Guide for setting up Arduino <> PC wireless
I can buy from this store: http://proto-pic.co.uk
I know I need to get a:
  • XBee Adapter kit
  • XBee Module
  • FTDI cable
What's the cheapest possible combination I can get from that store that will work? Thanks!
If I understand you correctly for 28pounds you can get a working Arduino to PC xbee solution. using these 2 boards http://proto-pic.co.uk/xbee-explorer-regulated/ (to Arduino) http://proto-pic.co.uk/xbee-explorer-usb/ (PC, this contains a FTDI so you wont need the cable)
We have similar versions of these boards and they work well, although if you want a shield for the xbee Arduino end this one looks interesting http://proto-pic.co.uk/arduino-xbee-shield-empty/ and would make your total build a couple pounds cheaper.
But I would still have to buy two XBEE modules? That's another £40, no?
Here is another option that is not Xbee but, works nearly the same. It does not work with Xbee. Look over the specs and make sure this is good enough.
I have one and I like it.
http://www.pololu.com/catalog/product/2501
