my code
#include<Arduino.h>
#include "driver/uart.h"
#include <esp_task_wdt.h>
//#include "soc/timer_group_struct.h"
//#include "soc/timer_group_reg.h"
#include <AT24Cxx.h>
#include <MCP3XXX.h>
#include "soc/rtc.h"
#include<SPI.h>
#include <SD.h>
#include <ESP32Time.h>
#include <stdio.h>
#include <MCP342x.h>
#include "MAX17048.h"
#include<ArduinoJson.h>
#include<Wire.h>
#include<FS.h>
#include<String.h>
#include<SparkFunSX1509.h>
#include "Adafruit_SHTC3.h"
#include <Adafruit_Sensor.h>
#include <WiFi.h>
#include <ESP32WebServer.h>
#include "FS.h"
#include "SPIFFS.h"
#include "CSS.h"
#define ServerVersion "1.0"
#define i2c_address 0x50
#define FORMAT_SPIFFS_IF_FAILED true
#define pwrkey 4
#define NUMERO_PORTA_SERIALE UART_NUM_2
#define BUF_SIZE (1024 * 4)
#define RD_BUF_SIZE (1024)
#define U2RXD 16
#define U2TXD 17
String webpage = "";
String etyp;
int sts;
ESP32WebServer server(80);
AT24Cxx eep(i2c_address, 512);
File myFile;
MCP3004 ads;
hw_timer_t *My_timer = NULL;
static const BaseType_t pro_cpu = 0;
static const BaseType_t app_cpu = 1;
MAX17048 pwr_mgmt;
uint8_t addres = 0x68;
bool SPIFFS_present = false;
MCP342x adc = MCP342x(addres);
const byte SX1509_ADDRESS = 0x3E;
SX1509 io;
ESP32Time rtc(19800);
Adafruit_SHTC3 shtc3 = Adafruit_SHTC3();
const byte SX1509_LED_PIN1 = 13;
const byte SX1509_LED_PIN2 = 14;
const byte SX1509_LED_PIN3 = 15;
static const uint32_t taskDelay = 0;
static QueueHandle_t data_queue;
static QueueHandle_t device_id_queue;
static QueueHandle_t volt_queue1;
static QueueHandle_t volt_queue2;
static QueueHandle_t volt_queue3;
static QueueHandle_t current_queue1;
static QueueHandle_t current_queue2;
static QueueHandle_t current_queue3;
static QueueHandle_t temp_queue1;
static QueueHandle_t temp_queue2;
static QueueHandle_t slot_queue1;
static QueueHandle_t slot_queue2;
static QueueHandle_t command_queue;
static QueueHandle_t uart2_queue;
static const char * TAG = "";
uint8_t rxbuf[256]; //Buffer di ricezione
uint16_t rx_fifo_len; //Lunghezza dati
uint16_t num=0;
typedef struct Message{
char body[20];
int count;
}Message;
float fcg_L1V_high, fcg_L1V_low, fcg_L2V_high, fcg_L2V_low, fcg_L3V_high, fcg_L3V_low,fcg_L1C_high, fcg_L2C_high, fcg_L3C_high, fcg_L1C_LOW, fcg_L2C_LOW, fcg_L3C_LOW;
typedef struct Message1{
char body1[60];
String count;
}Message1;
int motor;
int sched_id;
String bcg_schedule_id1,startsrc;
long int count1;
char configu[3000];
void readFile2(fs::FS & fs,
const char * path) {
Serial.printf("Reading file: %s\r\n", path);
File file = fs.open(path);
if (!file || file.isDirectory()) {
Serial.println("- failed to open file for reading");
return;
int l;
Serial.println("- read from file:");
while (file.available()) {
configu[l++] = file.read();
configu[l] = '\0';
l = 0;
// Serial.print(configu);
file.close();
/*readFile*/
void readFile(fs::FS & fs,
char json[3000];
return;
int i;
json[i++] = file.read();
json[i] = '\0';
i = 0;
uart_write_bytes(UART_NUM_2,json, strlen(json));
file.close();
/*on timer*/
void IRAM_ATTR onTimer(){
count1++;
/*uart task*/
static void UART_ISR_ROUTINE(void *parameters)
uart_event_t event;
size_t buffered_size;
bool exit_condition = false;
char data1[2048];
char data2[2048];
char buf11[100];
memset(data1, '\0', sizeof(data1));
memset(data2, '\0', sizeof(data2));
memset(buf11, '\0', sizeof(buf11));
//Infinite loop to run main bulk of task
while (1) {
esp_task_wdt_init(30, false);
int flagX=0;
//Loop will continually block (i.e. wait) on event messages from the event queue
if(xQueueReceive(uart2_queue, (void * )&event,(portTickType)portMAX_DELAY)) {
// //Handle received event
if (event.type == UART_DATA) {
uint8_t UART2_data[2000];
static const int RX_BUF_SIZE = 1024;//321 byte need to be received at atime
int UART2_data_length = 0; //data length
ESP_ERROR_CHECK(uart_get_buffered_data_len(UART_NUM_2, (size_t*)&UART2_data_length));
// try to read 321 at once in upto 100 ticks
UART2_data_length = uart_read_bytes(UART_NUM_2, UART2_data, RX_BUF_SIZE, 100);
for(int i=0; i<UART2_data_length;i++)
data1[i]=((char)UART2_data[i]);
//Handle frame error event
else if (event.type == UART_FRAME_ERR) {
//TODO...
//Keep adding else if statements for each UART event you want to support
//else if (event.type == OTHER EVENT) {
//TODO...
//Final else statement to act as a default case
else {
//TODO...
