GSM with arduino nano *Please Help*
Hey I'm new here and I'm sorry if I do something wrong...
I'm doing a project that need to do the fallowing things:
If Relay1 closes it must send an SMS to the phone.
If Relay2 closes it must send a diffrent SMS to the phone.
This is the basic idea...
Hardware:
-GSM module SIM800l
-Arduino nano
HW connection(hope is correct): Connected the voltage supply (+5 V and GND), connected the RX of the GSM to the TX10 of the arduino, TX of the GSM module to RX10 of the arduino (not shure if needed, because I only must transmit), and finally i connected the reset of GSM to reset of arduino.
Software: I opened the GSM->sendSMS example in Arduino IDE, but I don't know how to program what I need, also if I have tried...
SMS sender
This sketch, for the Arduino GSM shield,sends an SMS message
you enter in the serial monitor. Connect your Arduino with the
GSM shield and SIM card, open the serial monitor, and wait for
the "READY" message to appear in the monitor. Next, type a
message to send and press "return". Make sure the serial
monitor is set to send a newline when you press return.
Circuit:
* GSM shield
* SIM card that can send SMS
created 25 Feb 2012
by Tom Igoe
This example is in the public domain.
http://www.arduino.cc/en/Tutorial/GSMExamplesSendSMS
// Include the GSM library
#include <GSM.h>
#define PINNUMBER "A7"
// initialize the library instance
GSM gsmAccess;
GSM_SMS sms;
// initialize serial communications and wait for port to open:
while (!Serial) {
  ; // wait for serial port to connect. Needed for native USB port only
Serial.println("SMS Messages Sender");
// connection state
boolean notConnected = true;
// Start GSM shield
// If your SIM has PIN, pass it as a parameter of begin() in quotes
while (notConnected) {
  if (gsmAccess.begin(PINNUMBER) == GSM_READY) {
    notConnected = false;
    Serial.println("Not connected");
Serial.println("GSM initialized");
Serial.print("Enter a mobile number:004178*******");
char remoteNum[20];  // telephone number to send sms
readSerial(remoteNum);
Serial.println(remoteNum);
// sms text
Serial.print("Now, enter SMS content: ");
char txtMsg[34];
readSerial(txtMsg);
Serial.println("SENDING");
Serial.println("Message:");
Serial.println(txtMsg);
// send the message
sms.beginSMS(remoteNum);
sms.print(txtMsg);
sms.endSMS();
Serial.println("\nCOMPLETE!\n");
Read input serial
int readSerial(char result[]) {
int i = 0;
while (1) {
  while (Serial.available() > 0) {
    char inChar = Serial.read();
    if (inChar == '\n') {
      result[i] = '\0';
      Serial.flush();
      return 0;
    if (inChar != '\r') {
      result[i] = inChar;
      i++;
Why have you posted your question in the Introductory Tutorials section where it clearly says
PLEASE DON'T POST YOUR QUESTIONS IN THIS TUTORIAL SECTION
I am suggesting to the Moderator to move your Post.
And to make it easy for people to help you please modify your post and use the code button </> so your code looks like this and is easy to copy to a text editor. See How to use the Forum
...R
