i am getting this error when i try to run two functions parallel with my esp 32. The first loop will control an actuator via a self-defined function, the second loop will control a stepper motor through inputs from a joystick.
Error message:
Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
12:53:34.269 ->
12:53:34.269 -> Core 1 register dump:
12:53:34.269 -> PC : 0x400d155f PS : 0x00060630 A0 : 0x800d1487 A1 : 0x3ffb2780
12:53:34.411 -> A2 : 0x00000000 A3 : 0x00061a80 A4 : 0x0002ae71 A5 : 0xb33fffff
12:53:34.504 -> A6 : 0x00000001 A7 : 0x00000001 A8 : 0x80082e70 A9 : 0x3ffb2780
12:53:34.551 -> A10 : 0x3ff000e0 A11 : 0x00000001 A12 : 0x3ffbdc88 A13 : 0x00000000
12:53:34.645 -> A14 : 0x00000000 A15 : 0x00000000 SAR : 0x0000001e EXCCAUSE: 0x0000001c
12:53:34.739 -> EXCVADDR: 0x00000004 LBEG : 0x40085d89 LEND : 0x40085d99 LCOUNT : 0xfffffffe
Backtrace:0x400d155c:0x3ffb27800x400d1484:0x3ffb27a0 0x400d113a:0x3ffb27d0 0x400d1227:0x3ffb2800 0x400d4105:0x3ffb2820
#include <Wire.h>
#include <Arduino.h>
#include <Adafruit_MCP4725.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BNO055.h>
#include <utility/imumaths.h>
#include <Stepper.h>
// define objects
Adafruit_MCP4725 dac0;
// PWM properties
const int pwmPin = 13;
const int freq = 732;
const int ledChannel = 0;
const int resolution= 8;
// boolean variables
bool autoMode = false;
bool mannualMode = false;
bool delayOrNot = false;
bool fastOrNot = false;
bool cutoffOrNot = false;
bool preTestTrigger = false;
// experimental variables
int delayTime = 19;
int downStep = 1023;
int cutoffVol = 1364;
// stepper motor
const int stepsPerRevolution = 2048;
// ULN2003 motor driver pins
#define IN1 D10
#define IN2 D11
#define IN3 D12
#define IN4 D13
// Joystick Pins
#define inputX A3
#define inputY A4
#define inputC D2
int outputX = 0;
int outputY = 0;
int outputC = 0;
// Initialise stepper motor
Stepper myStepper(stepsPerRevolution, IN1, IN3, IN2, IN4);
TaskHandle_t Task1;
Wire.begin();
while(!Serial);
Serial.println("Serial communication set up");
// set up pin mode
pinMode(LED_BUILTIN, OUTPUT);
pinMode(inputC, INPUT);
// set up DAC converter
// if(!dac0.begin(0x62)){
// Serial.println("Failed to connect to the converter.");
// while(1);
// set up pwm properties
ledcSetup(ledChannel, freq, resolution);
ledcAttachPin(pwmPin, ledChannel);
// stepper motor speed
myStepper.setSpeed(5);
// Initialise your task (2nd loop)
xTaskCreatePinnedToCore(
loop2, // name of the task function
"printLettera", // name of the task
1000, // memory assigned for the task
NULL, // parameter to pass if any
1, // priority of task, starting from 0(Highestpriority)
// *IMPORTANT*( if set to 1 and there is no activity in your 2nd loop, it will reset the esp32)
&Task1, // Reference name of taskHandle variable
1); // choose core (0 or 1)
// LED for final check
digitalWrite(LED_BUILTIN, HIGH);
delay(3000);
digitalWrite(LED_BUILTIN, LOW);
// Loop 1: For haptic motor control
const int dutyCycle = 127;
int inComing = Serial.read();
// write specified input signal wave
ledcWrite(ledChannel, dutyCycle);
if(Serial.available()>0){
if (inComing == 48){
autoMode = true;
Serial.println("Initial display is ready to go");
if (autoMode){
Serial.println("Display 9 configurations at once");
Serial.print("Starting in: \t");
Serial.print("3 \t");
Serial.print("2 \t");
Serial.println("1 \t");
// delay time configurations
hapticConfig(19, 255,0,19);
delay(5000);
// hapticConfig(0,255,0,39);
// delay(5000);
// hapticConfig(39,255,0,15);
// // ramp down step length configurations
// hapticConfig(19,1024,0,29);
// delay(5000);
// hapticConfig(19,64,0,15);
// delay(5000);
// hapticConfig(19,255,0,19);
// delay(5000);
// // cut-off voltage configurations
// delay(5000);
// hapticConfig(19,255,1364,19);
// delay(5000);
// hapticConfig(19,255,511,19);
// delay(5000);
Serial.println("Initial displace ends");
autoMode = false;
// loop 2: For stepper motor control and encoder readings
void loop2(void*parameter){
for (;;){
// write your code the 2nd loop to run endlessly
outputX = analogRead(inputX);
outputY = analogRead(inputY);
outputC = digitalRead(inputC);
if (outputX < 100){
Serial.println("Moving to the left");
myStepper.step(-stepsPerRevolution/4);
else if (outputX > 4000){
Serial.println("Moving to the right");
myStepper.step(stepsPerRevolution/4);
void hapticConfig(int delayTime, int downStep, int cutoffVol, int maxRepeat){
uint32_t dac0Vol = 4095;
for (int repeatTime = 0; repeatTime <= maxRepeat; repeatTime ++){
for (int counter = 0; counter <= delayTime; counter ++){
dac0.setVoltage(dac0Vol, false);
delay(1);
//Serial.println(dac0Vol);
for (int value = 4095; value >= cutoffVol; value = value - downStep){
dac0.setVoltage(value, false);
//Serial.println(value);
