Guru Meditation Error: Core 1 panic'ed (IntegerDivideByZero)
I am experiencing the "Guru Meditation Error: Core 1 panic'ed (IntegerDivideByZero)" error and I can not find where the error lies so I am hoping someone can come to my rescue.
The code, below, is a fairly straight forward code that controls a fan using pwm on an esp32 and measuring the temperature with a DH22. I also store the data to a sd card so I can evaluate the data at a later stage. The program runs fine until it is stopped and rebooted followin the "guru" error. This can happen after a few minutes or hours. My program itself does not involve any calculation, this is mainly done in the dht file.
I would be grateful if anyone could solve this problem for me.
Thanks
Dave
#include "DHTesp.h"
DHTesp dht;
#include <ESP32Time.h>
#include <Arduino.h>
#include <WiFi.h>
#include "FS.h"
#include "SD.h"
#include "SPI.h"
#include "time.h"
#include "BluetoothSerial.h"
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED)
#error Bluetooth is not enabled! Please run `make menuconfig` to and enable it
#endif
#define FAN_PWM_PIN 27  // was 17
#define FAN_TACH_PIN 26  // was 2
#define PWM_CHANNEL 0
#define PWM_RESOLUTION 8
#define PWM_FREQUENCY 25000
int dutyCycle = 0;
ESP32Time rtc;
BluetoothSerial SerialBT;
const char* ssid = "xxxxxxx";
const char* password = "yyyyyyyyy";
const char* ntpServer = "pool.ntp.org";
const long  gmtOffset_sec = 0;
const int   daylightOffset_sec = 3600;
char filename[] = "000000.CSV";
char buffer[80];
const char*  header = " ";
String headerMessage;
String dataMessage;
char  datetime[80];
char  dateandtime[40];
char daynumber[10];
unsigned long previousMillis = 0;
const long interval_sec = 60000;
/////////////////////////VOID  INITIALISE SD CARD  //////////////////////
void initSDCard() {
  if (!SD.begin()) {
    Serial.println("Card Mount Failed");
    return;
  uint8_t cardType = SD.cardType();
  if (cardType == CARD_NONE) {
    Serial.println("No SD card attached");
    return;
  Serial.print("SD Card Type: ");
  if (cardType == CARD_MMC) {
    Serial.println("MMC");
  } else if (cardType == CARD_SD) {
    Serial.println("SDSC");
  } else if (cardType == CARD_SDHC) {
    Serial.println("SDHC");
    Serial.println("UNKNOWN");
  uint64_t cardSize = SD.cardSize() / (1024 * 1024);
  Serial.printf("SD Card Size: %lluMB\n", cardSize);
//////////////////////// VOID   INITIALISE WiFi  ////////////////////////////////////////
void initWiFi() {
  WiFi.mode(WIFI_STA);
  WiFi.config(INADDR_NONE, INADDR_NONE, INADDR_NONE, INADDR_NONE);
  // WiFi.setHostname(hostname.c_str()); //define hostname
  //wifi_station_set_hostname( hostname.c_str() );
  WiFi.begin(ssid, password);
  Serial.print("Connecting to WiFi ..");
    Serial.print('.');
  long rssi = WiFi.RSSI();
  Serial.print("RSSI:");
  Serial.println(rssi);
/////////////////////////VOID SET LOCAL TIME //////////////////////////////////////
void updateTime() {
  struct tm timeinfo;
  if (getLocalTime(&timeinfo)) {
    rtc.setTimeStruct(timeinfo);
    Serial.println(&timeinfo, "%A, %B %d %Y %H:%M:%S");
/////////////////////////  VOID WRITE FILE  ///////////////////////////////////////
void writeFile(fs::FS & fs, const char * path, const char * message) {
  Serial.printf("Writing file: %s\n", path);
  File file = fs.open(path, FILE_WRITE);
  if (!file) {
    Serial.println("Failed to open file for writing");
    return;
  if (file.print(message)) {
    Serial.println("File written");
    Serial.println("Write failed");
  file.close();
/////////////////////  VOID APPEND FILE DATA /////////////////////////////
void appendFile(fs::FS & fs, const char * path, const char * message) {
  //  Serial.printf("Appending to file: %s\n", path);
