Guidance with MATLAB compatibility
Hello everybody, this is my first post in this forum lots more to come I hope :) I am an engineering student in my final year at college and I am supposed to make a project (which will greatly affect my grades). I am planning on doing something related to Sound enhancement or noise reduction technique. I will be implementing it using MATLAB so the while testing my matlab code I will be giving it some sound signal with noise in it as input and should get enhanced sound as output.
Now, I was wondering if I can give the input, and get an output in hardware using ARDUINO maybe? Is it possible to burn the MATLAB code to ARDUINO ? All the help I get is appreciated. Thanks alot :)
You use "it" in this sentence three times - presumably to refer to three different things. It would be much better if you refrained from using "it" unless it is quite clear what "it" is.
The first "it" presumably refers to the project you are developing, but the second "it" could be any number of things. The third "it" presumably refers to the sound signal, but it is not clear what is getting the sound signal.
The Arduino is not very good at audio processing. It is far too slow, for the most part.
No.
I am very sorry I will refrain from using "it" I promise :) You are right my first "it" refers to the project which I am developing which is basically reduction of noise in any sound signal through adaptive and subtraction methods.
Second "it" refers again to my project and since I will be implementing this method in Matlab i will be testing my code on a pre-recorded noisy speech in .wav format so if everything works fine I should get noiseless speech as output.
Correct,third "it" refers to the sound signal.
Now, All of this will be done in software my guide says it is mandatory I use Matlab. But I have always been more of a hardware guy so,I want to take speech(with noise in the surrounding) as input through a microphone give it "some hardware" and get noiseless speech as output on a speaker.
I know that I can do this using a DSP. But I'll have to learn how to use one and code again (As I am already going to code in matlab).
So, Is there any option by which I can interface MATLAB to a hardware device? I know I can directly give input to the computer and process it using matlab but I'd still prefer an independent module. Please help. Thanks :)
Last year we have had a student who developed a PID system (+some more) in MATLAB and generated code for the Arduino from MATLAB. So although PaulS is technically right that you cannot run native MATLAB code on the Arduino directly, Matlab seems to have means to port a design to Arduino. Be aware that restrictions apply, e.g. the float datatype in Arduino is smaller than in MATLAB. I do not know which version of MATLAB was used, you can check MATLAB site for that
MatLab connects to the Arduino via a serial port, so the Arduino can send data to MatLab, and get data from MatLab.
The question, then, is what kind of data do you want to get from the Arduino? Audio data is not going to work. It takes too long to get a sample, and the send information about that sample to MatLab. The time it takes means that you will get a very poor representation of the audio data, due to far too few samples per second.
Audio data contains harmonics and frequencies that contribute to the sound quality (or lack thereof). Using a microphone as input to the Arduino will give you an average reading over some (small) period of time. The smaller the period of time, the closer you'll come to replicating, elsewhere, the data that you get from the microphone. The problem is that the time over which you sample is too long, and the time between samples is way too long.
So PaulS, as the original project goal was doing “Sound enhancement”, the rough / low bits / low freq sound data from the Arduino might be just the opportunity the OP is looking for.
