Guidance on a nema 23 stepper motor linear actuator system
Good evening
Wondering if it's possible to run off an Arduino uno the following, 12C LCD display, on/off switch, a potentiometer to change speed and also a forward jog button as well as a reverse jog button for a linear actuator system.
Any help much appreciated
Kind regards
Yes it is.
Thank you for your reply Jim was hoping I wouldn't be running out of pins as I'm unsure wether two proximity switches would run back to Arduino uno or if they would run back to the stepper driver ?
Thank you
Have no idea since you never said what driver you are using.
If you connect everything to the Uno you only need 6 pins, not including the driver
Ok yes definitely should have mentioned that the driver is a DM556. Hoping to run potentiometer, two (jog) buttons forward and reverse, on/off switch and two magnetic PNP proximity switches as stroke length adjustment of the actuator.
That driver only requires 3 more pins for control.
So no problem connecting everything to the Uno.
That's great thank you very much for your help Jim much appreciated it's a lot to take in when you're starting out that's for sure.
Cheers
I get the impression that your plan is to connect everything together and write one massive program and then begin testing. PLEASE don’t even begin that path. One step and one device at a time until you completely understand how each device works and your code for that device is bug free. Then begin a final program adding a device and code for it, step-wise again.
Paul, thank you for that advice definitely seems absolutely the best approach, do it in little steps make sure any issues are sorted out and then bring it all together, I will ask questions in programming forum just to make sure I sequence all the steps correctly once I am at that stage. I could also simplify it right down to just having an on off switch and two proximity switches either end as a start to lower the complexity as a complete novice it can be overwhelming
MAy I suggest you first get the LCD display working? Then you can use that to display debug messages.
That's a great suggestion Paul Thank you very much
I see you have several topics open regarding this project but you have never explained the purpose of your motor project. You don't have to but you may receive additional suggestions on how to proceed.
Jim, absolutely it is to automate linear actuation of a honing bench to hone cylinder bores.
Should not be to difficult, seem like you are going in the right direction.
I have only, ever, honed cylinders on car engines. That used an electric drill and lots of oil to flush the removed metal. Will you linear actuator move the stones fast enough and how will you lubricate?
Paul thank you , that's exactly it, it's already all in place electric drill and also has a pump for honing fluid just hoping to add the actuator to existing bench, actuator should be fast enough the stroke isn't as fast as automotive honing
Thank you Jim for your help much appreciated
You are welcome
