Guidance about expanding a project with motorized faders encoders
Hello,
I have a working project around an Arduino Leonardo. It acts as a midi controller with one motorized fader, one button and an encoder.
I want more faders, buttons and encoders but scaling up I need more inputs/outputs than the Leonardo can handle.
So I successfully added a shift register for the h-bridge controlling the motor (from the motorized fader), but using shift registers doesn't work with the libraries i'm using for encoders and buttons. You can't refer to pins in the code with shift register, so it breaks my code.
I started trying I2C communication between the Leonardo and a Mega board, the mega could handle the number of pins needed. With this method, I feel like there is latency and the motor behavior is erratic.
So do you think I should rewrite code to follow with I2C or shift registers ? Is there another path ? (a board acting like an HID device with as many pins as the mega for example)
Thank you
I believe you could follow a hard path to making the Mega into an HIDUSB capable board. But it is a slog and less than ideal for developing on.
Adding a second microprocessor for more pins is plausible but also introduces another kind of fun you'll be having quite a bit of doing.
As more of a software hacker, I would spend the time
unbreaking the code.
There may be libraries for the shift register that offer superior ways of dealing with the pins which might mean bringing your code into compliance would not be as hard.
a7
Yeth:
a7
Thank you for answering. I will try it, if it works it would get me out of a spot!
It's your funeral. Or party. :expressionless:
I read
  1. Sketches can only be loaded to the Arduino when the 8U2/16U2 is running the arduino-usbserial.hex driver. You must flash this firmware back to the Arduino using DFU mode before you can load a new sketch.
and was reminded why ppl don't usually.
If indeed you need to go through the entire process back and forth to get a revised sketch in there, I would recommend postponing using the Mega until I was very sure the sketch was ready to go. Finding a trivial error woukd become a huge amount of work if you use the try this try that stuff we can find ourselves doing.
Good luck!
a7
Ok so I learned my Mega is an CH340G board, can't be flashed, I will need another Mega board.
Thank you
Perhaps you should consider a Due board. I understand it can act as HID device, like Leonardo can, but also has many pins, like Mega has.
But also it is a 3.3V device, not 5V, so check that this will not cause a problem.
It would be a good option, I didn't notice it while searching for bigger board! It looks like it's compatible with the libraries I use, thank you !
Keep in mind that the Due is an old board with IMHO poor software support. (Their compiler is stuck at GCC 4.8.5, which doesn't even have non-experimental C++11 support; the current release of GCC is 14.2).
You may want to have a look at the Control Surface library: it has an "ExtIO" framework that supports shift registers and multiplexers to allow building large MIDI controllers.
It also supports motorized faders, but it off-loads the actual low-level motor control loops to separate microcontrollers which communicate movement and setpoint changes to the main microcontroller over I²C.
Thank you for answering. I'm using this library for buttons and encoders, but I didn't use it for the motorized faders. I have to test it it.
I didn't know I could use it with shift registers and multiplexers, I'll read about it!
PS : thank you for your work, I read you many times before.
I started reading, and will have to dig in much more if I follow this path. Do you think more faders can be implemented using more ATMEGA328P?
That's the idea, yes. You can use a different I²C address for each ATmega: Control-Surface-Motor-Fader/Motor-Controller/main.cpp at fe8a54f912ea0bac2d75647e6f40e23807e00823 · tttapa/Control-Surface-Motor-Fader · GitHub Each ATmega then supports up to four faders.
That said, I've never actually tried it in practice, these fader projects can get quite pricey.
I hope I'll be able to try it !
For users reading this post, I followed PieterP's advice and it was a good choice. The library and documentation are very good. I didn't expanded it with more than one AT328p at the moment, but I will in the future.
