulla porta serial1 NON mi legge nulla.
Uso questa libreria
GSM/GPRS/GPS Shield of Futura/Open-electronics
For support use the issues' page on google code:
http://code.google.com/p/gsm-shield-arduino/issues/
or Arduino Forum
Library created by:
Marco Martines
#include "SIM900.h"
#include <SoftwareSerial.h>
#include "inetGSM.h"
InetGSM inet;
char msg[50];
int numdata;
char inSerial[50];
int i=0;
boolean started=false;
long lasttime=millis();
//Serial connection.
Serial.println("GSM Shield testing.");
//Start configuration of shield with baudrate.
//For http uses is raccomanded to use 4800 or slower.
if (gsm.begin(9600)) {
Serial.println("\nstatus=READY");
started=true;
} else Serial.println("\nstatus=IDLE");
if(started) {
//GPRS attach, put in order APN, username and password.
//If no needed auth let them blank.
if (inet.attachGPRS("tre.it", "", ""))
Serial.println("status=ATTACHED");
numdata=inet.httpGET("www.miosito.it", 80, "/pagina.asp?numeroardu=6", msg, 50);
//Print the results.
Serial.println("\nNumber of data received:");
Serial.println(numdata);
Serial.println("\nData received:");
Serial.println(msg);
else {Serial.println("status=ERROR");}
//Read IP address.
gsm.SimpleWriteln("AT+CIFSR");
delay(2000);
int i=0;
while(i<20) {
gsm.SimpleRead();
i++;
//TCP Server. Start the socket connection
//as server on the assigned port.
delay(5000);
if (inet.connectTCPServer(80))
Serial.println("status=TCPSERVERWAIT");
else Serial.println("ERROR in Server");
lasttime=millis();
if (started)
//Check if there is an active connection.
if (inet.connectedClient())
delay(300);
//Read and print the last message received.
gsm.read(msg, 50);
serialhwread();
serialswread();
void serialhwread()
i=0;
if (Serial.available() > 0) {
while (Serial.available() > 0) {
inSerial[i]=(Serial.read());
delay(10);
i++;
inSerial[i]='\0';
if(!strcmp(inSerial,"/END")) {
Serial.println("_");
inSerial[0]=0x1a;
inSerial[1]='\0';
gsm.SimpleWriteln(inSerial);
//Send a saved AT command using serial port.
if(!strcmp(inSerial,"TEST")) {
Serial.println("SIGNAL QUALITY");
gsm.SimpleWriteln("AT+CSQ");
//Read last message saved.
if(!strcmp(inSerial,"MSG")) {
Serial.println(inSerial);
inSerial[0]='\0';
void serialswread()
gsm.SimpleRead();
Vi prego di volermi dare qualche consiglio. GRAZIE
