Guidance for ccs811/bme280 values published via mqtt
hi i am new with coding and i am having really trouble making a script to publish the values of the sensor ccs811 and bme280 from sparkfun via mqtt .I have the sensor connected to wemos d1 esp8266 and
the code i am using is from the example library of sparkfun and it works fine when publishing the values via serial . Is it possible to guide - help me how to modify this script to send the values via mqtt ?any help will be greatly appreciated .
here is the code
#include <SparkFunBME280.h>
#include <SparkFunCCS811.h>
#define CCS811_ADDR 0x5B //Default I2C Address
//#define CCS811_ADDR 0x5A //Alternate I2C Address
#define PIN_NOT_WAKE 5
//Global sensor objects
CCS811 myCCS811(CCS811_ADDR);
BME280 myBME280;
  Serial.println("Apply BME280 data to CCS811 for compensation.");
  //This begins the CCS811 sensor and prints error status of .begin()
  CCS811Core::status returnCode = myCCS811.begin();
  Serial.print("CCS811 begin exited with: ");
  //Pass the error code to a function to print the results
  printDriverError( returnCode );
  //For I2C, enable the following and disable the SPI section
  myBME280.settings.commInterface = I2C_MODE;
  myBME280.settings.I2CAddress = 0x77;
  //Initialize BME280
  myBME280.settings.runMode = 3; //Normal mode
  myBME280.settings.tStandby = 0;
  myBME280.settings.filter = 4;
  myBME280.settings.tempOverSample = 5;
  myBME280.settings.pressOverSample = 5;
  myBME280.settings.humidOverSample = 5;
  //Calling .begin() causes the settings to be loaded
  delay(10);  //Make sure sensor had enough time to turn on. BME280 requires 2ms to start up.
  myBME280.begin();
  //Check to see if data is available
  if (myCCS811.dataAvailable())
    //Calling this function updates the global tVOC and eCO2 variables
    myCCS811.readAlgorithmResults();
    //printInfoSerial fetches the values of tVOC and eCO2
    printInfoSerial();
    float BMEtempC = myBME280.readTempC();
    float BMEhumid = myBME280.readFloatHumidity();
    Serial.print("Applying new values (deg C, %): ");
    Serial.print(BMEtempC);
    Serial.print(",");
    Serial.println(BMEhumid);
    //This sends the temperature data to the CCS811
    myCCS811.setEnvironmentalData(BMEhumid, BMEtempC);
  else if (myCCS811.checkForStatusError())
    //If the CCS811 found an internal error, print it.
    printSensorError();
  delay(2000); //Wait for next reading
void printInfoSerial()
  //getCO2() gets the previously read data from the library
  Serial.println("CCS811 data:");
  Serial.print(" CO2 concentration : ");
  Serial.print(myCCS811.getCO2());
  Serial.println(" ppm");
  //getTVOC() gets the previously read data from the library
  Serial.print(" TVOC concentration : ");
  Serial.print(myCCS811.getTVOC());
  Serial.println(" ppb");
  Serial.println("BME280 data:");
  Serial.print(" Temperature: ");
  Serial.print(myBME280.readTempC(), 2);
  Serial.println(" degrees C");
  Serial.print(myBME280.readTempF(), 2);
  Serial.println(" degrees F");
  Serial.print(" Pressure: ");
  Serial.print(myBME280.readFloatPressure(), 2);
  Serial.println(" Pa");
  Serial.print((myBME280.readFloatPressure() * 0.0002953), 2);
  Serial.println(" InHg");
  Serial.print(" Altitude: ");
  Serial.print(myBME280.readFloatAltitudeMeters(), 2);
  Serial.println("m");
  Serial.print(myBME280.readFloatAltitudeFeet(), 2);
  Serial.println("ft");
  Serial.print(" %RH: ");
  Serial.print(myBME280.readFloatHumidity(), 2);
  Serial.println(" %");
//printDriverError decodes the CCS811Core::status type and prints the
//type of error to the serial terminal.
//Save the return value of any function of type CCS811Core::status, then pass
//to this function to see what the output was.
void printDriverError( CCS811Core::status errorCode )
  switch ( errorCode )
    case CCS811Core::SENSOR_SUCCESS:
      Serial.print("SUCCESS");
    case CCS811Core::SENSOR_ID_ERROR:
      Serial.print("ID_ERROR");
    case CCS811Core::SENSOR_I2C_ERROR:
      Serial.print("I2C_ERROR");
    case CCS811Core::SENSOR_INTERNAL_ERROR:
      Serial.print("INTERNAL_ERROR");
    case CCS811Core::SENSOR_GENERIC_ERROR:
      Serial.print("GENERIC_ERROR");
    default:
      Serial.print("Unspecified error.");
//printSensorError gets, clears, then prints the errors
//saved within the error register.
void printSensorError()
  uint8_t error = myCCS811.getErrorRegister();
  if ( error == 0xFF ) //comm error
    Serial.println("Failed to get ERROR_ID register.");
    Serial.print("Error: ");
    if (error & 1 << 5) Serial.print("HeaterSupply");
    if (error & 1 << 4) Serial.print("HeaterFault");
    if (error & 1 << 3) Serial.print("MaxResistance");
    if (error & 1 << 2) Serial.print("MeasModeInvalid");
    if (error & 1 << 1) Serial.print("ReadRegInvalid");
    if (error & 1 << 0) Serial.print("MsgInvalid");
if you do a web search for arduino mqtt you will get plenty of links, e.g.
https://pubsubclient.knolleary.net/
Hey,
I've just published my sketch for reading the values from the CCS811 and publish them to mqtt using the AKStudios Library (https://github.com/AKstudios/CCS811-library).
I couldn't get the Sparkfun nor Adafruit library to run on an ESP8266. I always get an I2C_ERROR there.
All in all it seems very flacky. Maybe someone of you can hint me on how to use the other library and/or get it running stable on the esp8266.
Cheers,
Patrik
For the I2C-error, have a look at: http://www.instructables.com/id/SparkFun-ESP8266-Thing-With-CCS811and-BME280-I2C-T/
Maybe you have to change the bme280 adress from0x77 to 0x76.
