Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x400d1de0 PS : 0x00060630 A0 : 0x800d1eb4 A1 : 0x3ffb1cd0
A2 : 0x00000000 A3 : 0x3ffb1d1f A4 : 0x00000001 A5 : 0x00000001
A6 : 0x00000000 A7 : 0x00000000 A8 : 0x00000000 A9 : 0x00000000
A10 : 0x00000000 A11 : 0x3ffcbc7c A12 : 0x00000050 A13 : 0x00000001
A14 : 0x00000000 A15 : 0x00000000 SAR : 0x0000000a EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000008 LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0xffffffff
Backtrace: 0x400d1de0:0x3ffb1cd0 0x400d1eb1:0x3ffb1cf0 0x4015bfe2:0x3ffb1d10 0x400d5065:0x3ffb1d40 0x400d50fd:0x3ffb1d60 0x400d36a1:0x3ffb1d80 0x400d3b9f:0x3ffb1e20 0x400d3bef:0x3ffb1e60 0x400d3c13:0x3ffb1e80 0x400d19d2:0x3ffb1ea0 0x400d1b75:0x3ffb1f90 0x400d5f9d:0x3ffb1fb0 0x40088f69:0x3ffb1fd0
Rebooting...
Platform: WEMOS LOLIN32
Source code:
#include <WiFi.h>
#include <HTTPClient.h>
int ldr = 32; // Analog
long t = 0;
// Sensor variables
long lastBlink = 0;
int threshold = 512; // Arbitrary so far...
float duration = 0;
float W = -1.0;
// WiFi variables
const char* ssid = // MY SSID
const char* password = // MY PASSWORD
const char* serverName = // MY API ENDPOINT (POST)
int ldrValue = 0;
WiFi.disconnect();
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.print("Connected to WiFi network with IP address:");
if (millis() - lastBlink > 1000) {
ldrValue = analogRead(ldr);
Serial.println(ldrValue);
if (ldrValue > threshold) {
t = millis(); // Freeze time.
duration = (t - lastBlink) / 1000.0; // Calculate the time difference in seconds.
lastBlink = t; // Update last blink time.
// Calculate AVERAGE wattage since last blink.
W = 3600.0 / (float)duration;
print_power(duration, W);
post(duration, W);
void print_power(float duration, float W) {
Serial.print("Average power consumption for the last ");
Serial.print(duration);
Serial.print(" seconds was ");
Serial.println(W);
void post(float duration, float W) {
if (WiFi.status() == WL_CONNECTED) {
HTTPClient http;
http.begin(serverName);
http.addHeader("Content-Type", "application/json");
String json = "{\"power\":";
json += (int)W;
json += "}";
Serial.print("JSON = ");
Serial.println(json);
int httpResponseCode = http.POST(json);
Serial.print("HTTP Response code: ");
Serial.println(httpResponseCode);
http.end();
Serial.println("WiFi Disconnected");
I have a simple LDR hooked up to GPIO 32 and 3V to measure whenever a light pulse comes in. This works fine for an arbitrary (low) number of times, usually less than ten. It prints the JSON fine, the request is received on the server and the reply is processed fine by the ESP. But at some point it throws the error above. I’ve read things about watchdogs, stating that loops shouldn’t be frozen too long, but I don’t that is the cause here. Also I don’t think I have uninitialised variables causing a null pointer exception.
Any help would be greatly appreciated.
