Bonjour,
un esp32 et un bme280, envoie la température la pression et l'humidité à une page php.
la page php reçoit bien les données qu'elle écrit dans la base sql.
Mais j'ai des erreurs, qui font rebooter l'esp32 avant la fin du delay.
Copie du moniteur série
Rebooting...
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1344
load:0x40078000,len:13924
ho 0 tail 12 room 4
load:0x40080400,len:3600
entry 0x400805f0
E (219) psram: PSRAM ID read error: 0xffffffff
Connecting to: Freebox-XXXXXX
......Internet connected
HTTP_EVENT_ON_CONNECTED
HTTP_EVENT_HEADER_SENT
HTTP_EVENT_ON_HEADER, key=Server, value=nginx
HTTP_EVENT_ON_HEADER, key=Date, value=Thu, 22 Jun 2023 17:42:17 GMT
HTTP_EVENT_ON_HEADER, key=Content-Type, value=text/html; charset=UTF-8
HTTP_EVENT_ON_HEADER, key=Transfer-Encoding, value=chunked
HTTP_EVENT_ON_HEADER, key=Connection, value=keep-alive
HTTP_EVENT_ON_HEADER, key=X-SSO-WAT, value=You've just been SSOed
HTTP_EVENT_ON_HEADER, key=Content-Security-Policy, value=upgrade-insecure-requests
HTTP_EVENT_ON_HEADER, key=X-Content-Type-Options, value=nosniff
HTTP_EVENT_ON_HEADER, key=X-XSS-Protection, value=1; mode=block
HTTP_EVENT_ON_HEADER, key=X-Download-Options, value=noopen
HTTP_EVENT_ON_HEADER, key=X-Permitted-Cross-Domain-Policies, value=none
HTTP_EVENT_ON_HEADER, key=X-Frame-Options, value=SAMEORIGIN
HTTP_EVENT_ON_HEADER, key=Permissions-Policy, value=interest-cohort=()
HTTP_EVENT_ON_HEADER, key=Strict-Transport-Security, value=max-age=63072000; includeSubDomains; preload
HTTP_EVENT_ON_DATA, len=27
HTTP_EVENT_ON_DATA, len=5
HTTP_EVENT_ON_FINISH
esp_http_client_get_status_code: 200
HTTP_EVENT_DISCONNECTED
Guru Meditation Error: Core 1 panic'ed (IllegalInstruction). Exception was unhandled.
Memory dump at 0x400d2fa0: 6502ad02 00002d52 b1004136
Core 1 register dump:
PC : 0x400d2fa6 PS : 0x00060d30 A0 : 0x800d6384 A1 : 0x3ffb21e0
A2 : 0x3ffcccdc A3 : 0x3ffc428c A4 : 0x00000014 A5 : 0x00000004
A6 : 0x3ffb8188 A7 : 0x80000001 A8 : 0x800d2fa6 A9 : 0x3ffb21c0
A10 : 0x00000000 A11 : 0x00000003 A12 : 0x0000000a A13 : 0x00000001
A14 : 0x00ff0000 A15 : 0xff000000 SAR : 0x00000020 EXCCAUSE: 0x00000000
EXCVADDR: 0x00000000 LBEG : 0x4008ab4e LEND : 0x4008ab59 LCOUNT : 0x00000000
Backtrace: 0x400d2fa3:0x3ffb21e0 0x400d6381:0x3ffb2290
ELF file SHA256: 40c402ae728632f7
Rebooting...
Copie du programme envoyé à l'esp32 Wroom 32
#include "esp_http_client.h"
#include <WiFi.h>
#include "Arduino.h"
#include <forcedClimate.h>
const char* ssid = "Freebox-XXXXXX";
const char* password = "XXXXXXXXXXXXXXXXXXXX";
const char *post_url = "https://monsite/site/client_temp.php"; // Location to send POSTed data
char post_data[140];
// const String *post_data;
const char *rootCACertificate = "-----BEGIN CERTIFICATE-----\n" \
"xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx\n" \
"-----END CERTIFICATE-----\n";
bool internet_connected = false;
// Create an instance of a BME280. The parameters I2C bus and I2C address are optional. For example:
// - ForcedClimate climateSensor = ForcedClimate(Wire, 0x76);
// - ForcedClimate climateSensor = ForcedClimate(TinyWireM, 0x77);
ForcedClimate climateSensor = ForcedClimate();
//initialisation BME280
climateSensor.begin();
//variable du capteur
float temp=climateSensor.getTemperatureCelcius();
float pression=climateSensor.getPressure();
float humid=climateSensor.getRelativeHumidity();
if (init_wifi()) { // Connected to WiFi
internet_connected = true;
Serial.println("Internet connected");
snprintf(post_data, sizeof(post_data),
"temperature= %f &pression= %f &humidite= %f",
temp, pression, humid);
bool init_wifi()
int connAttempts = 0;
Serial.println("\r\nConnecting to: " + String(ssid));
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED ) {
Serial.print(".");
if (connAttempts > 10) return false;
connAttempts++;
return true;
esp_err_t _http_event_handler(esp_http_client_event_t *evt)
switch (evt->event_id) {
case HTTP_EVENT_ERROR:
Serial.println("HTTP_EVENT_ERROR");
case HTTP_EVENT_ON_CONNECTED:
Serial.println("HTTP_EVENT_ON_CONNECTED");
case HTTP_EVENT_HEADER_SENT:
Serial.println("HTTP_EVENT_HEADER_SENT");
case HTTP_EVENT_ON_HEADER:
Serial.printf("HTTP_EVENT_ON_HEADER, key=%s, value=%s", evt->header_key, evt->header_value);
case HTTP_EVENT_ON_DATA:
Serial.printf("HTTP_EVENT_ON_DATA, len=%d", evt->data_len);
if (!esp_http_client_is_chunked_response(evt->client)) {
// Write out data
// printf("%.*s", evt->data_len, (char*)evt->data);
case HTTP_EVENT_ON_FINISH:
Serial.println("");
Serial.println("HTTP_EVENT_ON_FINISH");
case HTTP_EVENT_DISCONNECTED:
Serial.println("HTTP_EVENT_DISCONNECTED");
return ESP_OK;
static esp_err_t post_something()
esp_err_t res = ESP_OK;
esp_http_client_handle_t http_client;
esp_http_client_config_t config_client = {0};
config_client.url = post_url;
config_client.cert_pem = rootCACertificate ;
config_client.event_handler = _http_event_handler;
config_client.method = HTTP_METHOD_POST;
http_client = esp_http_client_init(&config_client);
esp_http_client_set_post_field(http_client, post_data, strlen(post_data));
// esp_http_client_set_header(http_client, "Content-Type", "image/jpg"); // sending a jpg file
esp_err_t err = esp_http_client_perform(http_client);
if (err == ESP_OK) {
Serial.print("esp_http_client_get_status_code: ");
Serial.println(esp_http_client_get_status_code(http_client));
esp_http_client_cleanup(http_client);
displaySensorDetails();
post_something();
delay(600000);
merci de votre aide
