I would like advice on how best link an arduino device wirelessly to an android smart phone. I have looked into the possibility of using an arduino mega ADK combined with a wireless sd shield and xbee module however this appears to be a slightly expensive option and I'm unsure if the shield and ADK board are compatible? As an alternative could a arduino yun be used as it has the integrated wireless functionality?
For the xbee/wifly the pins are 0 and 1 for serial to the module and power and ground so it should be. There may be issues with the Sd card part but you not using so...
SuspectRogue:
I would prefer to use WiFi so that I could make use of the increased range, but if bluetooth would be simpler to implement I could use it instead.
