Hello Guys,
I’m working on a project where I check the health of a battery. The battery is connected to a charger that keeps the battery charged at all times. However, it does not check if the battery is bad (i.e. unable to hold a charge), because the battery is too old or has another fault. To check the battery health, I’ve come up with some code to disconnect the charger from the battery every day for about 1 hour. The battery will be charged at 13 V. If the voltage drops below 12.5 V within that hour, an email will be sent notifying me that, indeed, it is a bad battery. Otherwise, If the battery is below this voltage value to begin with, the code won’t execute, because it means that the battery was recently used or is still charging.
The code below works just like I want it to work, but I think is a little rough and could be improved. I’m asking all the genius coders out there for help. Can I improve this code?
// On and Off Times
const unsigned long timeOn = 1000UL*30; // This will be set to 23 hrs
const unsigned long timeOff = 1000UL*5; // This will be set to 1 hr
// Tracks the last time event
unsigned long startMillis = 0;
// Waiting time
unsigned long period = timeOn;
// Tracks if Relay is on or off
boolean relayState = true;
// Variables for the voltage sensor
int offset = 8; // Offset value
float average = 0;
pinMode(13, OUTPUT);
digitalWrite(13, HIGH); // We want the relay on
int volt = analogRead(A3);
double voltage = map(volt,0,1023, 0, 2500) + offset; // map 0-1023 to 0-2500 and add correction offset
voltage /=100;// divide by 100 to get the decimal values
if(voltage > 13 || relayState == LOW) // Do this only if voltage is below 13V and Relay is LOW
// relayState value will change only if the relay state changes
digitalWrite(13, relayState);
// CurrentMills will take keep track of the milliseconds
// Compare to previous capture to see if enough time has passed
if ((unsigned long)(currentMillis - startMillis) >= period)
// Change the period value depending on current relay state
if (relayState)
// Relay is currently on, set time to stay off
period = timeOff;
Serial.println("Relay off");
// Relay is currently off, set time to stay on
period = timeOn;
Serial.println("Relay on");
if (voltage < 12.5) // If voltage is less than 12.5 send email
Serial.println("Send bad battery email"); // Send me an email!
digitalWrite(13, HIGH); // Check is done! Turn relay back on
// Toggle the Relay's state
relayState = !(relayState);
// Restarts the time
startMillis = currentMillis;
