Hi
My new GSM Shield doesn't work. I changed the Code in this GSM3ShieldV1AccessProvider.cpp library like this post Code hangs in interrupt when there is poor GSM signal - Arduino GSM Shield - Arduino Forum
I have two different running Swisscom SIM-Cards. In a handy it runs perfectly.
Where is the problem?
Thanks for your support
Mick
Here is the output from serial mon.:
Starting Arduino web client.
notConnected = true
begin while...
gsm.begin()
AT%13%gsm.begin() waiting for ready
Not connected
begin while...
gsm.begin()
// include the GSM library
#include <GSM.h>
// PIN number if necessary
#define PINNUMBER "1111"
// APN information obrained from your network provider
#define GPRS_APN "gprs.swisscom.ch" // replace with your GPRS APN
#define GPRS_LOGIN "" // replace with your GPRS login
#define GPRS_PASSWORD "gprs" // replace with your GPRS password
// initialize the library instances
GSMClient client;
GPRS gprs;
GSM gsmAccess(true);
// This example downloads the URL "http://arduino.cc/latest.txt"
char server[] = "arduino.cc"; // the base URL
char path[] = "/latest.txt"; // the path
int port = 80; // the port, 80 for HTTP
// initialize serial communications
Serial.println("Starting Arduino web client.");
// connection state
boolean notConnected = true;
Serial.println("notConnected = true");
// Start GSM shield
// pass the PIN of your SIM as a parameter of gsmAccess.begin()
while(notConnected)
Serial.println("begin while...");
if(gsmAccess.begin(PINNUMBER)==GSM_READY) {//& (gprs.attachGPRS(GPRS_APN, GPRS_LOGIN, GPRS_PASSWORD)==GPRS_READY)){
notConnected = false;
Serial.println("Connected");
Serial.println("Not connected");
Serial.println("connecting...");
// if you get a connection, report back via serial:
if (client.connect(server, port))
Serial.println("connected");
// Make a HTTP request:
client.print("GET ");
client.print(path);
client.println(" HTTP/1.0");
client.println();
// if you didn't get a connection to the server:
Serial.println("connection failed");
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available())
char c = client.read();
Serial.print(c);
// if the server's disconnected, stop the client:
if (!client.available() && !client.connected())
Serial.println("disconnecting.");
client.stop();
// do nothing forevermore:
for(;;)
