Guidance on switch statement
Hello everyone!
Hi have a question regarding how to use a switch statement for the Arduino IDE.
The thing is that if I declare a variable (i was testing with arrays) inside a case statement the switch function gets stuck on that statement. Reading I found that it requires to wrap the statement on '{}' to define the variable scope.
My question is, why is it necessary to wrap the case on {}? Why isn't the case entry self scoped? Can you help with some links on c++ info regarding to this example?
Example code here, it is for a 1 to 10 counter that resets at 10 and the switch is on handle of comparing the current second (method is for example purpouses):
unsigned long last_millis = 0;
byte state = 0;
Serial.println("Switch test");
  unsigned long current = millis();
  if (current - last_millis >= 1000){
    last_millis = current;
    state ++;
    if (state > 10){state = 0;}
    Serial.print(call_switch());
    Serial.println(" segs");
byte call_switch (){
  byte result = 0;
  switch (state){
    case 0:{
      int char_array = 0;
    break;}
    case 1:
      result = 1;
    case 2:
      result = 2;
    case 10:
      result = 10;
    default:
      result = 42;
  return result;
the braces delimit the code being processed by the switch similar to a while or for loop. the variables scope is external to the switch statement
The {} is required when you initialize a variable since if the switch skips "case 1" the variable value is undefined.