//If you want to break out of the loop due to certain conditions, set exit condition to true
if (exit_condition) {
int flagC = 0;
Serial.println(data1);
for(int m=0;m<strlen(data1);m++){
if((data1[m]=='+')&&(data1[m+1]=='Q')&&(data1[m+2]=='L')&&(data1[m+3]=='T')&&(data1[m+4]=='S')){
if (strlen(data1) - 1 > 25) {
memcpy(buf11,data1,sizeof(data1));
flagX = 1;
for(int j=0;j<strlen(data1);j++){
if((data1[j]=='+')&&(data1[j+1]=='Q')&&(data1[j+2]=='M')&&(data1[j+3]=='T')&&(data1[j+4]=='R')&&(data1[j+5]=='E')&&(data1[j+6]=='C')&&(data1[j+7]=='V')){
Serial.println("+QMTRCEV matched");
int k=0;
while(data1[k] != '{') {
k++;
int f;
if(data1[k] == '{'){
for(f=0;f<strlen(data1);f++){
data2[f] = data1[k];
k++;
data2[f]='\0';
f=0;
Serial.println("split data print");
Serial.print(data2);
flagC = 1;
if(flagC==1) {
StaticJsonDocument < 1000 > doc;
DeserializationError error = deserializeJson(doc,data2 );
serializeJsonPretty(doc, Serial);
int command = doc["command_session"];
if (!(command == NULL)) {
xQueueOverwrite(command_queue, & command);
int device = doc["device_client_id"];
if (!(device == NULL)) {
xQueueOverwrite(device_id_queue, & device);
String Location = doc["Location"];
String FarmId = doc["FarmId"];
String Region = doc["Region"];
String fcg_first_confg = doc["fcg_first_confg"];
float fcg_motor_capacity_hp = doc["fcg_motor_capacity_hp"];
String fcg_motor_type_phase = doc["fcg_motor_type_phase"];
String fcg_starter_type = doc["fcg_starter_type"];
long int fcg_max_motor_runTime = doc["fcg_max_motor_runTime"];
String fcg_single_phase_protect = doc["fcg_single_phase_protect"];
String fcg_voltage_protection = doc["fcg_voltage_protection"];
String fcg_track_manual_trigger = doc["fcg_track_manual_trigger"];
float L1V_high = doc["fcg_L1V_high"];
if (!(L1V_high == NULL)) {
fcg_L1V_high=L1V_high;
float L1V_low = doc["fcg_L1V_low"];
if (!(L1V_low == NULL)) {
fcg_L1V_low=L1V_low;
float L1C_high = doc["fcg_L1C_high"];
if (!(L1C_high == NULL)) {
fcg_L1C_high=L1C_high;
float L1C_LOW = doc["fcg_L1C_LOW"];
if (!(L1C_LOW == NULL)) {
fcg_L1C_LOW=L1C_LOW;
float L2V_high = doc["fcg_L2V_high"];
if (!(L2V_high == NULL)) {
fcg_L2V_high=L2V_high;
float L2V_low = doc["fcg_L2V_low"];
if (!(L2V_low == NULL)) {
fcg_L2V_low=L2V_low;
float L2C_high = doc["fcg_L2C_high"];
if (!(L2C_high == NULL)) {
fcg_L2C_high=L2C_high;
float L2C_LOW = doc["fcg_L2C_LOW"];
if (!(L2C_LOW == NULL)) {
fcg_L2C_LOW=L2C_LOW;
float L3V_high = doc["fcg_L3V_high"];
if (!(L3V_high == NULL)) {
fcg_L3V_high=L3V_high;
float L3V_low = doc["fcg_L3V_low"];
if (!(L3V_low == NULL)) {
fcg_L3V_low=L3V_low;
float L3C_high = doc["fcg_L3C_high"];
if (!(L3C_high == NULL)) {
fcg_L3C_high=L3C_high;
float L3C_LOW = doc["fcg_L3C_LOW"];
if (!(L3C_LOW == NULL)) {
fcg_L3C_LOW=L3C_LOW;
float bcg_schedule_id = doc["bcg_schedule_id"];
Serial.print("bcg_schedule_id");
Serial.println(bcg_schedule_id);
if (!(bcg_schedule_id == NULL)) {
sched_id=bcg_schedule_id;
long int bcg_schedule_runTime_hrs = doc["bcg_schedule_runTime_hrs"];
int slot_begin = doc["bcg_schedule_slot_begin"];
if (!(slot_begin == NULL)) {
xQueueOverwrite(slot_queue2, & slot_begin);
int slot_end = doc["bcg_schedule_slot_end"];
if (!(slot_end == NULL)) {
xQueueOverwrite(slot_queue1, & slot_end);
int bcg_schedule_frequency = doc["bcg_schedule_frequency"];
String bcg_schedule_sts = doc["bcg_schedule_sts"];
String bcg_schedule_switch = doc["bcg_schedule_switch"];
String bcg_manual_switch_in_app = doc["bcg_manual_switch_in_app"];
byte cg_wifissid = doc["cg_wifissid"];
byte cg_wifipass = doc["cg_wifipass"];
int motorcon = doc["motor"];
if(!(motorcon==NULL)){
motor=motorcon;
if (flagX == 1) {
char * tmpbuf;
char * tmpbufi;
tmpbufi = strtok(buf11, ":");
char * y;
y = strtok(NULL, "/");
y = y + 2;
int z = atoi(y);
z = z + 2000;
tmpbuf = strtok(NULL, "/");
int b = atoi(tmpbuf);
tmpbuf = strtok(NULL, ",");
int c = atoi(tmpbuf);
tmpbuf = strtok(NULL, ":");
int i1 = atoi(tmpbuf);
int i2 = atoi(tmpbuf);
tmpbuf = strtok(NULL, "+");
int i3 = atoi(tmpbuf);
rtc.setTime(i3, i2, i1, c, b, z);
Serial.println(rtc.getTime("%A, %B %d %Y %H:%M:%S"));
struct tm timeinfo = rtc.getTimeStruct();
// TIMERG0.wdt_wprotect = TIMG_WDT_WKEY_VALUE;
// TIMERG0.wdt_feed = 1;
// TIMERG0.wdt_wprotect = 0;
// TIMERG1.wdt_wprotect = TIMG_WDT_WKEY_VALUE;
// TIMERG1.wdt_feed = 1;
// TIMERG1.wdt_wprotect = 0;
esp_task_wdt_reset();
disableLoopWDT();
feedLoopWDT();
vTaskDelay(1);
// vTaskDelay(10 / portTICK_PERIOD_MS);
Serial.printf("esp_task_wdt_delete: %d\n\n", esp_task_wdt_delete(NULL));
//Out side of loop now. Task needs to clean up and self terminate before returning
vTaskDelete(NULL);
/*preading*/
void preading(void * parameters) {
int16_t adc1, adc2, adc3;
long value1 = 0;
long value2 = 0;
long value3 = 0;
float VRMS1, VRMS2, VRMS3, AmpsRMS1, AmpsRMS2, L1C, L2C, L3C, AmpsRMS3, voltage1, voltage2, voltage3,
ANI0, ANI1, ANI2, volt1, volt2, volt3, tempareture, humudityper,bvoltage, bpercentage;
int deviceaddress = 0x44;
int slotend, slotbegin;
int flagA = 0;
unsigned int eeaddress = 0x50;
byte data = 00;
byte rdata = 0xFF;
char a;
int flagz = 0;
sensors_event_t event, temp, humidity;
while (1) {
vTaskDelay(1);
disableLoopWDT();
