#include <SoftwareSerial.h>
#include <Adafruit_Fingerprint.h>
#include <Wire.h>
#include <Adafruit_Thermal.h>
#include <GSM.h>
// I2C LCD Display
LiquidCrystal_I2C lcd(0x27, 20, 4);
SoftwareSerial mySerial(2, 3);
// Define fingerprint sensor and pins
#define FINGERPRINT_RX 2
#define FINGERPRINT_TX 3
SoftwareSerial fingerSerial(4, 5); // RX, TX
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&fingerSerial);
// Define button pins and buzzer pin
#define BUTTON_CANDIDATE_1 4
#define BUTTON_CANDIDATE_2 5
#define BUTTON_CANDIDATE_3 6
#define BUZZER_PIN 7
// Define thermal printer and printer pin
#define PRINTER_RX 8
#define PRINTER_TX 9
SoftwareSerial printerSerial(6, 7); // RX, TX
Adafruit_Thermal printer(&printerSerial);
// GSM module pins
#define GSM_RX 10
#define GSM_TX 11
// Define GSM object
SoftwareSerial gsmSerial(GSM_RX, GSM_TX);
GSM gsmAccess;
// GSM related variables
char gsmPhoneNumber1[] = "+923012345678";
char gsmPhoneNumber2[] = "+923022345678";
char gsmPhoneNumber3[] = "+923032345678";
GSM_SMS sms;
#define ADMIN_FINGERPRINT_ID 1
// Candidate names
const char* candidateNames[] = {
"PTI",
"PPP",
"ANP"
// Candidate votes counters
int votesCandidate1 = 0;
int votesCandidate2 = 0;
int votesCandidate3 = 0;
// Initialize serial communication with Arduino IDE
// initialize the lcd
lcd.begin();
// Turn on the Backlight
lcd.backlight();
Serial.println("LCD initialized");
while (!Serial); // For Yun/Leo/Micro/Zero/...
delay(100);
// Initialize fingerprint sensor
finger.begin(57600);
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
Serial.println("Did not find fingerprint sensor :(");
while (1);
finger.getTemplateCount();
Serial.print("Sensor contains ");
Serial.print(finger.templateCount);
Serial.println(" templates");
Serial.println("Waiting for valid finger...");
lcd.clear();
// Set cursor (Column, Row)
lcd.setCursor(0, 0);
lcd.print("Digital Electronic");
lcd.setCursor(0,1);
lcd.print("Voting Machine");
delay(3000);
// Initialize buttons and buzzer
pinMode(BUTTON_CANDIDATE_1, INPUT);
pinMode(BUTTON_CANDIDATE_2, INPUT);
pinMode(BUTTON_CANDIDATE_3, INPUT);
pinMode(BUZZER_PIN, OUTPUT);
// Initialize thermal printer
printer.begin();
// Initialize GSM module
gsmAccess.begin();
// Wait for a finger to be detected
if (finger.getImage()) {
// Finger detected, search fingerprint database
int fingerprintID = finger.fingerID;
if (fingerprintID == 0) {
// No fingerprint match found
invalidVote();
} else if (fingerprintID == ADMIN_FINGERPRINT_ID) {
// Admin fingerprint detected
adminMode();
// Valid voter fingerprint detected
castVote(fingerprintID);
void castVote(int fingerprintID) {
// Enable voting buttons and activate buzzer once
enableVotingButtons();
activateBuzzerOnce();
// Wait for voter to select a candidate
int selectedCandidate = waitForCandidateSelection();
// Disable voting buttons
disableVotingButtons();
// Print the selected candidate's vote
printVote(fingerprintID, selectedCandidate);
void invalidVote() {
// Display invalid vote message
Serial.println("Invalid Vote");
// Activate buzzer three times
for (int i = 0; i < 3; i++) {
void adminMode() {
// Calculate total voter turnout
int totalVotes = votesCandidate1 + votesCandidate2 + votesCandidate3;
// Determine winner based on votes
int winner = determineWinner();
// Print winner and voter turnout
Serial.print("Winner: Candidate ");
Serial.println(winner);
Serial.println(candidateNames[winner - 1]); // winner - 1 to access array index
Serial.print("Total Voter Turnout: ");
Serial.println(totalVotes);
