GUI-O Android - Arduino Leonardo Joystick
Here is a very simple example how a GUI-O joystick can be made on Arduino Leonardo Nano hardware and used on an Android phone.
It could be also good alternative for LCD displays.
Instruction in 5 steps:
2. Install the GUI-O from
[www.gui-o.com] (https://www.gui-o.com)
[Google play] (https://play.google.com/store/apps/details?id=com.guio.guioapp)
on your smartphone
3. Open MS-Leonardof.ino
and program the Arduino Leonardo.
4. Open GUI-O on smartphone, connect with Bluetooth device (HC06)
5. Press the start button in the GUI-O application
(blue circle with the GUI-O symbol)
Enjoy.
Read the manual for new ideas.
Manual
Complete graphic interface on Android phone is done in firmware site Arduino. See init_guio();
MS-Leonardof.ino (3.0 KB)
Youtube video
Youtube video
> // Arduino Leonardo nano Joystic Bluetooth HC06
> // GUI-O JOYSTIC
> // https://play.google.com/store/apps/details?id=com.guio.guioapp
> // www.gui-o.com
> float xa = 0.095419;
> float yb = 0.048638;
> float x;
> float y;
> byte bt1;
> byte cur;
> //Setup-------------------------------------------------------------------
> void setup()
>  Serial1.begin(9600);
>  while (!Serial1); //wait for connection to become live
>   delay(1000);
> //GUI-O Init
> init_guio();
> pinMode(21, INPUT_PULLUP);
> //Main -------------------------------------------------------------------
> void loop()
>  joystick();
>  while (Serial1.available() > 0 ) {
>      String str = Serial1.readString();
>      if (str.equals("@im1 1\r\n")) {
>         init_guio();
>      if (str.equals("@init\r\n")) {
>         init_guio();
> // Procedure Init GUI-O --------------------------------------------------------
> void init_guio()
> //GUI-O Init
> Serial1.println("@sls 500");
> Serial1.println("@cls");
> Serial1.println("@clo");
> Serial1.println("@gse COD:0 TSC:39");
> Serial1.println("@guis BGC:#696969 ASR:0.449671");
> Serial1. println("|BSR UID:bsr1 X:50 Y:25 W:99 H:50 VIS:1 ROT:0 RAD:1.5 BGC:#d3d3d3 SBGC:#d3d3d3 FGC:#d3d3d3 SHE:1 BTH:0.5");
> Serial1.println("|LB UID:lb2 X:80 Y:48 ALP:0 SHE:1 ROT:0 URL:1 FGC:#FFFFFF FSZ:2 FFA:'font0' TXT:'www.gui-o.com'");
> Serial1.println("|SI UID:six X:50 Y:25 W:5 VIS:1 ROT:0 BGC:#B0C4DE FGC:#FF0000 SHE:1 EN:0");
> Serial1.println("|LB UID:lb0 X:50 Y:55 ALP:0 SHE:1 ROT:0 FGC:#FFFFFF FSZ:4 FFA:'font7' TXT:'GUI-O Joystick'");
> Serial1.println("|LB UID:lb1 X:50 Y:63 ALP:0 SHE:1 ROT:0 FGC:#FFFFFF FSZ:3 FFA:'font7' TXT:'Arduino Leonardo'");
> Serial1.println("|LB UID:lbcu X:50 Y:60 ALP:0 SHE:1 ROT:0 FGC:#000000 FSZ:1.8 FFA:'font0' TXT:'---'");
> Serial1.println("|IM UID:im1 X:50 Y:80 W:60 H:60 ROT:0 SHVR:0.8 SHE:1 SHC:#404040 IP:'https://i.imgur.com/sG1LpQV.png'");
> Serial1.println("|IM UID:imp X:50 Y:25 W:15 H:10 ROT:0 SHVR:0.8 SHE:0 SHC:#404040 IP:'https://i.imgur.com/tlDfn0k.png'");
> Serial1.println("@hls 200");
> // Joystick----------------------------------------------------------------------
> // Porcedure Joystick
> void joystick()
>    x=analogRead(A1)*xa;
>    y=analogRead(A0)*yb;
>    cur=y+4;
>   bt1=(!digitalRead(21));
>   digitalWrite(5, bt1);
>   delay(10);
>   Serial1.print("@six X:");Serial1.print(x);Serial1.print(" Y:"); Serial1.print(y); Serial1.print(" EN:");Serial1.print(bt1);
>   Serial1.println();
>    Serial1.print("@imp X:");Serial1.print(x);Serial1.print(" Y:"); Serial1.print(y);
>    Serial1.println();
>   Serial1.print("@lbcu X:");Serial1.print(x);Serial1.print(" Y:"); Serial1.print(cur); Serial1.print(" TXT:'");
>   Serial1.print("X:"); Serial1.print(x); Serial1.print("Y:"); Serial1.print(y);Serial1.print("'");
>   Serial1.println();
Are you from the GUI-O team ?
Please be clear about it, so we don't have guess.
The Category "Exhibition / Gallery" and might be more appropriate : Exhibition / Gallery - Arduino Forum
You can edit your top post to change the Category.
I see that you have not found the Ctrl+T in the Arduino IDE. Try it.
Yes I'am from GUI-O team.
I moved the post to the suggested category.