feedLoopWDT();
int flagB = 0;
ANI0 = (ads.analogRead(0));
ANI1 = (ads.analogRead(1));
ANI2 = (ads.analogRead(2));
volt1 = ((ANI0 / 1023) * 3.3);
volt2 = ((ANI1 / 1023) * 3.3);
volt3 = ((ANI2 / 1023) * 3.3);
volt1 = volt1 * 209;
volt2 = volt2 * 229;
volt3 = volt3 * 229;
// Serial.println("Step1");
if ((volt1 == 0) || (volt2 == 0) || (volt3 == 0)) {
flagB = 1;
if ((bvoltage < 3.5) && (flagB == 1)) {
sts = 0;
if ((flagB == 0)) {
sts = 1;
// Serial.println("Step2");
// Serial.print("fcg_L1V_high");
// Serial.println(fcg_L1V_high);
// Serial.print("fcg_L2V_high");
// Serial.println(fcg_L2V_high);
// Serial.print("fcg_L3V_high");
// Serial.println(fcg_L3V_high);
// Serial.print("fcg_LV_low");
// Serial.println(fcg_L2V_low);
// Serial.print("fcg_L2V_low");
// Serial.print("fcg_L3V_low");
// Serial.println(fcg_L3V_low);
MCP342x::Config status;
uint8_t err1 = adc.convertAndRead(MCP342x::channel1, MCP342x::continous,
MCP342x::resolution16, MCP342x::gain4,
10000, value1, status);
uint8_t err2 = adc.convertAndRead(MCP342x::channel2, MCP342x::continous,
10000, value2, status);
uint8_t err3 = adc.convertAndRead(MCP342x::channel3, MCP342x::continous,
MCP342x::resolution16, MCP342x::gain4 ,
10000, value3, status);
Serial.println("Step3");
voltage1 = abs(voltage1 = (float) value1);
voltage2 = abs(voltage2 = (float) value2);
voltage3 = abs(voltage3 = (float) value3);
VRMS1 = (voltage1 / 2.0) * 0.707;
VRMS2 = (voltage2 / 2.0) * 0.707;
VRMS3 = (voltage3 / 2.0) * 0.707;
AmpsRMS1 = VRMS1 / 30;
AmpsRMS2 = VRMS2 / 30;
AmpsRMS3 = VRMS3 / 30;
AmpsRMS1 = AmpsRMS1 + 25.30;
AmpsRMS2 = AmpsRMS2 + 25.30;
AmpsRMS3 = AmpsRMS3 + 25.30;
// Serial.print("fcg_L1C_high");
// Serial.println(fcg_L1C_high);
// Serial.print("fcg_L2C_high");
// Serial.println(fcg_L2C_high);
// Serial.print("fcg_L3C_high");
// Serial.println(fcg_L3C_high);
// Serial.print("fcg_L1C_LOW");
// Serial.println(fcg_L1C_LOW);
// Serial.print("fcg_L2C_LOW");
// Serial.println(fcg_L2C_LOW);
// Serial.print("fcg_L3C_LOW");
// Serial.println(fcg_L3C_LOW);
// Serial.println("Step4");
// shtc3.getEvent( & humidity, & temp);
// tempareture = temp.temperature;
// humudityper = humidity.relative_humidity;
// Serial.println("Step5");
// if(volt1>150){
// io.pinMode(SX1509_LED_PIN1, OUTPUT);
// else{
// io.pinMode(SX1509_LED_PIN1, LOW);
// if(volt2>150){
// io.pinMode(SX1509_LED_PIN2, OUTPUT);
// else{
// io.pinMode(SX1509_LED_PIN2, LOW);
// if(volt3>150){
// io.pinMode(SX1509_LED_PIN3, OUTPUT);
// else{
// io.pinMode(SX1509_LED_PIN3, LOW);
// io.blink(SX1509_LED_PIN1, 1000, 0);
// io.blink(SX1509_LED_PIN2, 1000, 0);
// io.blink(SX1509_LED_PIN3, 1000, 0);
// Serial.println("Step6");
bpercentage = (pwr_mgmt.accuratePercent());
bvoltage = (pwr_mgmt.voltage());
// Serial.println("Step7");
if (((fcg_L1V_high > volt1) && (volt1 > fcg_L1V_low) && (fcg_L2V_high > volt2) && (volt2 > fcg_L2V_low) && (fcg_L3V_high > volt3) && (volt3 > fcg_L3V_low) &&
(fcg_L1C_high > AmpsRMS1) && (AmpsRMS1 > fcg_L1C_LOW) && (fcg_L2C_high > AmpsRMS2) && (AmpsRMS2 > fcg_L2C_LOW) && (fcg_L3C_high > AmpsRMS3) && (AmpsRMS3 > fcg_L3C_LOW))) {
flagz = 0;
etyp = "T";
// Serial.println("Step8");
if (!((fcg_L1V_high > volt1) && (volt1 > fcg_L1V_low) && (fcg_L2V_high > volt2) && (volt2 > fcg_L2V_low) && (fcg_L3V_high > volt3) && (volt3 > fcg_L3V_low) &&
flagz = 1;
if (flagz == 1) {
etyp = "C";
startsrc = "OFF";
// Serial.println("Step9");
if ((motor == 1) && (flagz == 0)) {
digitalWrite(25, HIGH);
digitalWrite(26, HIGH);
startsrc = "App";
flagA = 0;
Serial.print("sched_id:");
Serial.println(sched_id);
Serial.print("motor:");
Serial.println(motor);
// Serial.println("Step10");
if ((sched_id > 3) && (motor!=1) && (flagz == 0)) {
String a;
xQueueReceive(slot_queue1, & slotend, 0);
xQueueReceive(slot_queue2, & slotbegin, 0);
String s;
s = rtc.getTime();
String b = (s.substring(0, 2));
String c = (s.substring(3, 5));
String d = (s.substring(6, 8));
int i1 = b.toInt();
int i2 = c.toInt();
int i3 = d.toInt();
int Time = ((i1 * 3600) + (i2 * 60) + i3 + 19800);
Serial.print("Time:");
Serial.println(Time);
Serial.print("slotbegin:");
Serial.println(slotbegin);
Serial.print("slotend:");
Serial.println(slotend);
if ((slotend > Time) && (Time > slotbegin)) {
startsrc = "bcg_schedule";
flagA = 0;
// Serial.println("Step11");
if ((sched_id < 3) && (motor!=1) && (AmpsRMS1 > 0.00) && (AmpsRMS2 > 0.00) && (AmpsRMS3 > 0.00)) {
startsrc = "ControlPanel";
if (((sched_id < 3) || (motor!=1))&&(flagA = 0)) {
digitalWrite(25, LOW);
digitalWrite(26, LOW);
flagA = 1;
startsrc="OFF";
// Serial.println("Step12");
String dataString = "";
dataString += String("Reading:-");
dataString += String("L1V:");
dataString += String(volt1);
dataString += String("V");
dataString += String(" ");
dataString += String("L2V:");
dataString += String(volt2);
dataString += String("L3V:");
dataString += String(volt3);
dataString += String("L1C:");
dataString += String(AmpsRMS1);
dataString += String("A");
dataString += String("L2C:");
dataString += String(AmpsRMS2);
dataString += String("L3C:");
dataString += String(AmpsRMS3);
dataString += String("Tempareture:");
dataString += String(tempareture);
