What am I doing?:
I am attempting to burn a bootloader onto an Arduino Ethernet using another Arduino as a software ISP (Arduino as ISP). So:
Board to be programmed: Arduino Ethernet
Board for Arduino as ISP: Arduino Duemilanove clone, Linksprite Diamondback
Why?:
I would like to remotely upload sketches via TFTP to the Arduino Ethernet. Ultimately would like to follow this process: Arduino Playground - TFTPBootloader1
What is wrong?:
As a preliminary test to make sure I can do this correctly, I am attempting to burn the bootloader through the Arduino IDE, using this walkthrough: https://www.arduino.cc/en/Tutorial/ArduinoISP
When attempting to finally program the Arduino Ethernet, I receive the following error:
avrdude: Version 6.3, compiled on Sep 12 2016 at 17:24:16
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino160\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega328
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.05s
avrdude: Device signature = 0x040404
avrdude: Expected signature for ATmega328 is 1E 95 14
Double check chip, or use -F to override this check.
avrdude done. Thank you.
Error while burning bootloader.
Did you check wiring?:
At least 10 times. I assume if my board does not use the standard SPI pins on (MOSI) 11, (MISO) 12 , and (SCK) 13, the ifndef will use a bitbang approach to force this to work. It would seem I am not quite that far along in thie process based on the device signature checksum error.
Questions:
Do I need a 10uF capacitor between reset and ground? Is that size fairly strict or is there an acceptable range?
Please shed some light on what I am doing incorrectly?
Do I need to just purchase an AVR ICP/ISP?
Notes:
I am using Arduino IDE 1.6.12.
