jwbernin:
Since the sampling will be done far more often than sending commands, it seems like I should have the interrupt processor trigger on serial input,
Strange idea. All serial input is stored in an serial input buffer by the Arduino core library. The core library uses interrupts to do so. You than can retrieve the serial input by "Serial.read()" at any time without any additional interrupt programming.
jwbernin:
not the timer,
Timer? Strange idea. The Arduino core library uses Timer0 to provide some timing functions for you like millis() or micros(). That's all you need.
jwbernin:
but everything I'm reading suggests that using an ISR for reading serial data is a Bad Idea(r)(tm).
Interrupt programming is used where it is needed, and NOT where things just get more and more complicated when using additional interrupts.
jwbernin:
Can anyone provide some input on what I'm planning, and any other (possibly better) ways I could go about it?
Here is some example framework which provided two "tasks" in the loop():
- handle_serial_input();
- send_temperature_samples();
The handle_serial_input() task will handle serial input lines which are ending with a end-of-line character. So if testing with the serial monitor be sure to set either "Carriage Return" or "Both NL&CR" as the line ending option. If a line with three parameters is detected, the input will be seperated at the space characters and printed seperately to serial.
The send_temperature_samples() function will send a fake message once per 5 minutes to serial.
char* serialInput()
{ // reads commands from Serial, return char pointer to command if detected
static char buf[31];
int count;
if (!Serial.available()) return NULL; // no command, return NULL pointer
delay(31); // small delay ==> wait for all chars of the command to arrive
memset(buf,0,sizeof(buf)); // clear command buffer
count=0; // clear number of chars in the command
while (Serial.available()) // while there is some Serial input ready
char c=Serial.read(); // read one char
if (count<sizeof(buf)-1 && c>=32) // does the char fit in the command buffer?
buf[count]=c; // Yes, insert char in command buffer
count++; // count the char
return buf; // return pointer to command buffer
void handle_serial_input()
char* command= serialInput(); // char pointer pointing to the command buffer
if (command!=NULL) // command ready
char *device= strtok(command," ");
char *action= strtok(NULL," ");
char *parameter= strtok(NULL," ");
Serial.print("RECEIVED: ");
if (parameter>NULL)
Serial.print(device);Serial.print(" | ");
Serial.print(action);Serial.print(" | ");
Serial.print(parameter);
else Serial.print(" ERROR");
#define SAMPLEINTERVAL 5*60000L // 5 minutes a 60000 milliseconds
void send_temperature_samples()
static unsigned long lastSampleSent;
if (millis()-lastSampleSent>=SAMPLEINTERVAL)
lastSampleSent+=SAMPLEINTERVAL;
Serial.println("Send temperature sample (FAKE VERSION)");
Serial.println("*** Good night and good luck ***");