dataString += String("degrees C");
dataString += String("humidity:");
dataString += String(humudityper);
dataString += String("% rH");
dataString += String("Batteryvoltage:");
dataString += String(bvoltage);
dataString += String("batteryLevel:");
dataString += String(bpercentage);
dataString += String("%");
// Serial.println("Step13");
xQueueOverwrite(volt_queue1, & volt1);
xQueueOverwrite(volt_queue2, & volt2);
xQueueOverwrite(volt_queue3, & volt3);
xQueueOverwrite(current_queue1, & AmpsRMS1);
xQueueOverwrite(current_queue2, & AmpsRMS2);
xQueueOverwrite(current_queue3, & AmpsRMS3);
// xQueueOverwrite(temp_queue1, & tempareture);
// xQueueOverwrite(temp_queue2, & humudityper);
bcg_schedule_id1 = String(sched_id);
xQueueOverwrite(data_queue, & dataString);
// Serial.println("Step14");
// esp_task_wdt_reset();
vTaskDelay(10);
vTaskDelete(NULL);
/* sdstoring*/
void sdstoring(void * parameters) {
String dataString;
while (1) {
xQueueReceive(data_queue, & dataString, 0);
File myFile = SD.open("/data.txt", FILE_APPEND);
myFile.println(dataString);
myFile.close();
disableLoopWDT();
feedLoopWDT();
vTaskDelay(10);
vTaskDelete(NULL);
/*aws task*/
void aws(void *parameters){
int i, ack;
char a;
timerAlarmEnable(My_timer); //Just Enable
float L1V, L2V, L3V, L1C, L2C, L3C, DT, DH;
// readFile(SPIFFS, "/jsonfile.json");
// delay(1000);
// StaticJsonDocument < 1024 > doc;
// DeserializationError error = deserializeJson(doc, configu);
// serializeJsonPretty(doc, Serial);
// Serial.println();
char json[] = "{\"command_session\":0,\"AccountId\":\"A500\",\"DeviceMode\":\"F\",\"Connection\":\"C600\",\"DeviceType\":\"c\",\"serial\":3000,\"SimId\":420,\"status\":\"Active\",\"device_client_id\":\"DL500\",\"Location\":\"venkatapuram\",\"FarmId\":\"F123\",\"Region\":\"bangalore\",\"fcg_first_confg\":\"x\",\"fcg_motor_capacity_hp\":10,\"fcg_motor_type_phase\":3,\"fcg_starter_type\":\"STOD\",\"fcg_max_motor_runTime\":3500,\"fcg_single_phase_protect\":1,\"fcg_voltage_protection\":1,\"fcg_track_manual_trigger\":0,\"fcg_L1V_high\":350,\"fcg_L1V_low\":150,\"fcg_L1C_high\":80,\"fcg_L1C_LOW\":0,\"fcg_L2V_high\":350,\"fcg_L2V_low\":150,\"fcg_L2C_high\":80,\"fcg_L2C_LOW\":0,\"fcg_L3V_high\":350,\"fcg_L3V_low\":150,\"fcg_L3C_high\":80,\"fcg_L3C_LOW\":0,\"bcg_schedule_id\":0,\"bcg_schedule_runTime_hrs\":10,\"bcg_schedule_slot_begin\":1,\"bcg_schedule_slot_end\":86399,\"bcg_schedule_frequency\":50,\"bcg_schedule_sts\":1,\"bcg_schedule_status\":1,\"bcg_schedule_switch\":0,\"bcg_manual_switch_in_app\":\"motor OFF\",\"cg_wifissid\":\"Riosh 2G\",\"cg_wifipass\":\"@1Riosh@1\"}";
DeserializationError error = deserializeJson(doc, json);
int command_session = doc["command_session"];
String AccountId = doc["AccountId"];
char DeviceMode = doc["DeviceMode"];
String Connection = doc["Connection"];
String DeviceType = doc["DeviceType"];
int serial = doc["serial"];
int SimId = doc["SimId"];
String Status1 = doc["status"];
String device_client_id = doc["device_client_id"];
fcg_L1V_high = doc["fcg_L1V_high"];
fcg_L1V_low = doc["fcg_L1V_low"];
fcg_L1C_high = doc["fcg_L1C_high"];
fcg_L1C_LOW = doc["fcg_L1C_LOW"];
fcg_L2V_high = doc["fcg_L2V_high"];
fcg_L2V_low = doc["fcg_L2V_low"];
fcg_L2C_high = doc["fcg_L2C_high"];
fcg_L2C_LOW = doc["fcg_L2C_LOW"];
fcg_L3V_high = doc["fcg_L3V_high"];
fcg_L3V_low = doc["fcg_L3V_low"];
fcg_L3C_high = doc["fcg_L3C_high"];
fcg_L3C_LOW = doc["fcg_L3C_LOW"];
sched_id = doc["bcg_schedule_id"];
int bcg_schedule_slot_begin = doc["bcg_schedule_slot_begin"];
int bcg_schedule_slot_end = doc["bcg_schedule_slot_end"];
// unsigned int address90 = 90;
// unsigned int address120 = 120;
// if (cg_wifipass !=NULL) {
// char str[10];
// sprintf(str, "%d", cg_wifipass);
// // str[j]='\0';
// for (int i = 0; str[i] != '\0'; i++) {
// eep.write(address90, str[i]);
// address90++;
// eep.write(address90, '\0');
// Serial.print("writeWIFIPASS:");
// Serial.println(str);
// char str[10];
// // str[j]='\0';
// eep.write(address120, str[i]);
// address120++;
// eep.write(address120, '\0');
xQueueOverwrite(slot_queue1, & bcg_schedule_slot_end);
xQueueOverwrite(slot_queue2, & bcg_schedule_slot_begin);
// xQueueOverwrite(bsvoltage_queue1, & fcg_L1V_high);
// xQueueOverwrite(bsvoltage_queue2, & fcg_L1V_low);
// xQueueOverwrite(bscurrent_queue1, & fcg_L1C_high);
// xQueueOverwrite(bscurrent_queue2, & fcg_L1C_LOW);
// xQueueOverwrite(bsvoltage_queue3, & fcg_L2V_high);
// xQueueOverwrite(bsvoltage_queue4, & fcg_L2V_low);
// xQueueOverwrite(bscurrent_queue3, & fcg_L2C_high);
// xQueueOverwrite(bscurrent_queue4, & fcg_L2C_LOW);
// xQueueOverwrite(bsvoltage_queue5, & fcg_L3V_high);
// xQueueOverwrite(bsvoltage_queue6, & fcg_L3V_low);
// xQueueOverwrite(bscurrent_queue5, & fcg_L3C_high);
// xQueueOverwrite(bscurrent_queue6, & fcg_L3C_LOW);
xQueueOverwrite(device_id_queue, & device_client_id);
String tpc = "";
tpc += String("/");
tpc += String(AccountId);
tpc += String("/");
tpc += String(device_client_id);
tpc += String("/");
tpc += String(FarmId);
tpc += String("/");
tpc += String(Connection);
tpc += String("/");
String msg1 = "";
String msg2 = "";
String cmd1 = "";
String cmd2 = "";
String at = "";
String at1 = "";
String at2 = "";
