GSM Text Parsing from SMS
Hello,
I'm not able to parse Text and Mobile number from AT command AT+CMGR=1.
Please help me how to get Text and Mobile number out of the response from GSM.
AT+CMGR=1
+CMGR: "REC READ","+91XXXXXXXXXX","","16/11/17,00:08:31+22"
Hello
For example (want to parse),
Number : +91XXXXXXXXXX
Text : Hello
it is just a case of parsing char by char until you get what you want.
I have not tested this code, there are bound to be typos and syntax errors. So treat it as pseudo code and work from it as an idea of how it might be done.
It is even easier if you want to use String objects.
so if you know that a text message has come in and is waiting in the serial buffer to be read, you do the following
void extractNumber( char *sendingNumber) {
  char d;
  uint8_t numDoubleQuotes = 0;
  bool foundColon = false;
  uint8_t index = 0;
  while (Serial.available()) {
    d = Serial.read();
    if (foundColon) {
      if (numDoubleQuotes == 3) {
        if (d == '"') return; //we have finished collecting
        sendingNumber[index] = d;
        sendingNumber[index + 1] = NULL;
        index++;
        numDoubleQuotes++;
      if (d == ':') foundColon = true;
void extractMessageText(char *textMessage) {
  char d;
  uint8_t numCommas = 0;
  char messageLengthChar[4];
  uint8_t messageLength;
  bool capturing = false;
  uint8_t index = 0;
    d = Serial.read();
    if (!capturing) {
      if (d == ',') {
        numCommas++;
        if (numCommas == 9) capturing = true;
        continue;
    } else { // we are capturing
      if (d == '\r') {
        messageLength = atoi(messageLengthChar);
      if (d == '\n') break;
      messageLengthChar[index] = d;
      messageLengthChar[index + 1] = NULL;
  while (Serial.read()) {
    for (index = 0; index < messageLength; index++) {
      d = Serial.read();
      textMessage[index] = d;
  char sendingNumber[15];
  char messageText[171];
  extractNumber( sendingNumber );
  extractMessageText( messageText );
  Serial.print(F("The following message was received from: "));
  Serial.println(sendingNumber);
  Serial.println(messageText);
if the text is already in a buffer, then pass a reference to the buffer as a second argument and iterate over the buffer rather than reading from Serial.
You can NOT parse the data until you have saved the data somewhere/somehow.
How to parse the data depends on HOW you have saved the data.
You seem to have forgotten to supply an awful lot of stuff in your post. Like your code!
