Guidance to improve my code
Hi everyone,
I'm working on this project (a downtime tracker for one of my machine) utilizing NetDevilz PLX-DAQ v2.
My arduino has a simple LDR sensor attached to it with an RTC DS3231 module with it.
It records every second and with the help of PLX DAQ v2, it saves a .csv file into my personal computer every 15 minutes.
In order for it to save every 15 minutes, I set my code as so:
      if ((now.dayOfTheWeek() == 5 && seconds >= 46800 && seconds <= 52199) || (now.dayOfTheWeek() == 0 && seconds >= 52200 && seconds <= 80999))  {
      else {
        if (seconds == 81899) {  // save at 10:44.59pm
          //Serial.println((String)"SAVEWORKBOOKAS,J2_" + (now.year()) + "-" + (now.month()) + "-" + (now.day()));
          //Serial.println("CLEARDATA");
          if ((future.day()) > (now.day())) {
            Serial.println((String)"SAVEWORKBOOKAS,J2_" + (now.year()) + "-" + (now.month()) + "-" + (future.day()) + "_01" );
          else {
            Serial.println((String)"SAVEWORKBOOKAS,J2_" + (now.year()) + "-" + (future2.month()) + "-" + (future.day()) + "_01" );
        if (seconds == 82799) {  // save at 10:59.59pm
            Serial.println((String)"SAVEWORKBOOKAS,J2_" + (now.year()) + "-" + (now.month()) + "-" + (future.day()) + "_02" );
          else {
            Serial.println((String)"SAVEWORKBOOKAS,J2_" + (now.year()) + "-" + (future2.month()) + "-" + (future.day()) + "_02" );
        if (seconds == 83699) {  // save at 11:14.59pm
            Serial.println((String)"SAVEWORKBOOKAS,J2_" + (now.year()) + "-" + (now.month()) + "-" + (future.day()) + "_03" );
          else {
            Serial.println((String)"SAVEWORKBOOKAS,J2_" + (now.year()) + "-" + (future2.month()) + "-" + (future.day()) + "_03" );
        if (seconds == 84599) {  // save at 11:29.59pm
            Serial.println((String)"SAVEWORKBOOKAS,J2_" + (now.year()) + "-" + (now.month()) + "-" + (future.day()) + "_04" );
          else {
            Serial.println((String)"SAVEWORKBOOKAS,J2_" + (now.year()) + "-" + (future2.month()) + "-" + (future.day()) + "_04" );
        if (seconds == 85499) {  // save at 11:44.59pm
            Serial.println((String)"SAVEWORKBOOKAS,J2_" + (now.year()) + "-" + (now.month()) + "-" + (future.day()) + "_05" );
          else {
            Serial.println((String)"SAVEWORKBOOKAS,J2_" + (now.year()) + "-" + (future2.month()) + "-" + (future.day()) + "_05" );
        if (seconds == 86399) {  // save at 11:59.59pm
            Serial.println((String)"SAVEWORKBOOKAS,J2_" + (now.year()) + "-" + (now.month()) + "-" + (future.day()) + "_06" );
          else {
            Serial.println((String)"SAVEWORKBOOKAS,J2_" + (now.year()) + "-" + (future2.month()) + "-" + (future.day()) + "_06" );
        if (seconds == 899) {  // save at 12:14.59am
          Serial.println((String)"SAVEWORKBOOKAS,J2_" + (now.year()) + "-" + (now.month()) + "-" + (now.day()) + "_07" );
        if (seconds == 1799) {  // save at 12:29.59am
          Serial.println((String)"SAVEWORKBOOKAS,J2_" + (now.year()) + "-" + (now.month()) + "-" + (now.day()) + "_08" );
        if (seconds == 2699) {  // save at 12:44.59am
          Serial.println((String)"SAVEWORKBOOKAS,J2_" + (now.year()) + "-" + (now.month()) + "-" + (now.day()) + "_09" );
        if (seconds == 3599) {  // save at 12:59.59am
          Serial.println((String)"SAVEWORKBOOKAS,J2_" + (now.year()) + "-" + (now.month()) + "-" + (now.day()) + "_10" );
        if (seconds == 4499) {  // save at 01:14.59am
          Serial.println((String)"SAVEWORKBOOKAS,J2_" + (now.year()) + "-" + (now.month()) + "-" + (now.day()) + "_11" );
        if (seconds == 5399) {  // save at 01:29.59am
          Serial.println((String)"SAVEWORKBOOKAS,J2_" + (now.year()) + "-" + (now.month()) + "-" + (now.day()) + "_12" );
        //MAKAN TIME 1:30AM - 2:00AM
        if (seconds == 8099) {  // save at 02:14.59am
          Serial.println((String)"SAVEWORKBOOKAS,J2_" + (now.year()) + "-" + (now.month()) + "-" + (now.day()) + "_13" );
        if (seconds == 8999) {  // save at 02:29.59am
          Serial.println((String)"SAVEWORKBOOKAS,J2_" + (now.year()) + "-" + (now.month()) + "-" + (now.day()) + "_14" );
        if (seconds == 9899) {  // save at 02:44.59am
          Serial.println((String)"SAVEWORKBOOKAS,J2_" + (now.year()) + "-" + (now.month()) + "-" + (now.day()) + "_15" );
        if (seconds == 10799) {  // save at 02:59.59am
          Serial.println((String)"SAVEWORKBOOKAS,J2_" + (now.year()) + "-" + (now.month()) + "-" + (now.day()) + "_16" );
        if (seconds == 11699) {  // save at 03:14.59am
          Serial.println((String)"SAVEWORKBOOKAS,J2_" + (now.year()) + "-" + (now.month()) + "-" + (now.day()) + "_17" );
        if (seconds == 12599) {  // save at 03:29.59am
          Serial.println((String)"SAVEWORKBOOKAS,J2_" + (now.year()) + "-" + (now.month()) + "-" + (now.day()) + "_18" );
This is just a short snipper but I hope you understand what I mean. Now instead of 15 minutes, I would like to save every 5 minutes or even lesser. But that would mean I'll have to write and edit a very tasking long list of codes as what I've done for 15 minutes (about 90).
My question and request for help is that is there a more efficient way to code and accomplish what I want as per my example code above?
Much thanks.
sprintf() can be used to format strings. it can be used to format a base string with year, month and day which can subsequently be used to format a string with a suffix (e.g. "_02")
rather than explicitly check for seconds being at 15 min intervals, the same techniques using millis() can be used to when ((seconds - secondsLst) > 900)
You need to use a for loop in which the seconds thresholds are calculated using the index of the loop and the duration you want (5 or 15 minutes)
int durationMinutes = 5;
int numberOfIterations = 24 * 60 / durationMinutes; // Assuming the whole duration is 24 hours
for (int i = 0; i < numberOfIterations; i++) {
  int threshold = i * durationMinutes * 60;
          if (seconds == threshold ) {  // save at ...
            String suffix = "_" + String(i);
            Serial.println((String)"SAVEWORKBOOKAS,J2_" + (now.year()) + "-" + (now.month()) + "-" + (future.day()) + suffix );
          else {
            Serial.println((String)"SAVEWORKBOOKAS,J2_" + (now.year()) + "-" + (future2.month()) + "-" + (future.day()) + suffix );
This is just an example, not tested nor compiled...
Yes
Each time you save a data point, work out the time of the next save then test for that in loop(). That way you only ever have one test to perform
