GSM Sketch wont compile
Trying to run the example sketches from the GSM library. Cant get them to compile. Havnt had this problem with any of the other example sketches for other libraries LCD etc. the error mssg is as below:
enabled in File > Preferences.
Arduino: 1.0.6 (Windows 7), Board: "Arduino Uno"
C:\Program Files (x86)\Arduino\libraries\GSM\GSM3ShieldV1ModemVerification.cpp: In member function 'String GSM3ShieldV1ModemVerification::getIMEI()':
C:\Program Files (x86)\Arduino\libraries\GSM\GSM3ShieldV1ModemVerification.cpp:72: error: conversion from 'int' to 'String' is ambiguous
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino/WString.h:61: note: candidates are: String::String(const __FlashStringHelper*)
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino/WString.h:59: note: String::String(const char*)
Any ideas what I am doing wrong?
A
Please post the program that exhibits the problem.
Which board ? Which version of the IDE ?
Thanks for the reply. It s the ‘GSM Send SMS’ Sketch from the Examples in the GSM library. However am getting similar errors on other sketches from that library. Have ony tried to verify so far and have all failed.
am on arduino 1.06. using an Uno from Sainsmart.
Using 1.0.5, I get:
Binary sketch size: 16,594 bytes (of a 258,048 byte maximum)
with the Mega selected.
Hi, I am having the same problem, was there any solution found to this!?
