GSM v2 reconnect sometimes fails
Hi!
I'm using Arduino GSM v2 shield to connect to web page and pull info- basically one integer.
This whole page consists of example - #4
So im using these two functions below to connect and parse result (get the number 4).
the problem is: sometimes when reconnecting to web page, to get the integer 4 or whatever it's displaying, GSM module fails to connect! :confused: it's not always but sometimes, and i don't know why.. What should I do about it?
I'm guessing client.stop() and client.flush() is needed after i have received needed data or before new connection. The thing is, these client.stop() and client.flush() are kind of slow, and blocks main loop() while it flushes or stops client.
void startGSM()
	// /////////START GSM/////////////
	// After starting the modem with GSM.begin()
	// attach the shield to the GPRS network with the APN, login and password
	Serial.println(F("Starting GSM"));
	//gsmSerial.write("AT+GSN\r\n");
	if (gsmAccess.begin(PINNUMBER) == GSM_READY)
		Serial.println("PIN correct = GSM READY");
		Serial.println("PIN error");
	if (gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD) == GPRS_READY)
		Serial.println("APN correct = GPRS READY");
		Serial.println("APN error");
void updateHashtag()
	// if you get a connection, report back via serial:
	Serial.println(F(""));
	Serial.println(F("Updating HT..."));
	Serial.println(F("Connecting..."));
	// if ((client.available() > 0))
	// client.flush();// flush before connect
	if (client.connect(server, port))
		Serial.println("Searching for hashtag: " + hashtag);
		client.print("GET ");
		client.print(path + hashtag);
		client.println(" HTTP/1.1");
		client.print("Host: ");
		client.println(server);
		client.println("Connection: close");
		client.println();
		if (client.connected())
			Serial.println(F("CLIENT IS CONNECTED"));
			HTparse = true; // start ht parser
		// if you didn't get a connection to the server:
		Serial.println(F("!!!!!!!!!!!!!!!!!!!!!!!!!!!connection failed"));
		Serial.println(F("Restarting GSM module"));
		HTparse = false; // disable ht parser
		startGSM(); // restart GSM module..
// ////////////////parser start'/////////////
unsigned long GPRSparser()
	// hashtag_result_int = 0;
	// //Serial.println("HT client connected.");
	fullDataReceived = false;
		// && (client.connected())
		// Serial.println(F("GPRS client conected."));
		cP = client.read();
		// Serial.print(cP);
		if (cP == '#')
			writeBool = true;
			// Serial.println("I see #");
		if (writeBool == true)
			// Serial.print(c );
			hashtag_buffer[HTindex] = cP; // appending characters to buffer array
			HTindex++;
			if (cP == '\n')
				hashtag_buffer[0] = '0'; // removing # character
				hashtag_buffer[HTindex - 2] = '\0';
				writeBool = false;
				fullDataReceived = true;
			if (fullDataReceived)
				HTindex = 0; // reset hashtag_buffer
				hashtag_result_int = atol(hashtag_buffer);
				Serial.print(F("Hashtag_result_int: "));
				Serial.println(hashtag_result_int);
				HTparse = false; // end ht parser
				return hashtag_result_int;
That's a mobile network! You always have to be prepared that this may fail. You'll never get 100% availability from a mobile network.