at += String("AT+QMTPUB=0,0,0,0,\"dv01/");
at1 += String("AT+QMTSUB=0,1,\"dv01/");
at2 += String("AT+QMTSUB=0,2,\"dv01/");
cmd1 += String(at1);
cmd1 += String("cmd");
cmd1 += String(tpc);
cmd1 += String("businessconfig\",1\r");
cmd2 += String(at2);
cmd2 += String("cmd");
cmd2 += String(tpc);
cmd2 += String("motorcontrol\",1\r");
msg1 += String(at);
msg1 += String("msg");
msg1 += String(tpc);
msg1 += String("tmetry\"\r");
//msg1 +=String("businesscloud\"\r");
msg2 += String(at);
msg2 += String("msg");
msg2 += String(tpc);
msg2 += String("cmdack\"\r");
Serial.println(cmd1);
Serial.println(cmd2);
Serial.println(msg1);
Serial.println(msg2);
char cmd11[100];
char cmd22[100];
char msg11[100];
char msg22[100];
char u=char(26);
strcpy(cmd11, cmd1.c_str());
strcpy(cmd22, cmd2.c_str());
strcpy(msg11, msg1.c_str());
strcpy(msg22, msg2.c_str());
uart_write_bytes(UART_NUM_2,cmd11, strlen(cmd11));
delay(2000);
uart_write_bytes(UART_NUM_2,cmd22, strlen(cmd22));
delay(2000);
while(1){
disableLoopWDT();
feedLoopWDT();
String mtyp = "S";
//Serial.print("count1:");
//Serial.println(count1);
if(count1 >15){
count1=0;
xQueueReceive(volt_queue1, & L1V, 0);
xQueueReceive(volt_queue2, & L2V, 0);
xQueueReceive(volt_queue3, & L3V, 0);
xQueueReceive(current_queue1, & L1C, 0);
xQueueReceive(current_queue2, & L2C, 0);
xQueueReceive(current_queue3, & L3C, 0);
// xQueueReceive(temp_queue1, & DT, 0);
// xQueueReceive(temp_queue2, & DH, 0);
uart_write_bytes(UART_NUM_2,msg11, strlen(msg11));
vTaskDelay(2000);
StaticJsonDocument<1000> doc;
JsonObject tmetry = doc.createNestedObject("tmetry");
tmetry["tstmp"]=(rtc.getTime("%d/%m/%Y:%H:%M:%S"));
tmetry["mtyp"]=mtyp;
tmetry["etyp"]=etyp;
tmetry["sts"]=sts;
tmetry["L1V"]=L1V;
tmetry["L2V"]=L2V;
tmetry["L3V"]=L3V;
tmetry["L1C"]=L1C;
tmetry["L2C"]=L2C;
tmetry["L3C"]=L3C;
tmetry["DT"]=DT;
tmetry["DH"]=DH;
tmetry["sched_id"]=bcg_schedule_id1;
tmetry["strt_src"]=startsrc;;
char output[1000];
memset(output, '\0', sizeof(output));
serializeJsonPretty( doc, output);
uart_write_bytes(UART_NUM_2,output, strlen(output));
uart_write_bytes(UART_NUM_2,&u, strlen(&u));
xQueueReceive(command_queue, & command_session, 0);
xQueueReceive(device_id_queue, & device_client_id, 0);
DynamicJsonDocument doc3(1024);
if (command_session == 100) {
String s;
s = rtc.getTime();
int i1 = b.toInt();
int i2 = c.toInt();
int i3 = d.toInt();
uart_write_bytes(UART_NUM_2,msg22, strlen(msg22));
vTaskDelay(2000);
JsonObject cmdack = doc3.createNestedObject("cmdack");
cmdack["command_session"] = command_session;
cmdack["ack_receipt_Time"] = Time;
cmdack["device_client_id"] = device_client_id;
cmdack["tstmp"] = (rtc.getTime("%d/%m/%Y:%H:%M:%S"));
char output1[500];
serializeJsonPretty(doc3, output1);
uart_write_bytes(UART_NUM_2,output1, strlen(output1));
//int flagM=0;
//if((L1V<150.00)&&(L2V<150.00)&&(L3V<150.00)){
// for(int j=0;j<60;j++){
// delay(1000);
// Serial2.print("AT+CFUN=0");
// delay(300);
// flagM=1;
//if((L1V>200.00)&&(L2V>200.00)&&(L3V>200.00)&&(flagM=1)){
// for(int j=0;j<30;j++){
// delay(1000);
// Serial2.print("AT+CFUN=1");
// delay(300);
// ESP.restart();
// delay(1000);
vTaskDelay(10);
//vTaskDelay(100/ portTICK_PERIOD_MS);
vTaskDelete(NULL);
void livemode(void *parameters){
char a,b;
Serial.print("Welcome to livemomde");
pinMode(32,OUTPUT);
digitalWrite(32,HIGH);
if (!SPIFFS.begin(true)) {
Serial.println("SPIFFS initialisation failed...");
Serial.println(F("SPIFFS initialised... file access enabled..."));
SPIFFS_present = true;
if (! shtc3.begin()) {
Serial.println("Couldn't find SHTC3");
while (1) ;
if (io.begin(SX1509_ADDRESS) == false)
Serial.println("Failed to communicate. Check wiring and address of SX1509.");
while (1);
io.clock(INTERNAL_CLOCK_2MHZ, 4);
Serial.print("Initializing SD card...");
if (SD.exists("example.txt")) {
Serial.println("example.txt exists.");
Serial.println("example.txt doesn't exist.");
pinMode(25,OUTPUT);
pinMode(26,OUTPUT);
uart_write_bytes(UART_NUM_2,"ATV1\r", strlen("ATV1\r"));
uart_write_bytes(UART_NUM_2,"ATE1\r", strlen("ATE1\r"));
uart_write_bytes(UART_NUM_2,"AT+CMEE=2\r", strlen("AT+CMEE=2\r"));
uart_write_bytes(UART_NUM_2,"AT+IPR?\r", strlen("T+IPR?\r"));
delay(300);
uart_write_bytes(UART_NUM_2,"ATI\r", strlen("ATI\r"));
delay(300);
uart_write_bytes(UART_NUM_2,"AT+GSN\r", strlen("AT+GSN\r"));
delay(300);
delay(300);
uart_write_bytes(UART_NUM_2,"AT+CPIN?\r", strlen("AT+CPIN?\r"));
delay(300);
uart_write_bytes(UART_NUM_2,"AT+CIMI\r", strlen("AT+CIMI\r"));
delay(300);
uart_write_bytes(UART_NUM_2,"AT+QCCID\r", strlen("AT+QCCID\r"));
delay(300);
uart_write_bytes(UART_NUM_2,"AT+CSQ\r", strlen("AT+CSQ\r"));
delay(300);
uart_write_bytes(UART_NUM_2,"AT+CREG?\r", strlen("AT+CREG?\r"));
delay(300);
uart_write_bytes(UART_NUM_2,"AT+CGREG?\r", strlen("AT+CGREG?\r"));
delay(300);
uart_write_bytes(UART_NUM_2,"AT+COPS?\r", strlen("AT+COPS?\r"));
delay(300);
delay(300);
delay(300);
delay(300);
delay(300);
delay(300);
delay(300);
uart_write_bytes(UART_NUM_2,"AT+QLTS=1\r", strlen("AT+QLTS=1\r"));
delay(300);
uart_write_bytes(UART_NUM_2,"AT+QIFGCNT=0\r", strlen("AT+QIFGCNT=0\r"));
delay(300);