  File file = fs.open(path, FILE_APPEND);
  if (!file) {
    Serial.println("Failed to open file for appending data");
    return;
       Serial.println("Data Message appended");
       Serial.println("Append failed");
  file.close();
void readFile(fs::FS &fs, const char * path) {
  Serial.printf("Reading file: %s\n", path);
  File file = fs.open(path);
  if (!file) {
    Serial.println("Failed to open file for reading");
    return;
  Serial.print("Read from file: ");
  while (file.available()) {
    Serial.write(file.read());
  file.close();
  dht.setup(25, DHTesp::DHT22);
  SerialBT.begin("Victron Cooling Fan");
  Serial.println("Bluetooth Started! Ready to pair...");
  ledcSetup(PWM_CHANNEL, PWM_FREQUENCY, PWM_RESOLUTION);
  ledcAttachPin(FAN_PWM_PIN, PWM_CHANNEL);
  pinMode(FAN_TACH_PIN, INPUT_PULLUP);
  Serial.println("Initiaiase WiFi");
  initWiFi();
  Serial.println("Initiaiase SDcard");
  initSDCard();
  Serial.println("Set RTC from NTP server");
  updateTime();
  configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
  struct tm timeinfo;
    Serial.println(&timeinfo, "%W, %w, %A, %B %d %Y %H:%M:%S");
  headerMessage = String("Date,Time,Duty Cycle,B2B Temp,RPM") + "\r\n";
  strftime (buffer, 80, "/B2B_Temp.csv", &timeinfo);
  writeFile(SD, buffer, header);
  appendFile(SD, buffer, headerMessage.c_str());
  struct tm timeinfo = rtc.getTimeStruct();
  strftime(datetime, 30, "%F, %X" , &timeinfo);
  strftime(dateandtime, 30, "%F, %R" , &timeinfo);
  strftime (daynumber, 10, "%w", &timeinfo);
//  float t = dht.readTemperature();
  float t = dht.getTemperature();
  if (t < 20) {
    dutyCycle = 0;
  } else if (t >= 20 && t <= 25) {
    dutyCycle = 50;
  } else if (t >= 25 && t <= 30) {
    dutyCycle = 100;
  } else if (t >= 30 && t <= 35) {
    dutyCycle = 150;
  } else if (t >= 35 && t <= 40) {
    dutyCycle = 200;
  } else if (t >= 40 ) {
    dutyCycle = 250;
  ledcWrite(PWM_CHANNEL, dutyCycle);
  unsigned long pulseWidth = pulseIn(FAN_TACH_PIN, HIGH);
  unsigned int rpm = (1000000 * 60) / (pulseWidth * 2);
  Serial.println(rtc.getTime("%A, %B %d %Y %H:%M:%S"));
  Serial.print("Temperature: ");
  Serial.print(t);
  Serial.print("C ");
  Serial.print("  DutyCycle ");
  Serial.print(dutyCycle);
  Serial.print("  RPM: ");
  Serial.println(rpm);
  if (currentMillis - previousMillis >= interval_sec) {
  dataMessage =   String(dateandtime) + "," + String(dutyCycle) + "," + String(t) + "," + String(rpm) + "\r\n";
  appendFile(SD, buffer, dataMessage.c_str());
  readFile(SD, buffer);
  delay(5000);
  // Write to Bluetooth
  SerialBT.println(datetime);
  SerialBT.print("Temp  ");
  SerialBT.print(t);
  SerialBT.println(" C");
  SerialBT.print("DutyCycle  ");
  SerialBT.println(dutyCycle);
  SerialBT.print("RPM  ");
  SerialBT.println(rpm);
  SerialBT.println();
Where, exactly, does that message occur?
have you tried putting that message into your favourite internet search engine?
eg, Guru Meditation Error: Core 1 panic'ed (IntegerDivideByZero) - Google Search
Are you sure? What happens if pulseIn returns 0?
Use the EspExceptionDecoder to see on which line and in which function the error occurs.
Hi awneil,
thanks for your reply, I have searched the internet and all i find is that part of the memory has been addressed and it shouldn't and unfortunately my knowledge of the workings of these devices is beyond me.
I have never used EspExceptionDecoder I will look into this.
I guess it may be possible for the pulse in to be zero, I can always add 1 to it as I am not in any need of that sort of accuracy.
I'll check these things out, thanks
Hi awneil,
did indeed return a zero every so often.
Thank you very much indeed.
Dave