// Print winner and voter turnout to thermal printer
printAdminResults(winner, totalVotes);
void activateBuzzerOnce() {
digitalWrite(BUZZER_PIN, HIGH);
delay(100);
digitalWrite(BUZZER_PIN, LOW);
void enableVotingButtons() {
// Enable voting buttons for candidates
void disableVotingButtons() {
// Disable voting buttons for candidates
pinMode(BUTTON_CANDIDATE_1, OUTPUT);
pinMode(BUTTON_CANDIDATE_2, OUTPUT);
pinMode(BUTTON_CANDIDATE_3, OUTPUT);
int waitForCandidateSelection() {
// Wait for user input from candidate buttons
int candidateSelected = 0;
while (candidateSelected == 0) {
// Check each candidate button
if (digitalRead(BUTTON_CANDIDATE_1) == HIGH) {
candidateSelected = 1;
} else if (digitalRead(BUTTON_CANDIDATE_2) == HIGH) {
candidateSelected = 2;
} else if (digitalRead(BUTTON_CANDIDATE_3) == HIGH) {
candidateSelected = 3;
delay(100); // debounce delay or adjust as necessary
return candidateSelected;
void printVote(int fingerprintID, int selectedCandidate) {
// Print the vote to the thermal printer
printer.println("Voter ID: " + String(fingerprintID));
printer.print("Vote: Candidate ");
printer.println(candidateNames[selectedCandidate - 1]); // selectedCandidate - 1 to access array index
printer.feed(2);
// Determine which phone number to send SMS based on fingerprint ID
char* phoneNumberToSend;
if (fingerprintID == 2) {
phoneNumberToSend = gsmPhoneNumber1;
} else if (fingerprintID == 3) {
phoneNumberToSend = gsmPhoneNumber2;
} else if (fingerprintID == 4) {
phoneNumberToSend = gsmPhoneNumber3;
// Handle other fingerprint IDs or errors
return;
// Send SMS alert
sendSMSAlert(phoneNumberToSend);
void sendSMSAlert(char* phoneNumber) {
// Connect to GSM network
Serial.println("Connecting to GSM network...");
while (!gsmAccess.begin()) {
Serial.println("Failed to connect to GSM network.");
delay(700);
Serial.println("Connected to GSM network.");
// Send SMS message
char smsMessage[50];
sprintf(smsMessage, "Your vote has been cast. Thank you.");
sms.beginSMS(phoneNumber);
sms.print(smsMessage);
sms.endSMS();
Serial.println("SMS sent.");
// Disconnect from GSM network
gsmAccess.shutdown();
void printAdminResults(int winner, int totalVotes) {
// Print winner and total voter turnout to the thermal printer
printer.println("Winner: " + String(candidateNames[winner - 1])); // winner - 1 to access array index
printer.print("Total Voter Turnout: ");
printer.println(totalVotes);
printer.feed(2);
int determineWinner() {
//Determine the candidate with the most votes
int winner = 1; // Assume candidate 1 is initially the winner
int maxVotes = votesCandidate1;
// Check if candidate 2 has more votes
if (votesCandidate2 > maxVotes) {
winner = 2;
maxVotes = votesCandidate2;
// Check if candidate 3 has more votes
if (votesCandidate3 > maxVotes) {
winner = 3;
maxVotes = votesCandidate3;
return winner;
> GSM\GSM3SoftSerial.cpp.o: In function __vector_3':** **C:\Program Files (x86)\Arduino\libraries\GSM\src/GSM3SoftSerial.cpp:499: multiple definition of
__vector_3'
SoftwareSerial\SoftwareSerial.cpp.o:C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial/SoftwareSerial.cpp:227: first defined here
GSM\GSM3SoftSerial.cpp.o: In function GSM3SoftSerial::spaceAvailable()':** **C:\Program Files (x86)\Arduino\libraries\GSM\src/GSM3SoftSerial.cpp:487: multiple definition of
__vector_4'
SoftwareSerial\SoftwareSerial.cpp.o:C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial/SoftwareSerial.cpp:392: first defined here
__vector_5'
collect2.exe: error: ld returned 1 exit status