uart_write_bytes(UART_NUM_2,"AT+QICSGP=1,\"airtelgprs.com\"\r", strlen("AT+QICSGP=1,\"airtelgprs.com\"\r"));
delay(300);
uart_write_bytes(UART_NUM_2,"AT+QIREGAPP\r", strlen("AT+QIREGAPP\r"));
delay(300);
uart_write_bytes(UART_NUM_2,"AT+QIACT\r", strlen("AT+QIACT\r"));
delay(300);
uart_write_bytes(UART_NUM_2,"AT+QSECREAD=\"NVRAM:CA0\"\r", strlen("AT+QSECREAD=\"NVRAM:CA0\"\r"));
delay(300);
uart_write_bytes(UART_NUM_2,"AT+QSECREAD=\"NVRAM:CC0\"\r", strlen("AT+QSECREAD=\"NVRAM:CC0\"\r"));
delay(300);
uart_write_bytes(UART_NUM_2,"AT+QSECREAD=\"NVRAM:CK0\"\r", strlen("AT+QSECREAD=\"NVRAM:CK0\"\r"));
delay(300);
uart_write_bytes(UART_NUM_2,"AT+QSSLCFG=\"cacert\",0,\"NVRAM:CA0\"\r", strlen("AT+QSSLCFG=\"cacert\",0,\"NVRAM:CA0\"\r"));
delay(300);
uart_write_bytes(UART_NUM_2,"AT+QSSLCFG=\"clientcert\",0,\"NVRAM:CC0\"\r", strlen("AT+QSSLCFG=\"clientcert\",0,\"NVRAM:CC0\"\r"));
delay(300);
uart_write_bytes(UART_NUM_2,"AT+QSSLCFG=\"clientkey\",0,\"NVRAM:CK0\"\r", strlen("AT+QSSLCFG=\"clientkey\",0,\"NVRAM:CK0\"\r"));
delay(300);
uart_write_bytes(UART_NUM_2,"AT+QSSLCFG=\"seclevel\",0,2\r", strlen("AT+QSSLCFG=\"seclevel\",0,2\r"));
delay(300);
uart_write_bytes(UART_NUM_2,"AT+QSSLCFG=\"sslversion\",0,4\r", strlen("AT+QSSLCFG=\"sslversion\",0,4\r"));
delay(300);
uart_write_bytes(UART_NUM_2,"AT+QSSLCFG=\"ciphersuite\",0,\"0xFFFF\"\r", strlen("AT+QSSLCFG=\"ciphersuite\",0,\"0xFFFF\"\r"));
delay(300);
uart_write_bytes(UART_NUM_2,"AT+QSSLCFG=\"ignorertcTime\",1\r", strlen("AT+QSSLCFG=\"ignorertcTime\",1\r"));
delay(300);
uart_write_bytes(UART_NUM_2,"AT+QMTCFG=\"ssl\",0,1,0\r", strlen("AT+QMTCFG=\"ssl\",0,1,0\r"));
delay(300);
uart_write_bytes(UART_NUM_2,"AT+QMTOPEN=0,\"a38zppqrq5r0ag-ats.iot.ap-south-1.amazonaws.com\",8883\r", strlen("AT+QMTOPEN=0,\"a38zppqrq5r0ag-ats.iot.ap-south-1.amazonaws.com\",8883\r"));
delay(20000);
uart_write_bytes(UART_NUM_2,"AT+QMTCONN=0,\"dv01\"\r", strlen("AT+QMTCONN=0,\"dv01\"\r"));
delay(5000);
disableCore0WDT();
disableCore1WDT();
esp_err_t esp_task_wdt_delete(TaskHandle_t handle);
xTaskCreatePinnedToCore(preading,
"Task 0",
5120,
NULL,
3,
NULL,
tskNO_AFFINITY);
xTaskCreatePinnedToCore(sdstoring,
"Task 1",
5120,
NULL,
1,
NULL,
tskNO_AFFINITY);
xTaskCreatePinnedToCore(aws,
"Task 1",
20000,
NULL,
2,
NULL,
tskNO_AFFINITY);
//Delete "setup and loop" task
vTaskDelete(NULL);
void configurationmode(void *parameters){
char a;
unsigned int address25 = 0;
unsigned int address26 = 30;
unsigned int address27 = 60;
int m = 0;
char str1[10];
char str2[10];
char str3[10];
do {
str1[m++] = eep.read(address25);
address25++;
} while (str1[m - 1] != '\0');
Serial.print("str1:");
Serial.println(str1);
do {
str1[m++] = eep.read(address26);
address26++;
Serial.print("str2:");
Serial.println(str2);
do {
str1[m++] = eep.read(address27);
address27++;
Serial.print("str3:");
Serial.println(str3);
delay(300);
delay(300);
delay(300);
delay(300);
delay(300);
delay(300);
delay(300);
delay(300);
delay(300);
delay(300);
delay(300);
delay(300);
delay(300);
delay(300);
delay(300);
delay(300);
delay(300);
delay(300);
delay(300);
Serial2.print("AT+QICSGP=1,\"airtelgprs.com\"\r");
delay(300);
delay(300);
delay(300);
uart_write_bytes(UART_NUM_2,"AT+QSECWRITE=\"NVRAM:CC0\",", strlen("AT+QSECWRITE=\"NVRAM:CC0\","));
uart_write_bytes(UART_NUM_2,str3, strlen(str3));
uart_write_bytes(UART_NUM_2,",100\r", strlen(",100\r"));
delay(300);
readFile(SPIFFS, "/certificate.pem.crt");
uart_write_bytes(UART_NUM_2,"AT+QSECWRITE=\"NVRAM:CK0\",", strlen("AT+QSECWRITE=\"NVRAM:CK0\","));
uart_write_bytes(UART_NUM_2,str1, strlen(str1));
delay(300);
readFile(SPIFFS, "/private.pem.key");
uart_write_bytes(UART_NUM_2,"AT+QSECWRITE=\"NVRAM:CA0\",", strlen("AT+QSECWRITE=\"NVRAM:CA0\","));
uart_write_bytes(UART_NUM_2,str2, strlen(str2));
delay(300);
readFile(SPIFFS, "/rootca.pem");
delay(300);
delay(300);
delay(300);
delay(300);
delay(300);
delay(300);
delay(300);
delay(300);
delay(300);
delay(300);
delay(75000);
delay(10000);
uart_write_bytes(UART_NUM_2,"AT+QMTCONN=0,\"\r", strlen("AT+QMTCONN=0,\"dv_dev_test_1\"\r"));
void runmode(void *parameters){
int b;
int c=22; // dummy Addressing passing
Serial.println("Please select the which run mode");
Serial.println("1.Configure mode");
Serial.println("2.Live mode");
Serial.flush();
while(Serial.available()==0) {}
b=Serial.parseInt();
if(b==1)
Serial.println("Welcome to configuration mode");
configurationmode(&c);
if(b==2)
Serial.println("Welcome to Live mode");
xTaskCreatePinnedToCore(UART_ISR_ROUTINE,
"UART_ISR_ROUTINE",
10120,
NULL,
1,
NULL,
tskNO_AFFINITY);
//vTaskDelete(NULL);
// xTaskCreate(UART_ISR_ROUTINE,
// "UART_ISR_ROUTINE",
// 10120,
// NULL,
// 1,
// NULL);
livemode(&c);
if(b>2||b<0)
Serial.print("Selected Wrong mode");
//ESP.restart();
void factorymode(void * parameters) {
Serial.print("Welcome to configure mode");
// unsigned int address1=0;
// unsigned int address2=0;
// readEEPROM(eeprom, address);
const char ssid[] = "Riosh 2G";
const char password[] = "@1Riosh@1";
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) { // Wait for the Wi-Fi to connect
delay(250);
Serial.print('.');
Serial.println("\nConnected to " + WiFi.SSID() + " Use IP address: " + WiFi.localIP().toString()); // Report which SSID and IP is in use
