Hi everyone,
I'm currently trying to build a datalogger with an ESP32-S3-WROOM-2, an I2C DS1307 RTC and a SPI2 microSD card reader.
I'm working by baby steps, and i'm currently trying to create a txt file on the SD card, name it with the date and time when the ESP32 boot up and after that, creating a new line every 2 seconds, with the current time and date, each time by reading the RTC.
But I'm facing an issue each time I'm trying to read a second time the RTC.
The strange part is that, if the ESP don't find a SD card, there is no issue with the time reading...
Here is the error -->
Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x420397f9 PS : 0x00060230 A0 : 0x82004f5a A1 : 0x3fcebba0
A2 : 0x3fcec900 A3 : 0x3fcebc09 A4 : 0x00000001 A5 : 0x00000000
A6 : 0x00000000 A7 : 0x00000000 A8 : 0x00000001 A9 : 0x39456001
A10 : 0xdffb0e68 A11 : 0x3c040838 A12 : 0x00000001 A13 : 0x0000ff00
A14 : 0x00ff0000 A15 : 0xff000000 SAR : 0x0000001c EXCCAUSE: 0x0000001c
EXCVADDR: 0xdffb0e68 LBEG : 0x400556d5 LEND : 0x400556e5 LCOUNT : 0xffffffff
Backtrace: 0x420397f6:0x3fcebba0 0x42004f57:0x3fcebbd0 0x42004dec:0x3fcebbf0 0x42002266:0x3fcebc30 0x4200271b:0x3fcebc80 0x4200c0a0:0x3fcebca0 0x4037f25a:0x3fcebcc0
Here is the exception decoder -->
PC: 0x420397f9: is in Adafruit_I2CDevice::write(unsigned char const*, unsigned int, bool, unsigned char const*, unsigned int) (d:\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp:115).
Decoding stack results
0x420397f6: is in Adafruit_I2CDevice::write(unsigned char const*, unsigned int, bool, unsigned char const*, unsigned int) (d:\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp:105).
0x42004f57: is in Adafruit_I2CDevice::write_then_read(unsigned char const*, unsigned int, unsigned char*, unsigned int, bool) (d:\Documents\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp:250).
0x42004dec: RTC_DS1307::now() at d:\Documents\Arduino\libraries\RTClib\src\RTC_DS1307.cpp:58
0x42002266: currentDT() at D:\Documents\Arduino\SD\SD.ino:121
0x4200271b: loop() at D:\Documents\Arduino\SD\SD.ino:151
0x4200c0a0: loopTask(void*) at C:\Users\chala\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.0.7\cores\esp32\main.cpp:74
0x4037f25a: vPortTaskWrapper at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/FreeRTOS-Kernel/portable/xtensa\port.c:162
And there is my code -->
#include <SD.h>
#include <SPI.h>
#include <ESP32Time.h>
#include "RTClib.h"
#include <Wire.h>
RTC_DS1307 rtc;
char daysOfTheWeek[7][12] = { "Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday" };
// Set up the pins for SPI2
const int spiClk = 18; // SCLK
const int spiMiso = 17; // MISO
const int spiMosi = 14; // MOSI
const int spiCs = 13; // CS
char title[20];
String CDT ="";
int i = 0;
// Initialize SPI2
SPIClass spi2(FSPI);
Wire.begin(15, 16);
if (!rtc.begin()) {
Serial.println("Couldn't find RTC");
Serial.flush();
while (1) delay(10);
//if (rtc.getYear()<2023){
//rtc.setTime(30, 24, 15, 17, 1, 2024);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// Initialize SPI2
spi2.begin(spiClk, spiMiso, spiMosi, spiCs);
// Initialize the SD card
if (!SD.begin(spiCs, spi2)) {
Serial.println("SD card initialization failed!");
return;
Serial.println("SD card initialization done.");
currentDT();
const char *bef = "/";
const char *ext = ".txt";
const char *tit = CDT.c_str();
strcpy(title, bef);
strcat(title, tit);
strcat(title, ext);
void listDir(fs::FS &fs, const char *dirname, uint8_t levels) {
Serial.printf("Listing directory: %s\n", dirname);
File root = fs.open(dirname);
if (!root) {
Serial.println("Failed to open directory");
return;
if (!root.isDirectory()) {
Serial.println("Not a directory");
return;
File file = root.openNextFile();
while (file) {
if (file.isDirectory()) {
Serial.print(" DIR : ");
Serial.println(file.name());
if (levels) {
listDir(fs, file.name(), levels - 1);
Serial.print(" FILE: ");
Serial.print(file.name());
Serial.print(" SIZE: ");
Serial.println(file.size());
void writeFile(fs::FS &fs, const char *path, const char *message) {
Serial.printf("Writing file: %s\n", path);
File file = fs.open(path, FILE_WRITE);
if (!file) {
Serial.println("Failed to open file for writing");
return;
if (file.print(message)) {
Serial.println("File written");
Serial.println("Write failed");
file.close();
void appendFile(fs::FS &fs, const char *path, const char *message) {
Serial.printf("Appending to file: %s\n", path);
File file = fs.open(path, FILE_APPEND);
if (!file) {
Serial.println("Failed to open file for appending");
return;
Serial.println("Message appended");
Serial.println("Append failed");
file.close();
void currentDT() {
Serial.println("2");
DateTime now = rtc.now();
Serial.println("3");
CDT = "";
CDT = String(now.year(), DEC);
if (now.month() < 10)
CDT += "0";
CDT = CDT + String(now.month());
if (now.day() < 10)
CDT += "0";
CDT = CDT + String(now.day()) + "_";
if (now.hour() < 10)
CDT += "0";
CDT = CDT + String(now.hour());
if (now.minute() < 10)
CDT += "0";
CDT = CDT + String(now.minute());
if (now.second() < 10)
CDT += "0";
CDT = CDT + String(now.second());
if (i == 0) {
writeFile(SD, title, "trtu");
Serial.println(title);
i = 1;
if (i == 1) {
delay(2000);
currentDT();
const char *toto = CDT.c_str();
appendFile(SD, title, toto);
i = 2;
Serial.println(toto);
if (i == 2) {
appendFile(SD, title, " Hello");
appendFile(SD, title, " World!\n");
delay(2000);
i = 1;