///////////////////////////// Server Commands
server.on("/", HomePage);
server.on("/Firstconfig", File_Upload);
server.on("/fupload", HTTP_POST, []() {
server.send(200);
}, handleFileUpload);
server.on("/lisence", File_Upload);
server.send(200);
server.on("/privatekey", File_Upload);
server.send(200);
server.on("/RootCAcert", File_Upload);
server.send(200);
server.on("/delete", File_Delete);
///////////////////////////// End of Request commands
server.begin();
Serial.println("HTTP server started");
int b;
int c=22;
char a;
pinMode(pwrkey,OUTPUT);
digitalWrite(pwrkey,LOW);
delay(2000);
digitalWrite(pwrkey,HIGH);
delay(2000);
SPI.begin();
ads.begin(15,13,12,14);
while (!Serial) {
delay(4000);
while(Serial.available()>0){
a=Serial.read();
Serial.print(a);
My_timer = timerBegin(0, 80, true);
timerAttachInterrupt(My_timer, &onTimer, true);
timerAlarmWrite(My_timer, 1000000, true);
esp_err_t esp_task_wdt_reset(void); // Reset calling task' the Task Watchdog timer
if (!SD.begin(5)) {
Serial.println("initialization failed!");
while (1);
Serial.println("initialization done.");
// open a new file and immediately close it:
Serial.println("Creating example.txt...");
myFile = SD.open("example.txt", FILE_WRITE);
myFile.close();
// Check to see if the file exists:
// delete the file:
Serial.println("Removing example.txt...");
SD.remove("example.txt");
Wire.begin();
pwr_mgmt.attatch(Wire);
uart_config_t Configurazione_UART2 = {
.baud_rate = 115200,
.data_bits = UART_DATA_8_BITS,
.parity = UART_PARITY_DISABLE,
.stop_bits = UART_STOP_BITS_1,
.flow_ctrl = UART_HW_FLOWCTRL_DISABLE
uart_param_config(NUMERO_PORTA_SERIALE, &Configurazione_UART2);
esp_err_t uart_disable_pattern_det_intr(uart_port_t uart_num2);
//Firma: void esp_log_level_set(const char *tag, esp_log_level_tlevel)
esp_log_level_set(TAG, ESP_LOG_INFO);
//Firma: esp_err_tuart_set_pin(uart_port_tuart_num, int tx_io_num, int rx_io_num, int rts_io_num, int cts_io_num)
uart_set_pin(NUMERO_PORTA_SERIALE, U2TXD, U2RXD, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE);
//Firma: uart_driver_install(UART_NUM_2, uart_buffer_size, uart_buffer_size, 10, &uart_queue, 0));
// uart_driver_install(Numero_porta, RXD_BUFFER, TXD_Buffer, event queue handle and size, flags to allocate an interrupt)
uart_driver_install(NUMERO_PORTA_SERIALE, BUF_SIZE, BUF_SIZE, 20, &uart2_queue, 0);
// esp_task_wdt_init(WDT_TIMEOUT, false); //enable panic so ESP32 restarts
// esp_task_wdt_add(NULL);
data_queue = xQueueCreate(1, sizeof(Message1));
volt_queue1 = xQueueCreate(1, sizeof(Message));
volt_queue2 = xQueueCreate(1, sizeof(Message));
volt_queue3 = xQueueCreate(1, sizeof(Message));
current_queue1 = xQueueCreate(1, sizeof(Message));
current_queue2 = xQueueCreate(1, sizeof(Message));
current_queue3 = xQueueCreate(1, sizeof(Message));
temp_queue1 = xQueueCreate(1, sizeof(Message));
temp_queue2 = xQueueCreate(1, sizeof(Message));
command_queue = xQueueCreate(1, sizeof(Message));
slot_queue1 = xQueueCreate(1, sizeof(Message));
slot_queue2 = xQueueCreate(1, sizeof(Message));
device_id_queue = xQueueCreate(1, sizeof(Message));
MCP342x::generalCallReset();
delay(1);
// Check device present
Serial.println("WELCOME TO IOT WORLD");
Serial.println("1.Factory mode");
Serial.println("2.Run mode mode");
Serial.flush();
long long counter = millis();
while (Serial.available() == 0) {
if (millis() - counter > (60 * 1000)) {
Serial.println("time exceeded and no inputs");
"UART_ISR_ROUTINE",
10120,
NULL,
1,
NULL,
tskNO_AFFINITY);
//xTaskCreate(UART_ISR_ROUTINE,
// 10120,
// NULL,
// 1,
// NULL);
livemode(NULL);
if(b==1)
Serial.println("Welcome to Factory mode");
factorymode(&c);
while(b==2)
Serial.println("Welcome to Run mode");
runmode(&c);
if(b>2||b<0)
// ESP.restart();
void loop(void){
server.handleClient();
void SendHTML_Content(){
server.sendContent(webpage);
webpage = "";
void File_Upload(){
append_page_header();
webpage += F("<h3>Select File to Upload</h3>");
webpage += F("<FORM action='/fupload' method='post' enctype='multipart/form-data'>");
webpage += F("<input class='buttons' style='width:40%' type='file' name='fupload' id = 'fupload' value=''><br>");
webpage += F("<br><button class='buttons' style='width:10%' type='submit'>Upload File</button><br>");
webpage += F("<a href='/'>[Back]</a><br><br>");
append_page_footer();
server.send(200, "text/html",webpage);
String file_size(int bytes){
String fsize = "";
if (bytes < 1024) fsize = String(bytes)+" B";
else if(bytes < (1024*1024)) fsize = String(bytes/1024.0,3)+" KB";
else if(bytes < (1024*1024*1024)) fsize = String(bytes/1024.0/1024.0,3)+" MB";
else fsize = String(bytes/1024.0/1024.0/1024.0,3)+" GB";
return fsize;
void SendHTML_Stop(){
server.sendContent("");
server.client().stop(); // Stop is needed because no content length was sent
void SendHTML_Header(){
server.sendHeader("Cache-Control", "no-cache, no-store, must-revalidate");
server.sendHeader("Pragma", "no-cache");
server.sendHeader("Expires", "-1");
server.setContentLength(CONTENT_LENGTH_UNKNOWN);
server.send(200, "text/html", ""); // Empty content inhibits Content-length header so we have to close the socket ourselves.
webpage = "";
void ReportCouldNotCreateFile(String target){
SendHTML_Header();
webpage += F("<h3>Could Not Create Uploaded File (write-protected?)</h3>");
webpage += F("<a href='/"); webpage += target + "'>[Back]</a><br><br>";
SendHTML_Content();
SendHTML_Stop();
File UploadFile;
void handleFileUpload(){ // upload a new file to the Filing system
HTTPUpload& uploadfile = server.upload();
if(uploadfile.status == UPLOAD_FILE_START)
String filename = uploadfile.filename;
if(!filename.startsWith("/")) filename = "/"+filename;
Serial.print("Upload File Name: "); Serial.println(filename);
SPIFFS.remove(filename); // Remove a previous version, otherwise data is appended the file again
UploadFile = SPIFFS.open(filename, "w"); // Open the file for writing in SPIFFS (create it, if doesn't exist)
else if (uploadfile.status == UPLOAD_FILE_WRITE)
if(UploadFile) UploadFile.write(uploadfile.buf, uploadfile.currentSize); // Write the received bytes to the file
else if (uploadfile.status == UPLOAD_FILE_END)
if(UploadFile) // If the file was successfully created
UploadFile.close(); // Close the file again
Serial.print("Upload Size: ");
Serial.println(uploadfile.totalSize);
Serial.print("uploadfile.filename");
Serial.print(uploadfile.filename);
String filename1 = uploadfile.filename;
int j = 0;
if (filename1 == "private.pem.key") {
char str[10];
sprintf(str, "%d", uploadfile.totalSize);
// str[j]='\0';
eep.write(address25, str[i]);
address25++;
eep.write(address25, '\0');
Serial.print("writeEEPROM1:");
if (filename1 == "rootca.pem") {
char str1[10];
sprintf(str1, "%d", uploadfile.totalSize);
// str1[j]='\0';
for (int i = 0; str1[i] != '\0'; i++) {
eep.write(address26, str1[i]);
address26++;
eep.write(address26, '\0');
Serial.print("writeEEPROM2:");
Serial.print(str1);
if (filename1 == "certificate.pem.crt") {
char str2[10];
sprintf(str2, "%d", uploadfile.totalSize);
// str2[j]='\0';
for (int i = 0; str2[i] != '\0'; i++) {
eep.write(address27, str2[i]);
address27++;
eep.write(address27, '\0');
Serial.print("writeEEPROM3:");
Serial.print(str2);
webpage = "";
webpage += F("<h3>File was successfully uploaded</h3>");
webpage += F("<h2>Uploaded File Name: "); webpage += uploadfile.filename+"</h2>";
webpage += F("<h2>File Size: "); webpage += file_size(uploadfile.totalSize) + "</h2><br>";
server.send(200,"text/html",webpage);
ReportCouldNotCreateFile("upload");
void ReportSPIFFSNotPresent(){
SendHTML_Header();
webpage += F("<h3>No SPIFFS Card present</h3>");
SendHTML_Content();
SendHTML_Stop();
void ReportFileNotPresent(String target){
SendHTML_Header();
webpage += F("<h3>File does not exist</h3>");
SendHTML_Content();
SendHTML_Stop();
void SPIFFS_file_delete(String filename) { // Delete the file
if (SPIFFS_present) {
SendHTML_Header();
File dataFile = SPIFFS.open("/"+filename, "r"); // Now read data from SPIFFS Card
if (dataFile)
if (SPIFFS.remove("/"+filename)) {
Serial.println(F("File deleted successfully"));
webpage += "<h3>File '"+filename+"' has been erased</h3>";
webpage += F("<a href='/delete'>[Back]</a><br><br>");
webpage += F("<h3>File was not deleted - error</h3>");
webpage += F("<a href='delete'>[Back]</a><br><br>");
} else ReportFileNotPresent("delete");
SendHTML_Content();
SendHTML_Stop();
} else ReportSPIFFSNotPresent();
void SelectInput(String heading1, String command, String arg_calling_name){
SendHTML_Header();
webpage += F("<h3>"); webpage += heading1 + "</h3>";
webpage += F("<FORM action='/"); webpage += command + "' method='post'>"; // Must match the calling argument e.g. '/chart' calls '/chart' after selection but with arguments!
webpage += F("<input type='text' name='"); webpage += arg_calling_name; webpage += F("' value=''><br>");
webpage += F("<type='submit' name='"); webpage += arg_calling_name; webpage += F("' value=''><br><br>");
SendHTML_Content();
SendHTML_Stop();
void File_Delete(){
if (server.args() > 0 ) { // Arguments were received
if (server.hasArg("delete")) SPIFFS_file_delete(server.arg(0));
else SelectInput("Select a File to Delete","delete","delete");
void HomePage(){
SendHTML_Header();
webpage += F("<a href='/upload1'><button>Upload</button></a>");
webpage += F("<a href='/upload2'><button>Upload</button></a>");
webpage += F("<a href='/upload3'><button>Upload</button></a>");
SendHTML_Content();
SendHTML_Stop(); // Stop is needed because no content length was sent
void writeEEPROM(int deviceaddress, unsigned int eeaddress, byte data ) {
Wire.beginTransmission(deviceaddress);
Wire.write((int)(eeaddress >> 8)); //writes the MSB
Wire.write((int)(eeaddress & 0xFF)); //writes the LSB
Wire.write(data);
Wire.endTransmission();
byte readEEPROM(int deviceaddress, unsigned int eeaddress ) {
byte rdata = 0xFF;
Wire.requestFrom(deviceaddress,1);
if (Wire.available())
rdata = Wire.read();
return rdata;
/* new file*/
// #include<Arduino.h>
// #include"CSS.h"
extern String webpage;
void append_page_header() {
webpage = F("<!DOCTYPE html><html>");
webpage += F("<head>");
webpage += F("<title>File Server</title>"); // NOTE: 1em = 16px
webpage += F("<meta name='viewport' content='user-scalable=yes,initial-scale=1.0,width=device-width'>");
webpage += F("<style>");
webpage += F("body{max-width:65%;margin:0 auto;font-family:arial;font-size:105%;text-align:center;color:blue;background-color:#F7F2Fd;}");
webpage += F("ul{list-style-type:none;margin:0.1em;padding:0;border-radius:0.375em;overflow:hidden;background-color:#dcade6;font-size:1em;}");
webpage += F("li{float:left;border-radius:0.375em;border-right:0.06em solid #bbb;}last-child {border-right:none;font-size:85%}");
webpage += F("li a{display: block;border-radius:0.375em;padding:0.44em 0.44em;text-decoration:none;font-size:85%}");
webpage += F("li a:hover{background-color:#EAE3EA;border-radius:0.375em;font-size:85%}");
webpage += F("section {font-size:0.88em;}");
webpage += F("h1{color:white;border-radius:0.5em;font-size:1em;padding:0.2em 0.2em;background:#558ED5;}");
webpage += F("h2{color:orange;font-size:1.0em;}");
webpage += F("h3{font-size:0.8em;}");
webpage += F("table{font-family:arial,sans-serif;font-size:0.9em;border-collapse:collapse;width:85%;}");
webpage += F("th,td {border:0.06em solid #dddddd;text-align:left;padding:0.3em;border-bottom:0.06em solid #dddddd;}");
webpage += F("tr:nth-child(odd) {background-color:#eeeeee;}");
webpage += F(".rcorners_n {border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:20%;color:white;font-size:75%;}");
webpage += F(".rcorners_m {border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:50%;color:white;font-size:75%;}");
webpage += F(".rcorners_w {border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:70%;color:white;font-size:75%;}");
webpage += F(".column{float:left;width:50%;height:45%;}");
webpage += F(".row:after{content:'';display:table;clear:both;}");
webpage += F("*{box-sizing:border-box;}");
webpage += F("footer{background-color:#eedfff; text-align:center;padding:0.3em 0.3em;border-radius:0.375em;font-size:60%;}");
webpage += F("button{border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:20%;color:white;font-size:130%;}");
webpage += F(".buttons {border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:15%;color:white;font-size:80%;}");
webpage += F(".buttonsm{border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:9%; color:white;font-size:70%;}");
webpage += F(".buttonm {border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:15%;color:white;font-size:70%;}");
webpage += F(".buttonw {border-radius:0.5em;background:#558ED5;padding:0.3em 0.3em;width:40%;color:white;font-size:70%;}");
webpage += F("a{font-size:75%;}");
webpage += F("p{font-size:75%;}");
webpage += F("</style></head><body><h1>File Server "); webpage += String(ServerVersion) + "</h1>";
void append_page_footer(){ // Saves repeating many lines of code for HTML page footers
webpage += F("<ul>");
webpage += F("<li><a href='/'>Home</a></li>"); // Lower Menu bar command entries
webpage += F("<li><a href='/Firstconfig'>Firstconfig</a></li>");
webpage += F("<li><a href='/lisence'>lisence</a></li>");
webpage += F("<li><a href='/privatekey'>privatekey</a></li>");
webpage += F("<li><a href='/RootCAcert'>RootCAcert</a></li>");
webpage += F("<li><a href='/delete'>Delete</a></li>");
webpage += F("</ul>");
webpage += F("</body></html>");
